Page 1 of 9 123 ... LastLast
Results 1 to 40 of 327
    Oct 09 2014
    Norway
    (Al3k) Round 2, EFR 6758 .85 build
    Got my car nov 2014, it only had a stage 1 tune and a cone filter.
    Started first with a K04 build and now EFR 6758 external gate v-band build.
    Round 2:
    -EFR T4 Twin scroll housing (installed)
    -Quick spool valve (Sound Performance) (installed)
    -Turbosmart waste gate actuator (installed)
    -T4 exhaust manifold conversion (installed)
    -JHM lightweight flywheel + clutch (installed)
    -Wastegate delete exhaust manifold (installed)
    -EFR 6758 .85 Vband (removed, switched to T4 Twinscroll .80 housing)
    -Neuspeed 2.75" catback exhaust (installed)
    -Tial MVS 38mm external wastegate (SOLD)
    -AR Design tubelar vband manifold (installed)
    -AEM Water/meth kit (SOLD)
    -Front spring lowering perch (installed)
    -Torqbyte_ PM3 LPFP Driver (installed)
    -Torqbyte_ CM5-LT LPFP Control with map + rpm signal (installed)
    -TTRS LPFP (installed Mar. 2017 132k km)
    -EFR Speedsensor (installed)
    -HPFP Stud kit (installed)
    Round 1:
    -Spulen K04 Turbo (SOLD)
    -GFB DV upgrade (SOLD)
    -S3 injectors (installed)
    -Evolution Racewerks FMIC and steering cooler (installed)
    -Autotech HPFP upgrade (installed)
    -ECS Tuning Flapper delete kit (removed)
    -RS4 Fuel pressure release valve (installed)
    -NGK Iridium BKR8EIX plugs (installed)
    -New red ignition coils (installed)
    -Spulen PCV Adapter (installed)
    -Spulen Turbo inlet hose (installed)
    -Ultimate timing belt kit (installed)
    -New South Column Pod (installed)
    -New South Boost gauge (installed)
    -Torque Solution snub mount (installed)
    -Eurodyne Maestro Tuning Suite (installed)
    -Oil catch can(ADD W1 with 10AN fittings) (installed)
    -Spulen PCV delete catch can adapter (AN10 fittings) (installed)
    -3bar Bosh MAP sensor (installed)
    -034Motorsports 3" testpipe (installed)
    -10AN oil return line and adapter (installed)
    -ECS tuning polished oil filter housing (installed)
    Service:
    -Oil filter + air filter (last change @ 9.2018)
    -Oil (last change @ 09.2018)
    -Coolant (last change @ 9.2018)
    -Timing belt + Serpentine belt + belt tensioner + idler pulley (installed 30.jan 2015, 120k km)
    -Cam Follower (installed 8.2017 136k km)
    [ B7 2.0TFSI Avant Quattro 07 ] [ Maestro tuned ] [ EFR 6258 .80 Twinscroll QSV ] [ S3 injectors ] [ Autotech HPFP ] [ ER FMIC ] [ Neuspeed Catback ] [ ARD V-Band Manifold ] [ TTRS LPFP + Torqbyte PM3 + CM5-LT ] - Build Thread
    Oct 09 2014
    Norway
    Oct 09 2014
    Norway
    Oct 09 2014
    Norway
    Veteran Member Four Rings Andrew149's Avatar
    Apr 19 2009
    Modesto/CA
    Looks like a fun build! Your off to a good start. I probably would of went with the jhm testpipe and jhm intercooler though.
    2012 Audi A6 3.0t
    2019 GTi 2.0t 6 speed
    2013 Touareg VR6
    Oct 09 2014
    Norway
    yeah me too, I didnt know about JHM when I ordered the parts but Im definitely getting the JHM clutch kit soon :P
    Veteran Member Four Rings ericpaulyoung's Avatar
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Nice lost of upgrades!
    EPY
    Epy
    Veteran Member Four Rings FraggyA4's Avatar
    Mar 03 2012
    Jeep Comanche
    Thief River Falls, MN
    Quote Originally Posted by Andrew149 View Post
    A test pipe is a test pipe. JHM is great and has nice craftsmanship, but so does 034. I went with 034 because they saved me almost $100.
    Parts looks good, do you plan to rebuild the engine at anytime?
    -Chadwick
    FULLY BUILT ENGINE!
    Jun 27 2011
    No rods??
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Mar 03 2012
    Jeep Comanche
    No rods??
    I was thinking the same thing. It's doable without them but you will not be getting the full potential of the K04.
    -Chadwick
    FULLY BUILT ENGINE!
    Oct 09 2014
    Norway
    I was thinking about rods at first but I dont have the resources to do it myself right now, there is none tuning shops in my town just regular car service shops and it would probly cost more than a new engine to get it done here.
    Im gonna do some more research to see if theres a way to get it done, or I might try to get a second engine so I can experiment myself and get someone to swap it for me.
    I hope as long I dont do too agressive timing and mild boost in the lower rpm range I will be good for now
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Looking good op! Let me know if you have any questions about our parts!
    Quote Originally Posted by FraggyA4 View Post
    Not necessarily true. A 2" test pipe will not perform like a 3" test pipe. A 3" test pipe with a 2" ID DP flange will not perform like a true 3" test pipe. Our JHM 3" Test Pipe was designed for optimal exhaust flow and has been used on multiple record setting 1/4 mile runs
    Mar 03 2012
    Jeep Comanche
    Quote Originally Posted by Jake@JHM View Post
    034's a true 3" test pit and if the flange isn't completely open I'll take the die grinder to it. Stop trying to make me feel bad Jake. I'm a modder on a buget. But in all seriousness it really is the same. Optimal flow you may have but your flow loss is so minimal in most configurations that you will never notice it. I'll even bust out some thermal dynamics if I have too.
    -Chadwick
    FULLY BUILT ENGINE!
    Oct 09 2014
    Norway
    I meassured it right now, and its close to 3" ID
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    You don't need an upgraded LPFP, if you ever do replace it, just stick with the A4 one, the rs4 is the same, and teh TTRS which is the only upgrade that is OEM is just a pain in the dick.
    Aug 31 2011
    Lathrop
    Not trying to make you feel bad, 034 makes great products! I just have seen bad test pipes out there (random companies and ebay) which is why I quoted that specific part of your post :)
    Mar 03 2012
    Jeep Comanche
    Quote Originally Posted by al3k View Post
    Go at it with a die grinder and get that last .062" off
    -Chadwick
    FULLY BUILT ENGINE!
    Oct 09 2014
    Norway
    Thank you, I was a little bit unsure about that
    Mar 03 2012
    Jeep Comanche
    Totally agree!
    -Chadwick
    FULLY BUILT ENGINE!
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Yup the a4 pump will flow plenty, I've been running it on my gtx2867r without issue. I recently bought a TTRS pump because I wanted to flow more fuel for e85 tuning, and it was not a fun swap. You would expect the parts to be completely interchangable, but they are not, the basket is different the level sensor is different, the fuel line connections are different, the basket mounting points are different. Not a fun project lol.
    I'm exciting to see what you can do with the k04 though. I would definitely put rods on the christmas list though.
    Aug 31 2011
    Lathrop
    [Insert plug about JHM running low 11s on stock RS4/A4 LPFPs]
    Oct 09 2014
    Norway
    hehe, yeah right! Im on stock exhaust anyway for more stealthiness
    Mar 03 2012
    Jeep Comanche
    LMAO!
    -Chadwick
    FULLY BUILT ENGINE!
    Aug 31 2011
    Lathrop
    LMAO!
    Haha , I need to just get all my responses into a text document so I can cut and paste all day
    Mar 03 2012
    Jeep Comanche
    Just make a meme and post it every time something comes along
    -Chadwick
    FULLY BUILT ENGINE!
    Oct 09 2014
    Norway
    Is there any known science behind when these OEM rods break? I really want to push the K04 to its boost limits, I want to peak at 20-22psi, Im thinking about retarding the timing and boost before 3000rpm to have a conservative tune.
    I havnt done so much research on this part yet, I will take it in small steps in the beginning to see how it behaves, its my first time to install a turbo kit and tune a turbo engine so Im not gonna rush it.
    Mar 03 2012
    Jeep Comanche
    Basically the thing that the K04 does it produce a ton of torque really quickly, so you need to retard that until the engine gets moving. Then you can run pretty high boost. There is someone on here running stock rods with a K04. Mec knows quite a bit about it too.
    -Chadwick
    FULLY BUILT ENGINE!
    Jun 27 2011
    That. The massive torque spike is what kills the rods. If you can ramp up boost smoothly until above 3000rpms to flatten off the torque, then you'll probably be fairly safe with OEM rods. The trick is doing a conservative tune like that.
    -CP
    2017 Q7 3.0t
    Aug 31 2011
    Lathrop
    Poor tuning also kills rods. You get guys who are like, I needz all the timings and all the boosts for alll torks!!!
    Oct 09 2014
    Norway
    It takes away some of the fun part but that would be the cons for not doing rods. It will be more fun than my k03 at least for a few weeks until my brains G-trims get fully adjusted and I want to do a BT setup :P
    Aug 31 2011
    Lathrop
    BT setup on your Super Rare B7 Avant will be super sweet!
    Oct 09 2014
    Norway
    Super rare? Is that sarcasm or am I missing something here?
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Lol you must have a blue avant. I can't tell since I'm on tapatalk but it's a joke that blue avants are super rare
    Oct 09 2014
    Norway
    aah havnt noticed that here, audi its not so common here, we dont even have a offical audi dealer in this city. iam probly the only one with a 2.0 tfsi engine, ive only seen a4 with tdi and a few 1.8T b7 a4s.
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    So then you do have a super rare car! Lol
    Oct 09 2014
    Norway
    hell yes, even when i was searching for a used b7 2.0tfsi quattro with manual gear box there were only two cars availible in the whole country!
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    welcome!!!! BT club is growing, i fucking love it!
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    That's what I liked about RAI's it was a 4" (cone style) that tapered to a 3".
    OP good looking build. Seeing the ER FMIC, reminds me of missing out on picking one up when it was 50% off.
    W/M: Quality that won't break the bank: http://www.alcohol-injection.com/en/173-diesel
    SnowPerformance and Coolingmist are also legit options, just more expensive. And of course Aquamist but that's $$$$!!!!!
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Oct 09 2014
    Norway
    nice, where to you usualy get the methanol or alcohol fluids?
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    you are going to enjoy the K04. It always puts a smile on my face when I hit the pedal
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
