Originally Posted by
rayray
The offset is 40. I have just been playing around with the tire size comparison calculator for a setup that is not over what I am now (about +4%). I know its possible, but I haven't found a combo that works yet. This is just a "if I can" type of thing; its nothing I am dead set on wanting.
A 245/35 actually has a pretty decent sidewall, just about 1/2'' less than the factory 245/40.
To get a larger sidewall dropping down to a 30 series you would need to go wider than would fit (285/30 still has a smaller sidewall)
With a 40 offset, you could probably get away with a 255/35/20, but given that you are only on 9'' wide wheels and 255 is slightly over 10'' wide (variances by tire brands obviously, just pure math) to give it a little more.
I would say you are probably at one of the best sizes for maximizing sidewall on your wheels while still maintaining a normal looking tire size.
