Over the past month I've noticed my coolant gauge struggling to get warm at the 12-oclock position. Sometimes it will fire up and get to the 12-oclock position in 5 minutes, and other times I will be driving for 10 minutes and it will still be sitting at the 3/4 mark:
The top coolant sensor (green) was replaced a few years ago, and as a sanity check, the bottom grey radiator coolant temp sensor was also replaced approximately 2 weeks ago. However, last night I was driving about 30 minutes on the highway and saw a similar situation to the above screenshot. The heater was on, and the coolant temp gauge stayed at the 3/4 mark.
I came home scanned my car last night and found the following codes:
Since the radiator Coolant Temp Sensor was replaced less than a month ago, does the above codes indicate that my fan control module is on its way out? TIA.
Thanks,
Asif
