Page 1 of 19 12311 ... LastLast
Results 1 to 40 of 750
    Veteran Member Four Rings avantagg's Avatar
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    OEM+ 2012 Phantom Black Avant Build Thread
    Specs:
    2012 Audi A4 Avant premium Plus S-line - 3.0T Swapped - B8.5 Competition Plus Facelift
    Mileage: 90k on body, 80k on DSG, 30k on motor.Estimated HP: 450 WHP
    Powertrain:
    Griptech 57mm Supercharger Pulley034 190mm Crank Pulley
    S4Matty Ported Supercharger Cerakoted Glacier Black
    APR Ultracharger
    APR IntakeRedstar Heatshielded Headers
    Miltek Resontaed Cat Back Exhuast
    GESI G-SPORT High Flow Cats
    Merc Racing C7 S6 HX w/ Divorced self bleeding Coolant ReservoirCWA-100 coolant pumpAEM Water Methanol Injection Kit w/ Prometh 970cc nozzle on Snow Hemi TB SpacerRS Red Cerakoted Engine Covers
    Suspension/Wheels:
    Bilstein PSS10
    H&R Sway Bars
    Moog Sway Bar Endlinks
    034 Billet Strut Brace
    Eurocode Alu Kruez
    034 Motor Mounts
    034 Transmission Mount Insert
    034 Rear Diff Mount Insert
    034 Rear Carrier Mount Insert
    OEM RS6 20x9.5 ET 36 Titantium Peelers with 255/30/R20 Falken Azenis
    OEM RS5 Front Calipers and 380mm Girodisc Rotors
    OEM S6 Rear Calipers w/ 356mm R1 Concepts Slotted Rotors
    Exterior:
    Full Facelift 2016 B8.5 Competition Plus Front Bumper w/ European Avant Rear Bumper
    OEM Front PDC Retrofit
    OEM Auto Fold Mirrors w/ Ecode Asymetrical Blindspot Glass
    Custom Black Out OEM Ecode headlights w/ ZKW-R Clear Projector Lens + OSRAM CBB D3S Xenon Bulbs
    OEM European Facelift LED tail lights
    LED reverse bulbs
    LED plate lights
    Hoen Endurance H11 fog bulbs
    OEM Black Roof Rails (as part of black headliner conversion)
    3M Matte Black Window Trim Vinyl
    RS4 Replica Hatch Spoiler
    Thule Aeroblade Edge Roofrack
    35% Tint Front / 20% Rear & Hatch
    Interior:
    OEM Black Headliner Conversion
    OEM A5 Instrument Cluster Retrofit w/ B8.5 Facelift S4 Needles
    OEM RS5 Piano Black Instrument Surround
    B8.5 S4 Alcantara Interior w/ Rear Sunshades
    OEM 3G Plus MMI Conversion
    OEM RS5 MMI Control Panel
    OEM RS4 Flat Bottom Steering Wheel
    OEM RS4 Door handles
    OEM B8.5 Facelift S-Line Air leather shifter
    OEM RS5 Pedals
    OEM Piano Black Door and Center Console Trim
    OEM B8.5 Facelift Switches
    OEM B8.5 Facelift Air Vents
    OEM B8.5 Facelift HVAC Panel
    OEM S4 Leather Door Armrests
    OEM B&O Speaker Covers
    OEM Ambient Door Pocket LED lighting (DavidB8 Mod)
    OEM Underseat StorageOEM European Trunk Luggage Rail System
    P3 Vent Gauge
    Precision LED interior kit
    Audio
    Audison Bit DMI*
    Audison AP1 D 500watt Mono Sub AmpAudison AP F8.9 Bit 1200watt 6-Way Amp & DSPHertz ML 280.3 TweetsHertz ML 700.3 MidsHertz ML 1800.3 Woofers
    Image Dynamics IDQ10 V.4 D2 Sub
    Bayser B8 Avant Hidden Sub Enclosure
    Custom OEM look Bass Remote Knob
    Sound Deadened all doors, rear lockers and spare tire well
    BEFORE/AFTER
    More Pics
    S4 SWAP
    WINTER MODE:
    2012 B8 Avant (3.0t Swapped)
    034 DP | APR UC | Ported Charger | Mertop Headers | Milltek Resonated Exhaust | Bilstein PSS-10 | Alu Kreuz | CR-15 | H&R Sways | 034 Inserts | Ecodes | A5 Cluster Swap | 3G+ MMI | RS4 FBSW | Black Headliner Swap | BUILD THREAD
    Senior Member Three Rings petraman's Avatar
    Apr 26 2016
    Columbus, OH
    Very clean!
    Hey, I'm thinking of using almost your exact suspension setup (although I was planning to go with eurocode sways and endlinks, but close enough). Would you recommend it? The stance is perfect!
    Established Member Two Rings HenrikMeister's Avatar
    Apr 03 2016
    Norway
    Very nice avant indeed! Well done
    Senior Member Three Rings NLPed68's Avatar
    Jan 21 2016
    1968 Chevy C10 Restomod, 1974 Bronco Crawler
    Hayden, AL
    Great looking Avant!
    Oct 03 2007
    New York
    Any plans to add a TTRS wheel to finish off the interior? Really nice OEM+ looking avant you've put together. I would black out the window trim too. But really nice package!
    AKA: Eightx3
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Quote Originally Posted by petraman View Post
    Very clean!
    Thanks! Yes the sway bars make a big difference in the handling. I went with those first and just dropped the car last week. The handling went from tight (on the OEM sport suspension w/sways and AK) to REALLY tight and noticeably stiffer but not harsh. You feel everything in the road, but it's not jarring. I think the B12 ride height is perfect for a daily driver and couldn't justify the extra cash for a set of coils. The only thing I didn't do were the end links. I have heard they will tighten things up just a tad more. Hope this helps!
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Quote Originally Posted by Matt C View Post
    Thank you! Yes, the plan is to find a S-line flat bottom wheel and piano black instrument surround for the cabin finishing touches. I have also looked into blacking out the window trim. I had originally wanted to use OEM parts, but the cost would be stupid expensive and hard to find. I think i might have them wrapped in matte black vinyl this summer and maybe leave the roof rack bright to match the front splitter and fog rings.
    Senior Member Two Rings meisladrs's Avatar
    Jul 14 2013
    Huffy 10 speed And rollerblades , dead hipsters
    Denver ,Co
    Good looking avant mine is almost the same
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Thanks! Looking good as well. What rims are those?
    Oct 03 2007
    New York
    Quote Originally Posted by avantagg View Post
    While you're taking suggestions I'd paint the mirrors (or wrap them) to match the splitter and strip the badges. It is amazing how the shifter update really makes the interior look that much newer. <3 avants
    AKA: Eightx3
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Looking fantastic!! Great work!
    Active Member One Ring DasKombi's Avatar
    Mar 08 2016
    2015 Audi A3 8V 2.0 Quattro
    Dublin, CA
    Love your Avant! Looking for some oem LED heads and tails like yours to switch mine out. Where did you get yours from?
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Quote Originally Posted by DasKombi View Post
    Thank you! All of the lighting was sourced second hand through ebay.de I used oem parts from GAP for the tail light adapters and followed this How-To for the tail light install: http://www.audizine.com/forum/showth...aillight-howto
    Here are the parts #'s to make your search easier:
    Xenon Headlights (non-adaptive):
    8K0 941 003 C
    8K0 941 004 C
    LED Tail lights:
    8K9 945 096 D
    8K9 945 095D
    8K9 945 094 E
    8K9 945 093 E
    Veteran Member Four Rings ebi718's Avatar
    Oct 29 2011
    2009 A8 L
    Brooklyn, New York
    Well done!!
    Sent from my SM-N910T3 using Tapatalk
    '10 A6 3.0T Quattro Avant Prestige Phantom Black Pearl Effect (Link)
    '09 A8L Phantom Black Pearle (Link)
    '13 A7 Quattro 3.0T Phantom Black - SOLD
    '07 A6 3.2 Quattro Avant S Line - SOLD
    Senior Member Two Rings ChicagoDave's Avatar
    Oct 21 2015
    Chicagoland, USA
    Subscribed. Well done. Love the OEM look.
    2012 A4 Avant - Brilliant Black :: Zisa LED Lighting :: Awesome Floor Mats :: Warning Triangle :: Total Newbie
    Retired - 2002 VW Passat GLX w/ 4Motion :: 14 Years and 202,000 miles
    Retired - 1995 Chevy Impala SS :: 5.7L LT1 V8 :: Dark Cherry Metallic :: Fell apart at 98,000 miles
    Established Member Two Rings geojt72's Avatar
    Sep 04 2013
    alfred me usa
    nice,
    Established Member Two Rings John44's Avatar
    Jan 07 2015
    1992 MKII Golf 1.8L 16v - SOLD, 2001.5 MKIV Golf 1.8T, 2011.5 A4 Avant Premium +
    SLC
    Love all the OEM parts... Looking forward to seeing more updates
    JPAutoworks.com
    ** 2011.5 A4 Avant Premium + **
    My other build...
    Veteran Member Three Rings CloseEncounters's Avatar
    Mar 04 2012
    2020 Navarro Blue SQ5, 2019 Black Q5 Prestige & Cannondale 27.5 'Beast of the East' MB.
    Tucson, AZ
    Don't mind if I play along boys...she still brings a smile to my face each time I get in :)
    2020 B9 SQ5
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Quote Originally Posted by CloseEncounters View Post
    Yes! I saw your car when I first joined and it was also a source of inspiration for my build. Love what you have done with it. Thanks for sharing!
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Nice car and build, what more can i say
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Quote Originally Posted by Gunnark100 View Post
    Thank you Gunnar, really appreciate your help with those tail lights!
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Picked up a set of B&O speaker covers from another member parting out an S4 last week. It's a simple little upgrade but I think it complements the black/aluminum accents in the interior really nicely.
    Veteran Member Three Rings redavant's Avatar
    Jun 17 2014
    California - Bay Area
    A really nice transformation and tastefully done! Look forward to future updates.
    Misano Red 2011 B8 A4 Avant S-Line Prestige
    My Build | AvantGarde M510 265/30/19 | RS4 grill | Euro Tail Lights | RS6 Steering Wheel | S-Tronic shifter |
    Mar 04 2012
    Tucson, AZ
    Pleased to hear mine was an inspiration as others have also inspired me. Really Love what you've done with yours. I was impressed enough to post pics of how similar mine looked, glad you did not mind me sorta 'jacking' your tread :-) I'll surely keep following your build.
    Established Member Two Rings X Y Z's Avatar
    Mar 20 2013
    SM610, AE86, FJ60
    Portland, Oregon
    Nice wagon! I have a good portion of the same upgrades on my Avant as well, good taste sir
    Mar 28 2009
    Minneapolis, MN
    I love what you've done. Subscribing for more. Keep it up!
    Veteran Member Three Rings khj677turbo's Avatar
    Dec 25 2007
    Tampa
    Always nice to pop in and see someone doing a car solid oem+ work.
    Current: 13 A4 P+ Sport, K04 etc, 18 SQ5
    Gone: 04 A4 1.8t USP 6-speed Avant
    Gone: 00 A4 1.8t K04'd
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Quote Originally Posted by X Y Z View Post
    Thank you, sir! They are fun aren't they :)
    Thanks man, I'll keep you updated on the black headliner progress. Reaaalllly want to do make this a reality and do it using OEM parts.
    Quote Originally Posted by khj677turbo View Post
    Cheers!
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Shaved the hatch today. Liking the no badge look.
    Mar 04 2012
    Tucson, AZ
    Awesome!! The no-badge looks really makes the back complete and I do love your LED tails
    Jun 17 2014
    A nice look! Great clean view :-)
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Thanks man! Seeing how clean yours looked gave me the motivation to strip them off. And the LED tails really update the rear end of the car.
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Found a deal too good to pass up today. I've taken the leap and plan on converting the headliner and upper interior to black. It's going to take some time to assemble all of the parts, but this is a big chunk! More to come.
    Mar 28 2009
    Minneapolis, MN
    That is a hell of a score. How did you find all that in one place? Only question I have is, did you make sure to get the right D-pillars? There are different part numbers for cars with or without B&O stereo because there's a speaker in the D-pillar.
    Also, what is the piece in the bottom center, and the two curved pieces in the top right?
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    I couldn't believe it myself. Found on German eBay for 269 Euro. My car came with the non B&O D-pillars, so once again a lucky score. It even includes the 2 little sun visor clips!
    I'm trying to figure out what those extra parts are. I've never seen them before. I think one might be a rear view mirror cover for a different style mirror, maybe one with lane assist if that exists? I have no idea what those little curved pieces go to.
    All the parts seem to be in excellent shape. He had a bunch of photos of the individual parts in the listing. I've got the rear view mirror and front and rear light covers already in the car. Just need to find a sunshade!
    Mar 28 2009
    Minneapolis, MN
    This one was on eBay recently. I'd contact the seller to see if it actually sold.
    https://www.ebay.com/itm/121920496862
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Nice! I will look into that. Thanks for the heads up.
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Ok, think I figured out what those curved pieces go to. I believe they cover the rear hatch hinges. I never even thought about needing those parts so I'm glad you pointed 'em out!
    Mar 28 2009
    Minneapolis, MN
    Ha, you're right! I don't think I've ever seen those pieces in anything but black, but at least you've got them now. Do you have all the grab handles you need or are you still needing two more? I know a guy with a few he might be willing to sell.
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    I am currently looking for two rears, if @avantagg doesn't need them.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
