I sell Audis, so let me give you some guidance. For the record, I have a 2018 S4 Prestige w/ DA, Daytona Gray on red (so pretty much the same car). Couldn't be happier with my choice.
The Prestige will give you the following equipment standard, which you CANNOT GET even as an option on the Prem+ model:
*Heads up display
*Interior LED lighting package that will allow you to turn your trim lighting a whole rainbow of colors (prolly not a must-have, but def a nice-to-have).
*Top view camera system
(it also has double-pane glass on the front windows to reduce road noise, but who cares)
If any of those features are must-haves for you, you need the Prestige.
If you're just in it for the performance and don't care about the tech, go with the Prem+. They lease much better than do the Prestiges; residuals are higher on the Prem+. That said, if your dealer is getting you a Prestige for only $55/mo more than a similarly equipped Prem+ model, I would jump all over that bc, MSRP for MSRP, the difference in lease payment is usually more than that. Most of the leases I've had go across my desk are usually around $100/mo different between Prem+ and Prestige if the MSRP is close.
As some of the other guys here have said, one of the key selling points of the Prestige is the availability of the Driver Assistance package. It's not available on Prem+. But what's further awesome about that package is that all of that DA info *populates in the HUD*, so it REALLY augments the awesomeness of the HUD. IMHO, it's a waste to get the Prestige without the DA because you're not getting the full benefit of the HUD. Without DA, the HUD will basically just give you current speed, and turn-by-turn nav directions if you're navigating. There are a few other things it'll display, like cruise control when you first turn it on, but for the most part, it's just current speed and turn-by-turn.
BUT...once you add the DA package, NOW you get all the cool stuff. You get the traffic sign recognition system, which will recognize three types of traffic signs: speed limits, school zones, no passing zones. If you drive past one of these signs, the car's camera will grab it and give you a pop-up in the HUD letting you know the speed limit and if you're in a school/no passing zone. Your Active Lane Assist will appear in the HUD. Your Adaptive Cruise activation will appear there, and when you adjust the Adaptive Cruise's following distance, it will show you the settings for a few seconds in the HUD. When Stop-and-Go Traffic Jam Assist is working, it'll display that. The DA package also does this: remember in driver ed class when they preached about a "two second following distance"? Well, you can set a following distance for the traffic ahead of you (I have mine set to 1.6 seconds), and if you start following the car in front by that distance OR LESS, it will give you a flashing red distance indicator in the HUD and Virtual Cockpit, letting you know you need to back off a bit. The settings for this system go from 1 second to 3 seconds following distance, or you can turn it off entirely. IMO, the Adaptive Cruise is worth its weight in gold bc it almost serves as a de facto emergency braking system, bc if traffic starts to rapidly slow while you're not paying the closest of attention, it'll slow the car down for you. I'm not sure how HARD it can hit the brakes if it has to, and hopefully I'll never find out, but so far, so good.
One thing to consider: if you have the DA, if you ever have to have the windshield replaced or, if I remember correctly, when you get new tires, you will have to have an "adaptive cruise alignment" performed, which costs a few hundred bucks and is apparently necessary in order to make sure all the car's various adaptive cruise sensors are properly aligned. I've yet to have this done, but I can live with it. Worth it to me.
Hope this helps! (Go Prestige!)
