Mod List:
Engine:
APR K04
APR V3.1+ Tune Running 93 Octane
ECS R8 Coil Packs
NGK Iridium IX BKR8EIX Spark Plugs Gapped @ .024
APR Carbonio Intake
ECS Intake Pipe
EuroCode FMIC Kit
034 HFC
Stratmosphere 90 Degree O2 Spacer
STaSIS Cat Back Exhaust
CTS Catch-Can
ECS R8 Oil Cap
ECS Black Washer Fluid Reservoir Cap
ECS Black Coolant Cap
ECS Oil Dip Stick
Wheels, Suspension & Brakes:
Velocity Motoring V708 RS4 19x8.5 ET38
ECS Audi OEM Wheel Center Caps
Continental Extreme DW Tires 255/35/19
ECS Tuning Spacers 5mm F&R
Eibach Pro Kit Springs 1.4"F & 1.2"R
Koni Sport Shocks
Ultra Racing Upper Strut Bar
H&R F&R Sway Bars
034 Transmission Mount Bracket
Apikol Differential Front Mount (Red)
ESC Differential Rear Mounts
ECS Q5 Brembo 4-Piston Big Brake Kit (Front)
ECS 345x30 Slotted Rotors (Front)
Posi Quiet/Centric Ceramic Brake Pads (Front)
S4/RS Calipers & Carriers (Rear)
ECS 330x22 Slotted Rotors (Rear)
Akebono Ceramic Brake Pads (Rear)
Stoptech Brake Lines
Interior:
3G MMI Retrofit
Color DIS Retrofit
B8.5 Climate Control Retrofit
Podi Boost Gauge
RS5 Pedals
Face Lift S-Tronic Shift Knob
Face Lift S-Line FBSW w/Paddle Shifters
Face Lift Seat & Door Switches
3M Brushed Black Metallic Trim Wrap
LED Interior Bulb Swap
Trunk Lid Warning Triangle & Bracket Kit
30% Front & 20% Rear Tint
Exterior:
S-Line Front & Rear Bumper
S-Line Side Blades
S-Line Rear Valance
S4 Grille
ABT Trunk Spoiler
ECS Plate Filler
S-Line Scuff Plates
S-Line Badges
Trunk Lid De-Badged
LED License Plate Bulbs
VAG-COM Coding:
Ross-Tech HEX-USB+CAN Interface Cable
Disabled Turn Signal Winking
Gauge Needle Sweep
MMI 3G Hidden Menu
Remote Window Roll Up/Down
Battery Level Display On MMI
Enabled DVD MMI Movie Playback
Oil Consumption:
Stage I - Completed June 2016
Stage II - Completed October 2016
Germany May 2010 - USA July 2015
**I am not responsible for anything you do to your car by following this thread. If you do not feel comfortable doing mods yourself then I strongly recommend you have a shop perform this for you.**
If you can't see all of the pictures, just install the hotfix for photobucket into Firefox or Chrome:
Firefox: https://addons.mozilla.org/en-US/fir...otobucket-fix/
Chrome: https://chrome.google.com/webstore/d...=1525177480008
