Results 1 to 40 of 44
    Senior Member Two Rings mushasho's Avatar
    Dec 09 2007
    Northern MA
    A tale of Rubí... The True Story, Unfolded... Warning: Ur-S Content
    POST FROM October 17th, 2010
    Some remember me from this... the savage ex-girlfriend
    or this one, the victim of shady work at a local shop
    Since then I've strayed but have been lurking the forums ever since I got rid of her...
    But today I stand before my fellow forum members to proudly say that I'm back... (and still a sucker for silver)
    1993
    180k mtm 1+,
    Stromung Gen4,
    Samcos,
    Eibach on Bilsteins,
    2bennet camber plates,
    new coils,
    new cps,
    clutch done at 150k,
    Ipod Interface,
    17x8 DTM's on brand new Continental ExtremeContacts,
    new blower fan last fall,
    No LEAKS or Oil Burning (until now)..
    I'm the 3rd Owner, clean title no accidents or signs of over spray etc... over 12k in receipts
    plus a set of 16" ASA winter alloys with decent rubber...
    No rips or tears on the inside other than rear headrests (split at the seams) and what appears to be the beginning of the dreaded sagging headliner... Owner deleted the CellPhone
    exterior?... well it's rusty to my eyes but it was hard to find a 93 that wasn't... tell me what YOU think...
    ~OB~
    PS... Only $1200 bucks
    Then tragedy hit on my BDay Weekend 4/15/2011
    REAR ENDED WHILE AT A RED LIGHT...
    1995 ^ VEMS ^ IMS Tube EM ^ 1200cc FI ^ PTE GEN2 6062 ^ Stromung Gen4 ^ EDU 01E ^ EFI-X R8 Coils ^ Samcos ^ 18" OEM CH ^ Pirelli P7 ^ 29971/Bilstein ^ Clear Corner ^ SB Extreme ^ Auto Meter 5703 A-Pillar Boost Gauge ^ HRSB ^ A6 HID ^ Euro Lenses
    Project PTE6062
    Dec 09 2007
    Northern MA
    Then Comes Rubi To The Rescue 5Days Later & Rocks MyWorld
    95 S6 Tornado RED / Ecru
    133k
    Texas Owned NO RUST
    Stromung Unknown Gen Installed in 2006
    OEM RS2 Maninfold
    @88K Rebuilt O1E 6-Speed Conversion filled with REDLINE synthetic 75w90 fluid. All synchros and bearings were changed as well
    SACHs Clutch kit euro RS2 spec(whatever that means)
    BBS CH 18x8 AUDI OEM 43ET(CH021) Complete set of 5
    EBC pads with cross drilled rotors
    H&R Spring
    Bilstien Sports
    Modified Upper Slotted Spring Mounts
    Samcos
    K&N Filter
    Unknown Stage 1 Chip
    Autometer Pillar Mounted Boost Gauge
    35% Tint
    Euro Lenses
    55w 4300k HID's
    @100k T-Belt, Water Pump, camshaft seals, crankshaft seal, T-stat housing, valve cover gasket, front subframe bushings & lower control arms & tie rod ends.
    Needs:
    A Really good cleaning Ecru shows EVERYTHING!
    245/40/18's all around
    Driver Side Heater Seat Element
    Early Stage of Liner Sag
    Bumper Clip
    Project PTE6062
    Dec 09 2007
    Northern MA
    I Needed tires so I swapped out the set from Silvia's, so currently she sits like this..
    Immediately took her to the Dyno 250whp/283lb ft... seems pretty healthy
    In the endless pursuit of power I swapped in an RS2 Turbo, OEM RS2 Injectors, and VEMS
    Enjoyed it for a week or soo
    Then Came this Weekend
    Hit while standing still AGAIN!
    The Drunk Driver get Arrested
    http://forums.quattroworld.com/s4s6/msgs/108797.phtml
    Project PTE6062
    Dec 09 2007
    Northern MA
    Fixed....
    Trying out new sig ideas...
    Time to get crack'n on my BBK setup that's been collecting dust on the "bench"... Only air was used in this process for removal of pistons. Nothing else was needed to pry the dustboots off or removal of seal...
    P'Shop'd Rings Emblem
    Enjoy!
    Before
    Pop One out using air...
    Piston with old dustboot
    3 pieces
    to be replaced with these
    Lube & replace... 1 down 7 more to go
    Vise grip & Bolt
    Old seals actually looked good but I replaced them anyhow
    1 Done
    Both done
    Project PTE6062
    Established Member Two Rings AVier's Avatar
    Feb 06 2012
    Columbia, SC
    Everytime you get hit you get back up even better. I'm waiting for a few more posts where it turns in to a R8. Car looks nice. I've lately gotten in to red though silver is great looking.
    German Engineered Driver. German Engineered Car.
    "Yeah that light is always on..."
    Dec 09 2007
    Northern MA
    Some more goodies lined up...
    t04e 54trim/stage 3 tubine/k26 flanged, 60lb Dekas, ect...
    Right before final tightening...
    I'm trying to minimize hacking of the bumper so I'm think of this 3" core might help in that department along with the slimmer endtank profile. So I'm hoping the .5" height difference might slide behind it easier or (with the higher placement of the inlet/outlet) slide it under without having to trim.
    24" bottom length end tank to end tank
    VS
    Apikol 18"core but
    ~33" endtank to endtank & the install manual states the top side of the endtank is 21"
    Was previously on an A4
    Pipes are in
    So it's time to rip stuff apart...
    Aparently the previous owner of the bumper had an Apikol FMIC based on the existing trimming...
    Project PTE6062
    Dec 09 2007
    Northern MA
    No Trimming!
    Plenty of room!
    Next time I'll use 2.25" on the outlet to intake...
    but this isn't anything that a little trimming won't fix
    From this
    to this
    A little bit of this
    a little bit of that
    Project PTE6062
    Dec 09 2007
    Northern MA
    Here's an update on the Bosectomy, enjoy!
    Run wires to the door Blue for Highs, Clear for Mids, twisted pair for tapping into the preamp level before the Bose amps...
    Custom mounting bafle made out of a couple kitchen cutting boards... light, sturdy, strong & weather proof...
    We're not blessed with door mounts, instead the speakers mount to the panel... like so
    Stock tweeter mounts have to be cut open for usage as the stock system didn't use anything there
    Scrape plastic epoxy off
    Tweeter
    I used those brackets that come bundled with plastic mini blinds for home use... a couple bends and this is what you get
    Door Complete
    Plotting out a sliding amp rack
    What's it weigh?
    Not bad at all for over 1700 RMS watts of quality power IMO
    Project PTE6062
    Dec 09 2007
    Northern MA
    Many Thanks to Marc Swanson at EFI Express for the parts & support on many parts of my build, including these...
    Out with the old, In with the NEW!!!...
    New Clutch Description:
    "SS Stage 4 - (KF70074-SS-X) - Extreme: The Stage 4 SS-X Feramic kits are the ultimate when it comes to delivering maximum torque to the street and strip driven car. With feramic on both sides of the disc, the clutch delivers a more positive engagement. Because feramic clutch material dissipates heat extremely fast it will give you maximum clutch life and a consistent feel each time you shift. Torque Rating: 575 ft/lbs For even more power handling, consider swapping to a single mass flywheel setup (7a/Coupe Quattro style flywheel)."
    Project PTE6062
    Dec 09 2007
    Northern MA
    This year 2013 Spare Block Rebuild and PTE5862 Install in the Works...
    From this
    to this...
    So after an extended break from the project (read:holidays...) I decided to pick up where I left off...
    A while back I had tried different recommendations for cleaning carbon deposits... Some worked better than others but all left me wanting... Yesterday I figured I can do better and took myself to a local Autozone... They suggested the typical, seafoam ect... When at the bottom of the shelf I spot this...
    Something about the cheesy yet simple label caught my attention. It was also on sale so I took the plunge...
    Comes with a handy dipping tray...
    Results...
    In short, I'm reasonably pleased with the results...
    Project PTE6062
    Veteran Member Four Rings toaster's Avatar
    Sep 16 2005
    Gone:A4 USP+ / A4 S-Line+
    long island, ny
    love seeing the drunk drive getting arrested.
    Dec 09 2007
    Northern MA
    More...
    Light Hone with final Piston Wall Clearance .0035", Decked with a 30 RA finish, and Jet Washed....
    Profilometer
    Cylinder 1
    Cylinder 2
    Cylinder 3
    Cylinder 4
    Cylinder 5
    Next Stop? Pick up rotating assembly from the Balancing Shop...
    Done Work...
    Balance Rotating Assembly. Rods & Pistons
    Micro Polish Crank, Radius Oil Holes
    Jet Wash Crank
    Bead Blast Flywheel & Damper
    Balance Sheet
    Crank
    These always break, huh...
    Project PTE6062
    Dec 09 2007
    Northern MA
    Head Break Down
    And off we go onto block assembly... Weird things are happening at my job, the gave me another day off today. Hopefully it's not a bad sign, but regardless I can use the much needed time....
    Looking at the block, it could use some dressing up... Any tips out there for painting cast iron on a budget?
    Just shot the 1st layer of paint.... I'm not 100% on the color after it's been sprayed on the block.... It's more bronze than dark metallic gray...
    Do my eye's deceive me?
    Project PTE6062
    Dec 09 2007
    Northern MA
    Anyhow, some assembly got done today on the block... I wanna emphasize on "some" because it would've been done had the oil squirters had been picked up with the block... I had sort of rushed in and out when I picked it up...
    Oh well here are some pics
    Some balance correction marks on the rods...
    Cylinder 1
    Cylinder 2
    Cylinder 3
    Cylinder 4
    Cylinder 5
    Project PTE6062
    Dec 09 2007
    Northern MA
    Moving right along... Quick little lunch break gave me time to move this along a little bit...
    Clean Surfaces w/Flash
    Clean Surfaces w/No Flash
    Coated Main Bearings
    1 Piece!
    Top Shell Rod Bearings In
    LUBE!!!!!
    Project PTE6062
    Dec 09 2007
    Northern MA
    Quote Originally Posted by AVier View Post
    Thanks a bunch AVier, what doesn't break you makes you stronger... right?
    Project PTE6062
    Dec 09 2007
    Northern MA
    Quote Originally Posted by toaster View Post
    I wish I would've skipped the whole episode to be honest... I hate Audi Carnage...
    Project PTE6062
    Veteran Member Four Rings morris400's Avatar
    Dec 18 2008
    2016 VW GTI, 1994 Audi S4
    Alberta, Canada
    Awesome build man, wish I had money to do this to mine. I'll live through you lol.
    IF YOU WONT STAND BEHIND OUR TROOPS....TRY STANDING IN FRONT OF THEM!
    2016 VW Jetta 1.4T Daily Driver
    1994 Audi S4 20V Turbo, K24 7400 EFI EXPRESS
    2001 Audi S4 - Gone! Dropped valve cyl 4
    Dec 09 2007
    Northern MA
    Quote Originally Posted by morris400 View Post
    It's all about timing... luckily I was able to keep that Silver car as a parts car for like $400... the rest was put towards Rubi... the motor I'm building is off the Silver car...
    In essence it's just a Rod Build on 7A cams... that's not much $$$ at all... I had the PTE5857 from another local UrS part out and just sent it out to PTE for the PTE5862 CEA upgrade ~$500 ... the most cash outlay on parts is "supporting" mods, ie. V-Band tubular header, downpipe, & machine work adds up quick. This is doing all the work myself too...
    Project PTE6062
    Dec 09 2007
    Northern MA
    Re: A tale of Rubí... The True Story, Unfolded... Warning: Ur-S Content
    BOLTED these on before going to the beach today...
    Sent from my HTC One using Tapatalk 2
    Project PTE6062
    Dec 18 2008
    Alberta, Canada
    Keep up the good work.
    Dec 09 2007
    Northern MA
    Thanks... Your build looks awesome BTW... How do you like the ride of the 2Bennett system?
    Project PTE6062
    Veteran Member Four Rings Turbo Nerd's Avatar
    May 12 2009
    B5 A4, B5 S4, C5 Allroad, C5 A6
    Detroit Metro Area
    I love everything about UR's, makes me miss the 95 S6 I used to dip around. Great work Mushasho.
    Veteran Member Three Rings A4TQS's Avatar
    Feb 17 2013
    B7 2.0T Quattro Sline
    Europe
    Good job glad to see someone still walking tall after what happened
    EU Sline seats | H&R 20mm rear spacers |Shell V-Power NITRO+| Castrol Edge| Interior leds | VAG Mods | R8 oil cap | RS4 Pedal set | K&N Air filter | Rear lip spoiler | R8 red coil pack | ECS boost gauge | Continental Premium Contact 6 | LED City Lights | 034 Turbo Inlet Hose | Nokian WR A3 | License plate leds |
    Dec 09 2007
    Northern MA
    Rear Main: ON
    Oil Pump: ON
    First Gasket: ON
    Windage Tray: ON
    Pickup Tube: ON
    Second Gasket: ON
    Oil Pan: ON
    Oil Filter Housing: ON
    Project PTE6062
    Dec 09 2007
    Northern MA
    Dissecting the Upgraded 5857... NOW 5862 with VBand in & out
    Project PTE6062
    Dec 09 2007
    Northern MA
    A little dress up...
    Project PTE6062
    Dec 09 2007
    Northern MA
    A little more...
    Arp
    Project PTE6062
    May 12 2009
    Detroit Metro Area
    Looks great man, excellent work.
    Dec 09 2007
    Northern MA
    Quote Originally Posted by Turbo Nerd View Post
    Thanks!!!!
    Project PTE6062
    Dec 09 2007
    Northern MA
    More....
    Project PTE6062
    Dec 09 2007
    Northern MA
    E85 Fuel Pump Install
    Height difference between OEM and 450LPH
    Cut Basket
    About a similar size cut of the bottom the new pump
    Slide IN
    It gets more snug as you go in thanks to the OE basket tabs
    Flush
    Top View
    Splice into the wires
    Re Install as a complete unit
    [imghttps://lh3.googleusercontent.com/-4741atGekJ4/UeSLI7mKJBI/AAAAAAAAxWY/hQYUe4BZ6dc/s512-Ic42/IMAG0701.jpg[/img]
    Last edited by mushasho; 10-05-2015 at 10:46 AM. Reason: Add Fuel Pump Install Pics
    Project PTE6062
    Dec 09 2007
    Northern MA
    Project PTE6062
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    Clean car and nice build!!
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant, 2002 Audi S6
    Dec 18 2008
    Alberta, Canada
    You need fuel...lol. Awesome car.
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    I picked up my tornado over the weekend as a DD, but man I keep seeing this and wonder if I should build the Ur or my b5 s4. The turbo is so accessible compared to my b5 lol and it's taunting me.
    Dec 09 2007
    Northern MA
    Quote Originally Posted by Eurotuned_A4 View Post
    I've had both at the same time... Tell me more about how you use your cars I can help you decide...
    Project PTE6062
    Dec 09 2007
    Northern MA
    Looking to piece together a little Side Mount fluid cooling section for my car, similar to the one AutoSpeed version
    Possibly with some sort of ducting to the oil side...
    The Question is, do we NEED to oversize it over 3x over the stock 7row in order to keep things in check on hot days with spirited driving?
    25-Row
    19-Row
    Project PTE6062
    Dec 09 2007
    Northern MA
    Getting it done
    Good Used Piston
    Swapped out the .64 for a .82
    Pump gas numbers revealed a bad slipping clutch...We managed 374whp at 23.5psi but on 93 using a .82 hotside, 90*F ambient,
    A little more on e85
    And straight to the track...
    Project PTE6062
    Dec 09 2007
    Northern MA
    Based on some reading, I think the cause for excessive grease would be an explosion of el DMF... But I'll pull more components apart and take better pics to see what you guys think...
    From the 5 options discussed on QW I can Rule out:
    #2. Engine oil passing through the rear crank seal
    #4. Loose bolt machining a hole through the bellhousing and into the transmission, letting tranmission fluid into the bellhousing
    Those that have had multiple clutch setups...
    Is it true a 707 PP requires more pedal effort while holding less than a Twin Disc? (Pick a brand)
    However the engagement of TwinDisc is a lot more twichy (on/off) in comparison?
    I'm a sucker for lighter daily driveable clutches but I need a reliable setup for my driving style.
    The current setup is a Southbend Stage 4 dual ferramic disc on a stock DM Flywheel in an EDU 01e. Say we need enough clutch to put up with whatever this billet 58mm can put out in a 20vt "tractor motor"...
    TIA
    Project PTE6062
