Parts list here: Here is what I remember from 6+years of parts gathering.
Eurospec forged crank 12.5 kg 5lbs lighter than stock spun balanced for smoothness
IE forged rods end balanced rifle drilled for improved lubrication to main bearings 1g difference btw heaviest and lightest. 4340 Chrome Moly Steel.
JE forged pistons oem CR 9.25 heat resistant top (gold) and slip side (black) coatings
ARP rod bolts, mains bolts, head bolts, crankshaft bolt, camshaft bolts, flywheel bolts, clutch pressure plate bolts, fluid damper bolts
Carrico bearings for pistons and OEM for crank yeah I know should have went with coated but failures here are rare and due to lack of maintenance.
Forged main caps line bore was required. USA 4140 alloy steel assists in providing extreme rigidity to the main bearing and crankshaft.
Thrust washers - OEM
Spec stage 3+ flywheel 16lb lighter spun balanced with clutch plate assembly for a smooth launch and break-in experience.
EKagrip flywheel/crankshaft friction shim disc
Audi metal clutch slave conversion & stainless steel clutch line.
Fluidamper pulley
All new engine sensors throughout
Head ported and polished 5 angle valve work 1mm over valve in/out openings, intake ported for AEB manifold
Ferrea valves and high-rate springs
Autotech intake cam. Yeah I know its a mild 195 deg cam. Lift: 7.85mm (0.309) Duration: 195 at 0.050 lift. The IE cams launched with a huge success but I bought it years ago on a memorial day sale. I have to draw the line somewhere for how much to spend and how fast I really want to go. OEM exhaust cam. I looked everywhere and at everything from Schrick, to a British company I forget at this point, to the Eurospec stuff, to the Cat cams AND I just want a fast 1.8t; I don't want to race or compete against anyone - I just want a car that is rapid and stealthy. Sort of like my 360+hp V70R.
New oil pump tensioner and chain
New VVT solenoid actuator and cam chain
IE dowel pin timing gear/sprocket kit (broke drill bit included with kit and 2 more drilling the crankshaft end). Shows the age of my build as IE now offers a press-fit billet solution with 2.0FSI 6 bolt Fluidamper solution to keyway shearing.
Prepped Block
Underside of block being disassembled with OEM crank bushings.
Assembled Lower Block and Portion of the Cylinder Head with Ferrea Valvetrain
ARP bolts on rods and forged main bearing caps.
Ring Specs
Forged Main Bearing Caps
JE 2618 Forged Al - T6 High Tensile Strength Coated Dome and Skirts
OTHER MODS:
Apikol>Snub/Diff S4 mounts;APR>ExhTIP-TB hoses;AWE>DV;JHM>ShortShift-the works
Misc>Wheels 18x8x9 235/265;HSport>S4 bars;TT225;BoschF6DTC;
Carbonio>V2+V6Intake;HFC;Podi>P2;ATP>mani;GPop>K04
STaSIS>328/305mm,40/60,SL
