Page 1 of 3 123 LastLast
Results 1 to 40 of 87
    Aug 06 2016
    colorado
    allroad single turbo build
    Summary:
    2001 all-road i got off craigslist with STK conversion already done by PO. PO did things hastily and under the guise of creating a drift missle.(Weld diffs, rwd conversion, wiring harnesses resting on down pipes, chinese t66 turbo, ect) needless to say I have it torn apart and am rebuilding as I am wanting to build a nice DD for myself with a bit of grunt.
    Right now I have the entire drive train torn apart and am rebuilding.
    Currently:
    -01e rebuild under way with JHM carbon syncros
    -stock 2.7 heads at machine shop for inspection, pressure test, and valve job.
    -block at machine shop for hot tank and hone
    -rotating assembly will get balanced once block comes back with ok bill of health with IE forged rods.
    -PTE5858 with .87 hot side on its way
    -PTE 46mm wg
    -EV14's on the way (298's)
    -clutch went with JHM stage4 and rs4 pressure plate, already worried it may not be enough, we will see.
    Undecided:
    -thinking walbro 450 intank as it seems to drop into allroad tank/carrier
    -sensors:
    maf: was planning on hitachi but not sure
    map: was planning stocker but now unsure
    primary 02's: was thinking pre turbo each bank as I'm worried about tuning with a single in the DP.
    tuning:
    Was thinking of tuning myself, still might, just scared at this point and still learning.
    Goals:
    I'd like this to be a daily driver with some grunt, but reliability will take precedence over power, give and take all that. The most power I'm looking for would be 500whp. If that could be achieved in a reliable set up, that's where I will stop. If to many reliability areas must be dropped to achieve that will happily tone the power down. Not really planning on launching it ever, high way rollers sure.
    Well that's about it for now, will upload some pictures when I get my desktop back up and running.
    please feel free to chime, any input is appreciated.
    motor out, helper in background:
    Taking motor apart:
    rebuilding trannY:
    putting heads back together:
    tested out Chem dip to remove carbon. it works amazingly.
    block painted crank going in
    ie rods:
    mostly assembled:
    waiting for manifolds:
    - - - Updated - - -
    Got new manifolds finished and bolts actually clear this time:p
    merge collector with turbo inlet v-band:
    - - - Updated - - -
    update got new tig torch finally.
    got up pipes fully tacked up.
    Mistake 1: i did not fully bolt/secure the heads manifolds to the heads while tacking *im dumb* so had to cut off a few tacks.
    Lucky mistake outcome: Upon remove the manifold realized it was actually pretty warped on one side, put some dykem on it and ran it on a belt, and it was not going to seal at all on the end.* Faced both manifolds nice and flat, fully bolted to heads now and working on finishing tacking and will start welding.
    - - - Updated - - -
    I'm still very much learning but every now and then I get lucky.
    obligatory weld porn,
    - - - Updated - - -
    up pipes, wire insulation, insulation everywhere done. dont mind wierd glow, had oil on lens.
    got motor back in car, oh the swearing!
    turbo clearence is spot on, score:
    I'm hoping tomorrow to finish the down pipe and exhaust. then onto the cold side.
    Anyone know the part number for the clip that holds the clutch line into the slave cylinder?
    - - - Updated - - -
    downpipe done. Waiting on a 1.75" and 3" vband so i can finish the exhaust.
    117 injectors on the way, was sent wrong size an fittings for turbo oil drain, waiting on those.
    Could not figure out part number to clip that holds clutch line into slave cylinder so had to order whole new slave :(
    front end is going on soon, getting anxious!
    May 20 2010
    Subbed! Looks amazing! Cannot wait to see how this finishes up!
    Veteran Member Three Rings JediJoker7169's Avatar
    Dec 11 2009
    PDX, OR/SF Bay Area, CA - USA
    Kudos to the PO for an unconventional drift missile choice. Best I've ever seen was a Ram shortbed with a hydro.
    - JediJoker
    "Dieselgate" / 2011 VW Jetta SportWagen TDI 6-speed
    FORMER: "Das Boot" / 2001 Audi A6 2.7T quattro sedan:
    RS4 clutch / 710N DVs / 2Bennett Stage2 GT front 6-piston Brembo 350mm/rear 311mm / Bilstein PSS9 / Hotchkis Sport anti-roll bars / 034 Density adjustable front UCAs/Track Density front shock mounts/spherical ARB end links / O.Z. Superturismo LM 18" x 8" / Hella E-codes / LED tails / Facelift rear license plate trim
    Aug 06 2016
    colorado
    turned this on lathe today so i can recycle instead of vent to atmosphere.
    May 20 2010
    God I miss when I had access to a machine shop...
    Aug 06 2016
    colorado
    starting on cold side
    Aug 06 2016
    colorado
    ev14 117's did not work out and I ended up getting upsold to ID725, which are probably just modified 117's but should work i hope.
    got one side of the cold side done, just waiting on a flange to weld on for bov, working on the other.
    Stuck a bit trying to figure out how to plumb in the wastegate dump, its so cramped in there its hard to mock up, need a way to index the vband flanges so i can bolt it all up, mark the flanges, take it apart then bolt it up in the shop and plumb it in.
    Aug 06 2016
    colorado
    Got waste gate dump finished:
    mocked:
    tacked:
    welder'd:
    Jun 21 2005
    Milton, Ontario
    Amazing!
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
    May 20 2010
    Great fab work!
    Aug 06 2016
    colorado
    got the id725's in and had an epiphany. This whole time i have been pulling the metal clip off the plug, un plugging, and putting the clip back on. turns out you just push down on the clip!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!
    please dont judge me :p
    Active Member Two Rings C H A I N S A W's Avatar
    Apr 06 2016
    2000 A6 2.7t, '99 Mustang GT
    Indiana
    Motor pull/install outside, in the snow, working off plywood. You are a lot tougher than I am.
    Cool build!
    -Ken
    Aug 06 2016
    colorado
    Tough and stupid can be used as synonyms in this instance.
    got exhaust finished but its F'in unruly to mount on the car as one piece. After many rage fits I ordered another vband and will be breaking the under car exhaust system into 2 parts so there is some hope of installing it by myself.
    Aug 06 2016
    colorado
    Was finalizing the charge piping today, one weld left. Gust of wind came and closed the hood, and I don't have the release hooked back up yet. So good news is my underhood shenanigans clear the hood, bad news is now i have to figure out how to open it.
    Aug 06 2016
    colorado
    charge piping done:
    installed:
    Senior Member Three Rings Eurylo's Avatar
    Nov 17 2015
    Earth
    Going off ova there!
    this shzt makes me cold just looking at the pics/ time of year!!
    100 C5's
    Aug 06 2016
    colorado
    -Shift linkage reconnected and working, machined a "short shift" linkage.
    -heater hoses hooked back up.
    -catch can attached to car and plumbed in.
    -wiring harness position finalized and secured.
    -drive shaft reconnected.
    -various other things.
    cut and welded some tabs to my charge pipe so i could mount this vacuum distro block. Vacuum system plumbed:
    Aug 06 2016
    colorado
    Got air intake welded and installed.
    2nd exhaust piece underneath welded and installed.
    remaining:
    get wideband, boost, and oil pressure sender wires inside cab.
    Wire in zetitronix.
    Wire in Fuel pump
    add fluids
    pray
    Sep 20 2016
    San Diego
    Seriously awesome build, can't wait to see where this ends up.
    May I ask what you're taking these progress shots with, BTW?
    Project: Expedition Allroad
    2002 Allroad, 2.7, 6MT
    225/75/16 BFG KO2s, IPP arms, 402 mod, SAI delete, H&R spacers, Arnott front bags, Rola ext. cargo basket, Stage 1 tune
    For Sale: 2002 2.7 APB Engine (timing belt snapped) + B5 S4 Wiring Harness
    Aug 06 2016
    colorado
    some cellphone. most a7sii
    Aug 06 2016
    colorado
    was planning on first start today; however, got everything ready to go, went to put in coolant and there are leaks.
    reservoir has a big crack in it. upper rad hose has small leak.
    tempted to junk yard them but also dont wanna risk another junk part, but jesus the radiator hoses are expensive!
    Aug 06 2016
    colorado
    Found more leaks, 2 pin coolant sensor in cross pipe, bad o-ring.
    weld on the an fitting i welded onto the heater pipe cracked, off to buy brazing rod.
    Aug 06 2016
    colorado
    an welds brazed over. Side note brazing is weird.
    Kind of fortunate, I had to tear quite a bit out(turbo, uppipes, downpipe) and found a couple things that might have been issue down the road.
    - oil distro block had two washers on one side of each banjo, looks like the old washer "stuck" to the block and i did not notice during assembly. Probably would not have been an issue but resolved anyway.
    - waste gate v-band into down pipe was not seated properly, would have leaked for sure, but just been noisy/smelly.
    gonna go to junk yard tomorrow to get overflow tank. I ordered one online but wont get here until Friday and I'm wanting to see if this thing will fire up!
    Jun 21 2005
    Milton, Ontario
    happy new year. sounds like good progress.
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    Aug 06 2016
    colorado
    ready to go just waiting on base file from tuner.
    Aug 06 2016
    colorado
    welp she wont start.
    have air, have fuel, have spark.
    starting to think timing is off and i have bent valves. sighhhhhhhhhhhhhhhh
    Aug 06 2016
    colorado
    well it started, but its running like a tractor.
    It's either missing or timing is off and valves are properly smashed.
    Aug 06 2016
    colorado
    consistently starts now, but only running on 4 cylinders.
    2 and 6 do nothing but missfire.
    Aug 06 2016
    colorado
    off to buy leak down tester. preparing myself mentally for the inevitable on the way.
    Aug 06 2016
    colorado
    well leak down was fine. All cylinders between 8-10%, granted that's with a harbor fraught tester, but even still leads me to believe as of now the valve train and rings are sealing properly.
    i put in new plugs too the ones that were in there were fouled to all hell. Will test it once i warm up enough to go put the charge piping back in.
    Aug 06 2016
    colorado
    Cool so still having misfires, but stethoscope'ed the injectors and 2 and 6 are not making much noise if at all. Also new code showed up saying barometric and map sensors have implausible signals which I have read means 02 sensors shorted out and ECU is fried. Previous owner had main loom stuck between up pipe and down pipe so that is highly plausible.
    New direction is source ecu. fingers crossed.
    Aug 06 2016
    colorado
    could not find ecu locally for reasonable price. Tuner sending me one. will be down for a few days waiting but works out cause its 2 degrees here and I dont really want to be outside anyway :p
    Aug 06 2016
    colorado
    junk yard had one s4 in stock so i took a drive hoping to get the ecu. It had already been pillaged but I was able to get the 3 spoke wheel and airbag.
    Aug 06 2016
    colorado
    argggghhh PO cut all the electrical connectors off the clock spring so now my cheap wheel upgrade is going to end up costing me.
    Aug 06 2016
    colorado
    oh well clock springs aside
    old wheel:
    new wheel:
    Aug 06 2016
    colorado
    17z's installed and plumed:
    I had to cut and re-flare every brake hard line on the car, which was a real treat due to the fittings corroding onto the line.
    Also got a vacuum bleeder which i was sooooo stoked about because i hate bleeding brakes but my little compressor just does not have the oomph to keep it happy so gonna have to switch to the ol' fashion method.
    ECU should be here today.
    Aug 06 2016
    colorado
    oh yea also pulled a clock spring out of an a6 at the junk yard, so wheel is fully installed.
    Aug 06 2016
    colorado
    ecu in, weird implausible map/barometric codes gone, but still have misfires.
    Lowered my stupidity level slightly and actually looked at boost gauge. only holding -10 at idle, obvious leak somewhere but cant seem to find it.
    starting to lean towards smashed valves again. Going to try to build a smoke tester tomorrow. and do leak down again maybe i just did the test incorrectly.
    Veteran Member Four Rings SteelyS6's Avatar
    Oct 29 2011
    Winnipeg Manitoba
    Quote Originally Posted by spacecadet View Post
    Props to you for all this work. Hope your valves aren't fubar.
    EBC Red pads and what rotors?
    Aug 06 2016
    colorado
    those are the Mercedes rotors.
