Results 1 to 27 of 27
    Veteran Member Four Rings neoprufrok's Avatar
    NOR CAL
    So if smaller wheels are better for performance... why is it that Ferrari and Porsche
    are making bigger wheels for their "higher performance cars." Two examples being the new 997 Carrera S has 19" wheels in the front and the Ferrari 575M now has a "track package" that includes their ceramic composite discs and bigger 19" wheels.
    Seems that the current thinking of smaller wheels = better handling may not be holding true? I would think that those companies would want smaller wheels if they thought the performance benefit would be better.
    I'm also assuming that the wheels they are putting on those cars are fairly lightweight, thus negating the one big negative of having bigger wheels = weight.
    Currently:
    2018 GT3 Touring - Graphite Blue Metallic
    2016 McLaren 675LT - Mexico Blue with Roof Scoop
    2019 BMW M4 Convertible - Yas Marina Blue Competition Package
    Will be missed: 2001.5 Audi S4, 2004 Audi A4, 2004 Audi A8, 2008 Audi RS4, 2016 Porsche Cayman GT4, 2018 Porsche GT3.2, Mercedes C63 Black Series, McLaren 12C Spyder
    Podcast and Instagram: The Throttle Dogs
    Veteran Member Four Rings astris's Avatar
    Mar 03 2004
    nothing
    San Diego
    Don't Le Mans cars ride on 19's or 20's? Those cars are on incredibly light wheels. I can't remember the exact weight, but it is ridiculous.
    Veteran Member Four Rings marked001's Avatar
    Feb 17 2004
    08 Subaru Impreza WRX; vr
    South Philadelphia
    I dont think it was ever said that smaller wheels handle better... thicker sidewall just means more deflection...
    I think the performance issue with big wheels was always the added weight and if there was an increase in rolling diameter
    F the Jersey Jerks
    Jersey Jerk hata #1
    99.5 t28 A4 ....bye bye.
    www.REVI21ON.com
    Active Member Four Rings
    Cause they all know that it's baller to roll 19" and higher
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    The weight was the biggest issue I guess. Plus if you had a Ferrari would you be rolling on 17's?
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    2000 S4
    You touch on the answer in your original question: brakes. You can't fit 15" calipers behind 17" wheels there is simply not enough clearance, hence you need bigger wheels to clear big brakes. And as others have mentioned bigger wheels aren't always that heavier ie. 17x8 stock S4 wheels weigh in at 28 lbs. per wheel while 18x8.5 (bigger and wider) SSR weigh in at 17 lbs. per wheel.
    Veteran Member Four Rings D Piddy's Avatar
    Feb 12 2004
    Me: 2010 B8 A4 S-Line In the Family: BMW Z4M, BMW 335xi, Range Rover Evoque, Honda Element
    Washington, D.C.
    the unpsrung mass is the issue with larger wheels. these cars have incredibly light wheels therefore elminating the problem. plus, the wider the wheel, the better the performance, it creates a larger contact patch. but u can't have 15x10 wheels, it just doesn't work well, too much rubber and no tire companies make those. so these companies use large wheels with large widths that happen to be light in order to achieve max performance. plus the aforementioned brake issue and said ballerness of 19 and 20" rims
    Feb 10 2004
    2009 A4 2.0T Sedan
    Yup, all about the big brakes. Damn mullarks beat me to it!
    NOR CAL
    Yeah, that's a good reason...
    I've always known the arguments for and against, but now its starting to crystallize clearly why hi-perf cars go with bigger wheels.
    I guess now I can use my Volks as my "track wheels" and get another set of 19's as my daily driver rims!!!
    Currently:
    03 A4 Avant, 85 ABA Golf
    Palo Alto, Ca
    Your crazy meng!!
    Seattle/Seoul
    my thoughts exactly!!
    peace
    DBC ownz joo!! <- Wow what year is that from??
    Registered Member Two Rings
    Feb 13 2004
    Sacramento
    what they said about the brakes.. plus... with that much power, the companies can afford to sacrafice a little excess luggage for balla effect
    Veteran Member Four Rings maxh2o's Avatar
    Apr 13 2004
    B5S4,C2avant,Cgt,UrQ
    San Francisco
    Its all Bout Big Brakes, Balla effect and Booty!
    okay, I've had too much coffee today, ignore my last few posts.
    http://www.audizine.com/gallery/data...70780_copy.jpg
    Dominating the fast lane since 1984.
    Veteran Member Four Rings HotSauce's Avatar
    Jul 26 2004
    Madison
    If the wheel was too small, you would need one of the following.
    1) Stiffer sidewalls. If the tire has to be taller, to achieve the same overall height, the added leverage caused by the sidewalls will put stress on the sidewalls. If the sidewall isn't stiff enough, the tire buckeles
    2) Smaller tires. Alright, so if you want lower profile sidewalls, and keep the smaller wheels, you'll need to raise the overall gear ratio of the car, to attain the same top speed.
    3) So say you did figure out the sidewall situation...What do you do about brakes? I suppose you could compression brake and pray, but in my opinion, the best way is to go with bigger wheels, with lower profiles, and some huge brakes.
    Veteran Member Four Rings idrivemyself's Avatar
    Boxes 'n stuff
    Vancouver, WA
    it all depends on your car's weight, stance, power output, and drivetrain. just take a look at any open wheel race car (F1, IRL, CART, etc).
    Even my dishwasher is made by Bosch.
    I have Vag-Com and am happy to help... PM me for more info.
    Senior Member Three Rings Thrawn's Avatar
    Feb 18 2004
    Aliso Viejo
    Some of the WRC cars run 19"s on tarmac...
    "You don't know me, and you don't know my style..."
    GTA, Canada
    Exactly, and all the touring cars that have huge tucked rims.
    The wheels and rims they use are super lightweight though, so it helps and then they cram a massive brake under there. Can't complain with that combo.
    RippleChip (Ryan) - Moderator
    Audizine
    01.5 eh4 1.8T || 12 eh5 2.0T
    NOR CAL
    Originally posted by Saturnine
    Your crazy meng!!
    It's all your fault mang.
    I need to find some blacked out rims at 19"... haha.
    Currently:
    Registered Member Three Rings Hutash's Avatar
    2002 TT 225 coupe
    Ventura, CA
    It is all a compromise. Side walls, weight, brakes, looks, horsepower, etc, etc, etc.
    The overall trend is to go with bigger wheels for the aesthetics. How many people were rolling on 19" wheels five years ago?
    Feb 10 2004
    2019 Mk7.5 Golf R His/Her
    Eastvale
    well as mentioned it's dependent on the racing formula...open wheel racing they're running 15x10 or so w/ stiff ass sidewalls where as in the sedan type racing teams go w/ bigger wheels for less sidewall deflection and the ability to run bigger brakes. but some of the racing series are spec class where they dictate max wheel and tire sizing so yah.
    But the materials they use are crazy magnesium alloy etc superlight shiet
    Instagram: @daohaus_garage
    Veteran Member Three Rings rbt's Avatar
    Feb 25 2004
    Tracy
    Just remember though, even lightweight materials won't defeat the laws of physics. Even if you had, say, a 19" lightweight wheel that weighs the same as a given 17", the 19" has a higher Polar MOI due to diameter. it will resist acceleration/deceleration more (all other factors being equal). whether it's enough to notice? depends, I suppose. In a Vette Z06 w/ all that torque probably not!
    Feb 10 2004
    Eastvale
    having a big wheel can also have a positive affect going into the corner as you can carry more speed in due the "fly wheel" affect of the bigger wheel no?
    2002 TT 225 coupe
    Ventura, CA
    Yes, but it is also harder to stop (i.e. slow down) and to get rolling again. Hence the need for bigger brakes and more horsepower.
    NOR CAL
    Well I got the bigger brakes coverd.. now for the POWER... hahaha.
    I think the other thing is the feel and response of 19" sidewall is much better than a 17" due to the soft sidewalls on 17" tires. Also, the contact patch is smaller on 17" vs a 19" wider rim.
    Magnesium alloys... when are we going to get this technology?
    Currently:
    Feb 10 2004
    Eastvale
    not DOT legal...you can only have X amount of magnesium in the alloy mix any higher and it wont be road legal
    that's why when the BTCC was big in the late 90's w/ the fwd sedans carrying your speed into the corners was critical...scrub off too much speed and you kill your exit speed.
    Feb 13 2004
    Sacramento
    you talkin about the 3 B's of car modifying? btw u forgot one more B.... ahah
    Senior Member Three Rings Mr.Black's Avatar
    Feb 14 2004
    German aluminum und schteel.
    Humm.
    well all the answers were touched on it but in one word. Technology. forgeing has made bigger rims stronger and lighter than ever. and wheel strength is an improtant factor on a 150+ mph car. the Lil 15s on a ferrari 308 are super strong. tires have also come a LONG way in 10 yrs and they played a big part too. lastly style. image is probably the number 1 reason for most porsche and ferrari purshases (unfortunatly not performance). and, yeah 200k cars w 17s... just not cool.
