Here are some mechanical facts and common problems we have come across (we will edit this post as we find time to add more info and as we come accross new discoveries. Feel free to contact us with any further help or parts with any of these items we mention.
Don't be extremely concerned with the common problems we share since ALL cars have their common problems and some NOT so common. This will hopefully help people fix their car quicker and at a lower cost with some of these facts hopefully serving as a tool.
Mechanical differences between B6/B7 S4
-Flywheels (A B6 flywheel only works with a B6 Pressure plate and the same with a B7, they bolt up to either motor though.)
-Clutch Pressure Plates (A B6 pp only works with a B6 flywheel and the same with a B7)
-Intake Manifolds (B6 S4 has a nice gray coating on top and the B7 S4 has a temperature resistant coating underneath where it is closest to the motor)
-Core support to motor clearance (the B7 S4 has about 1 to 2 inches more room there than the B6)
-Center Diff (The B6 S4 and the 05.5 B7 S4 only share the same center diff. The 06 and up B7 S4 and RS4 share the same center diff.)
Common trouble codes or Engine Electrical problems. and solutions
-Code = 18613 - Performance Malfunction in Cooling System
P2181 - 008 - Implausible Signal
Solution = If your coolant sensor checks out ok or has been replaced and your car is full of coolant this is MOST likely a sticky thermostat. (We sell these)
-MAF (Mass Airflow) sensor issues or MAF codes. These cars have Bosch MAFs which are notoriously known for the HIGHER than normal failure rate. We have seen this in the early B5 S4, B6/B7 S4, Jettas, A4s and many others. So MOST of the time if you have MAF codes or if you get weird long term fuel trim codes that are not due to a bad 02 sensor then it is highly likely your MAF is bad. (We sell the replacement electronic portion for a low cost on our site.)
-Missfires (shuttering or rough running engine) or flashing CEL. The CEL flashes to warn you that your car is missfiring and you WILL damage your catalytic converters if you don't fix the problem. Most of the time this is one or some of your coil packs going bad. The coil packs (8 per car) have been updated by Audi for the B6 and the B7 S4 several times and they are currently on revision Q. This indicates they are aware of this problem. (We sell the replacement OEM updated Q coil packs on our site.)
Engine mechanical failures and facts of interest
-We have talked to some customers that have had some kind of valve train and or timing chain issue with stock engines. We are not sure if it is commonly the rocker arms, the valve springs, keepers, tensioners, etc. As we get more specific details from them and or Audi we will share. We are not sure the percentage on how common this is.
-We have talked to some customers that have had oil consumption issues with stock engines that ended up being worn cylinder walls and needed an engine replacement (these cars have aluminum cylinder walls WITHOUT any kind of sleeve) We are not sure the percentage on how common this is.
I will keep this a living document and add more over time. Feel free to share more info in your posts with extra details about any of the items above or if you have an questions about something technical that you would like to see us answer please feel free to ask.
Thanks.
