Results 1 to 40 of 57
    Veteran Member Three Rings KidGT's Avatar
    Oct 28 2008
    '00 S4
    The Mile High City
    Noah vs. the Avant: Welcome to Hell (Long)
    So back in June my sedan was totaled after some bitch rear-ended me. That car was perfect. Paint was money, no accidents, single owner (Dad of childhood friend), no winters, all maintenance. Just perfect. Decided I wanted to stick with a B5, but I wanted an avant. After searching for a month and almost getting scammed by some guy on Vortex, I found one.
    The car was in Boston.
    I was worried about buying a car from so far away again, but turns out he lives in the same area as one of my good friends from college. He checked it out for me, and spoke with the seller (an AZ member, car was in the classifieds). Everything seemed legit. Started setting things up for a PPI, but the shop I wanted it done at was about an hour and a half from the seller. He suggested a shop closer, and after finding nothing negative about them on any of the Audi/VW/BMW forums. Had the seller take the car in and my friend picked up the report,
    Everything seemed like I was finally catching some luck. Bought a ticket and flew out to buy it. Looked like this when I picked it up,
    Said bye to my friends, and started the drive from Boston back to Denver. And that's when things started going downhill...
    Now for the sake of full disclosure, I am now the 9th owner of this particular car. I wouldn't have bought it, but the Carfax came back clean accident wise, and the ownership trail lead me to believe there were really only two prior owners. The car was actually originally purchased from a dealer here in Denver, so I looked at it like I was bringing the car home after a hard life on the east coast.
    I immediately regret this decision.
    About 3 hours into the trip I had to mash on the brakes to avoid some crap on the highway. The wheel shook so hard from the vibration it nearly ripped out of my hands. So, at least one of the discs was warped. If you'll recall, the PPI I had done made no mention of this, actually stating the brakes were checked out and were fine. Great...
    I started noticing more stuff. One of the taillights was cracked, rear wiper didn't work, tint was so old it was purple and peeling. You know, the little things that aren't immediately apparent when you buy a car until you live with it for a while. But, it was minor stuff. Made it to Ohio, day 1 of 3 complete.
    Day 2 didn't start well.
    Almost totaled it less than 24 hours after buying it when some bitch in a Range Rover decided stop signs didn't apply to her, and nearly t-boned me. Also noticed that on a cold morning start the power steering made a lovely metal on metal grinding sound until the car heated up. The aftermarket stereo would also randomly lose two speakers after cornering. Still, the rest of the day was fairly uneventful, and I was on track to make it to KC by the early evening. Then I hit Missouri...
    Now I've done the drive from Ohio to Denver 3 times previous, and every single time something happens in Missouri, and I lose a shit ton of time. This trip was no different. It monsooned for about 3 hours straight, and I only covered about 15 miles in that time. I was now not going to make it to KC until well after dark. Night came and I turned on the headlights. Nothing.
    Pulled off at a trailer stop in BFE Missouri. The headlights were pointed straight down, and one of the bulbs was that weird color they turn right before they burn out. Fortunately, I had brought my vag-com cable with me. Checked for codes. Nothing. I knew the battery had been replaced, so I tried to run adaptation. Got the passenger side to raise, but the drivers side wouldn't move. Not only was the motor broke the manual arms were broken, and it couldn't be adjusted. I was getting enough light from the passenger side, so I said fuck it. Only when I restarted the car and turned on the lights it had dipped again. Checked for codes in the specific module this time. Auto-level arm ground to fault. Brilliant. Go to manually adjust the light again. Only this time, while the motor worked the manual arms were also broken, and I couldn't raise it. This of course was also mysteriously missing from that PPI I had done.
    Totally fucked. I was wondering what else was wrong with this thing.
    I couldn't drive anywhere, it was already late, and I was nowhere near a hotel. So I slept in the car. I attempted to sleep for about two hours before realizing it wasn't happening. Said fuck it and took off from outside Columbia around 1am. No traffic to be found, so I could drive with the high beams on. And since there was no traffic to be found I fucking caned it. Ripped on 7 Red Bulls and pure adrenaline, I made it back to Denver at 9:30am. It usually takes about 9 to get from KC to Denver, so there's that. I had been up for about 30 hours straight at this point, so I went to sleep for about 20. When I got up is when the real fun began.
    Already freaked about it, I called my usual shop here in Denver to do their own inspection. This is what they came back with,
    Yeah...
    Among the surprises; all 4 rotors warped, pads nearly dead, valve covers/cam seals leaking heavily, no idea when the brake fluid had last been changed, same for the power steering fluid, accessory belt was on its last legs, etc, etc. I also noticed the front bumper had been repainted. Poorly. I mean so bad Maaco would have been embarrassed. Basically, the only things that properly worked on the car were the cup holder(!?!?), and the rearview hadn't leaked (but of course didn't autodim).
    I distinctly remember having a PPI done on this car...
    2001.5 Candy Blue Dipped S4 Avant
    Stage 2+, APR everything, Saved from idiots, and resurrected.
    2004 Touareg V8
    Parents never us it, so I kinda just stole it...
    Oct 28 2008
    '00 S4
    The Mile High City
    Fortunately I still had my parts car, so the tear down began with the interior.
    Before,
    So that's why the window didn't work...
    Small victories...
    Turns out the stereo was wired by a toddler, but after much difficulty I fixed it.
    After,
    Things got worse the deeper I got into it.
    2004 Touareg V8
    Oct 28 2008
    '00 S4
    The Mile High City
    Since I couldn't trust that the timing belt service had been done I started with that. The alternator went out the night before I started everything.
    Go to take off the bumper. Noticed it wasn't lined up. There was also this,
    Yup, zip tied fog lights.
    And as you can see from the over-spray on the IC shrouds I don't even think they took the bumper off to spray it. I found out why a minute later. First bolt came out of the bumper unwillingly. The second one not so much. It just spun and spun. Ended up having to wiggle a bunch of extensions through the bumper and unbolt the bumper support from the lock carrier.
    I then had to cut the rebar so I could slide the support off the bolt.
    Whatever the bolt connects to inside the rebar had broken away and the bolt would just spin.
    It got worse.
    The lock carrier was broken and cracked in several places. It had also been repaired poorly. Fears confirmed. The car had clearly been in an accident.
    Also, something had been living in the engine bay.
    The rest of the next week went pretty much as you'd expect. Every time I went to take a bolt out it stripped, or was missing. Bolts were different sizes than what they should have been, or the hardware was completely wrong for the part. It was a total clusterfuck.
    Power steering fluid.
    Plugs.
    Air Filter.
    Puddles of oil from removing the drivers side IC.
    Wagner ICs installed.
    Installed headlights from my old car.
    Drivers side needed the tabs fixed.
    Lock carrier was broken on the passenger side where the rear bolt for the headlight goes. Pull clip off old car, plastic weld in place.
    Engine Bay before.
    After.
    2004 Touareg V8
    Oct 28 2008
    '00 S4
    The Mile High City
    Now for the brakes. Decided to upgrade while I was in there.
    Tore them down for cleaning and painting. One came apart just fine. The other not really. One of the bleeder screws was over torqued and cross-threaded, stripping out the threads in the caliper. Attempted to helicoil and re-tap. Unsuccessful.
    Bought another caliper because God hates me. And the USPS lost my rear rotors in the mail for a week making them 2 for 9 on actually delivering packages people ship me.
    Finally get stuff and install it.
    Brake fluid was flushed out with a power bleeder. It was jet black.
    2004 Touareg V8
    Oct 28 2008
    '00 S4
    The Mile High City
    On to the exterior.
    The driver's side door didn't line up or close correctly and was rusted. Swapped out the door from my parts car. Noticed some damage to both passenger doors. Said fuck it and swapped all for doors from my parts car. This created a new problem.
    The car hadn't been cared for. Inside and out.
    Look at this picture.
    That door is from my old car. Notice the difference in the paint from the door to the side skirts and fenders. Decided I was going to Plasti-dip the car. I had to remove the roof rails first. Found this hiding underneath them on both sides.
    This was the story along the length of the roof. There were also several other spots of rust along the body. Took off the bumper and sideskirts. Sideskirts were attached at the front with wood screws on the passenger side. Sanded everything down and went to work.
    Base coat.
    Top coat.
    Roof rails dipped.
    Complete.
    Winter mode.
    Wheels, also dipped.
    And that's how she stands. There's more to be done, but its winter and I really just don't care anymore.
    2004 Touareg V8
    Senior Member Three Rings lditty's Avatar
    Oct 29 2011
    2014 Suzuka Gray RS7
    USR NJ
    Wow nice job!
    2014 RS7 Suzuka Gray
    Aug 06 2013
    2002 s4 6sp, 2003 6spd vette convertible and 2013 SRX
    IL
    Looks good!
    Veteran Member Three Rings zamflip's Avatar
    Sep 21 2010
    Bayliner 175, 2014 JGC wk2, and wifey s40
    Smithfield, ri
    LOVE your winter mode! Also lug bolts too..
    "Do I expect everyone to like my car? Not in the slightest, but I didn't build my car for anyone but me." --dre
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    tough break mate.
    i had a similar story, bought a car interstate and got it home to find it all fucked up and nothing like i had been told it was.
    2000 Achat S4
    Apr 01 2011
    B5 on jack stands
    charlotte
    Wow, you definitely did a great job resurrecting
    Established Member Two Rings Regal to S4's Avatar
    Jun 14 2013
    2000 Audi S4 5SP Auto, 95 Honda Accord EX, 98 Buick Regal GS, 98 Pontiac Grand Prix GTP
    Damn, and I thought I've had issues with my Audi. But then again, I did have to replace the engine and still haven't gotten to drive it since I bought it in January. Your car looks good now though.
    The mechanic who did the initial inspection. Hmmmm, pass.
    2000 Audi S4 - port+polished heads+intake, ceramic coated manifolds and ceramic coated + wrapped 3" downpipes
    98 Buick Regal GS - Cobra M112 Supercharger converted, P+P heads, built motor, XPZ cam, SLP headers, custom tune and too many other mods to list
    98 Pontiac Grand Prix GTP - roller rockers, headers, 3.25" pulley, high flow cat, Borla XP mufflers
    95 Honda Accord EX - Viper green inside + out; P+P heads, intake and throttle body; headers; high flow cat; manual vtec button
    Registered Member One Ring Bjammn's Avatar
    Dec 16 2013
    2005 Audi S4 1998 Subaru Outback 1999 Saab 9-3 (broken) 1998 Geo Prizm because race car
    East TN
    Holy Cow! That's a Nightmare story man! Let's hope the sailing is a little smoother with it from here on out.
    The fact our heart yearns for something Earth can't supply is proof Heaven must be our home. ~ C.S. Lewis
    Established Member Two Rings TedStriker's Avatar
    Mar 26 2013
    H-Town
    I feel your pain. My first S4 had been parked outside in Southern California for 10 years. To say that the paint was in bad shape was an understatement. Turbos were whiney, and tons of electrical gremlins. Yet the cupholder worked like a dream.
    2001.5 Santorin S4 AVANT
    I want to paint a mural of Houston for the kids, but I’m terrible at drawing swamp humidity
    Veteran Member Four Rings aaron1085's Avatar
    Jul 12 2007
    2007 2.0T A4
    NH
    So. I guess the question is: if the car came from an AZ member and was posted here on AZ, has there been another contact with said member regarding the lack of disclosure?
    You really are a wonder with tools and skills...well done brother!
    "The important thing is not to stop questioning. -Albert Einstein"
    "Treat everyone like a million bucks; and always have a plan to kill them"
    2007 A4: APR, STaSIS/Alcon, Avant Garde, Hankook, Ohlins
    Jun 01 2008
    Apopka, FL
    Like the details, those zinc wheel bolts really make the whole picture pop.
    Veteran Member Three Rings Tec_Nine's Avatar
    Sep 17 2012
    Riverside, IL
    Good job, really brought it back to its glory
    Jun 14 2007
    2000 S4
    Connecticut
    Damn.. Between you and Blmlozz you guys are restoration kings!
    Veteran Member Four Rings ggg20t's Avatar
    Sep 18 2008
    Pittsburgh, PA
    wow.. The car is really coming a long. Sorry you got screwed over so bad. The interior looks incredible!
    2001.5 Nogaro Sport b5 s4
    Jan 09 2009
    FL
    That's rough....sorry! You seem to be giving her one hell of a turn around though!
    Veteran Member Four Rings Austonwerner4's Avatar
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    You painted the car outside?
    Single Turbo on it's Way
    PM me for 17z and 18z Caliper Needs
    Established Member Two Rings Hamburger's Avatar
    Mar 13 2013
    1980 Honda cm400t cafe racer
    Dallas Oregon
    I love seeing awesome cars saved from the clutches of the evil neglectful dumb ******s of the world and brought back to glory. well done sir, keep us posted and your progress!
    Aug 23 2012
    Chicago
    Sorry to hear about the horrible buying experience, unfortunately we live in a very dishonest world.
    But, looks like you did one hell of a job on it. Awesome work, car looks great! Enjoy!
    Veteran Member Four Rings ebi718's Avatar
    Oct 29 2011
    2009 A8 L
    Brooklyn, New York
    Wow ....quite a restoration job!! Hats off to your "wrenching skills"!! . Any feedback from the AZ member who sold it?
    '10 A6 3.0T Quattro Avant Prestige Phantom Black Pearl Effect (Link)
    '09 A8L Phantom Black Pearle (Link)
    '13 A7 Quattro 3.0T Phantom Black - SOLD
    '07 A6 3.2 Quattro Avant S Line - SOLD
    May 13 2011
    2015 BMW F30
    Good job.
    | Autospeed | JHM | Pure MS
    Jul 31 2011
    Wilton, CT
    You deserve a medal for saving this car. Great work so far man.
    Veteran Member Four Rings Believer's Avatar
    Oct 24 2011
    New Jersey
    Amazing zeal and perseverance through a really crappy hand.. Nice job. I really like the way your dip came out.
    Senior Member Three Rings Delmed83's Avatar
    Feb 19 2013
    Incredible work. I'm glad you got it sorted out.......if you wanna get things done, you gotta just go at it and do it. I think the fact that you've resurrected this car from the depths of hell is a wonderful Christmas present to all of us here in the AZ community.
    Fantastic job, my friend.
    Black 2013 B8.5 A4
    Previous rides:
    Silver 2001.5 B5 S4 - EPL Stage 3
    Black 2001 B5 A4 - Dahlback Stage 2
    Black 2006 B7 A4 S-Line APR Stage 2+
    Dolphin Gray B7 S4
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    Wow. You did wonders on that car.
    Its a shame you had to find out everything the hard way. Hopefully she will be running good for a long while now.
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    Veteran Member Three Rings Sour's Avatar
    Dec 08 2008
    B8.5 Brilliant S4
    great job! It sucks there are so many dishonest people out there.
    Past
    00' S4 Stage III
    02' S4 Stage II
    95' UrS6 Avant
    Jul 26 2008
    Brisbane, Australia
    Very impressive, well done.
    Sent from my HTC Sensation XE with Beats Audio using Tapatalk
    Oct 28 2008
    '00 S4
    The Mile High City
    Quote Originally Posted by Austonwerner4 View Post
    Didn't really have anywhere else to do it. I live downtown, and I only know one person with a garage close by. She's let me work on my car there before, but the second I would have told her what I was doing it would have been a fast no.
    Just waited for a day without any wind, and it was fine.
    Quote Originally Posted by aaron1085 View Post
    Quote Originally Posted by ebi718 View Post
    Not really. My thoughts are either the shop didn't do the inspection, didn't know what they were doing, lied to everyone involved, or colluded with the seller to rip me off. But, I have no direct proof of anything. I'm licensed in Mass., so I thought about the legal route, but after exploring the issue it was more work than it was worth.
    I still monitor his account to see if he's selling anything, so I can shoot the buyer a heads up about him.
    2004 Touareg V8
    Mar 24 2009
    New York and Toronto
    buying a car in this manner is always risky. sometimes it works out fine, sometimes you get what you got. despite that, this thread is a testament to your own personal dedication. you have done a good job thus far.
    just out of curiosity, how much time does this work represent from the time you got the car home to where it stood in your last photo?
    Because S4 = Hooker
    - getslideways
    Mar 24 2009
    Quote Originally Posted by KidGT View Post
    official nomination: most mature/realistic member of Audizine. [applause inserted]
    Because S4 = Hooker
    - getslideways
    Veteran Member Three Rings s4andtls's Avatar
    Jul 14 2009
    Ma.
    Gold medal! Feel free to post names of culprits, they deserve an ass whoopin.
    605.2 Brad tuning
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    damn what a crazy story. He should have just gone to the shop of your choice since you were the one shelling out all of the money. glad you made it home safely though.
    Veteran Member Four Rings Rdp616's Avatar
    Mar 23 2009
    Hibiscus S4
    SW, Pennsylvania
    Holy fuck, what a fiasco. Major props for sticking with it man. Not the cars fault.
    Single Turbo Hibiscus coming soon
    Veteran Member Three Rings hotshot32890's Avatar
    Dec 05 2009
    2008 VW Passat. 2000 Audi S4
    Boston, MA
    Being from the Boston area, that makes me raise an eye brow..Thumbs up to you sir, the avant looks great.
    Current:
    IN THE MARKET
    Previous:
    F21 Brilliant black b5s4
    SRM K24 silver b5s4
    Black B5S4: Eurojet Grenade DVs, AWE Twin1
    Eclipse GSX: 16G turbo
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    Great job....I'm in the process of doing the same on the Avant I purchased 2 months ago.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    This is just a reminder to be thorough when buying a car. Due to the excitement you tend to not notice things that would turn you off from buying it. Like the bad paint and rust. The worst part is that the shop that did the PPI screwed you as they could have alerted you to all of this.
    All of that said, great job with the resurrection, Nate.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings s2the4's Avatar
    Nov 02 2006
    01 Stage 3 S4 Silvaro, 01 S4 Avant Nogaro
    Western Mass
    That's a long list of snitch-iery. 9 owners I probably would have fainted when I saw that. Keep up the good work car looks great now! Just goes to show the owner is what makes these cars last and look good!
    |MRC-Tuned Stage 3| | RS4 K04 Turbos | | RS4 Y-Pipe | | RS4 Airbox | | RS4 Fuel Pump | | 60lb Siemens injectors | | ER SMIC | | APR Bi-Pipe | | All JHM Goodies | Vogtland GT | | Porsche 993 TT Brakes | | 034 Motor & Trans Mounts|
    ...For now
    417whp @ KTR Ayer, MA 110 octane with open dumps
    clicky
