Results 1 to 15 of 15
    Sep 26 2014
    200 20v (x2), D2 S8 6mt, C5 S6 5mt, C5 RS6 6mt, Fox quattro 20vt
    Knoxville, TN
    Amulet Red S6 to RS6 Avant 6-speed Conversion (and vice versa)
    Get your reading glasses, cause this is gonna be a doozy! I guess this is a hybrid of a build thread and a DIY writeup.
    I've been an old-school 5-cylinder Audi enthusiast for awhile, but I always loved the idea of the RS6 Avant. The engineers at Audi (bless them) took an unassuming family station wagon and thought "but what if dad was REALLY late for soccer practice?" They calculated exactly much engine could possibly fit under the hood, decided that was not enough and extended the front to fit more. The resulting twin turbo V8 estate blended practicality and performance in a way I could only dream of, since Audi had also decided us Americans would be content simply knowing it exists. And with a 6-speed? HA! The RS6 has never been offered with a manual anywhere in the world.
    Well, opportunity came a-knocking one pandemic-riddled year, when I found this storied oddity: an RS6 sedan, abandoned at a Quik Trip when its owner fled the state to evade the law. After sitting at a gas station for weeks, it was towed and received a salvage abandoned title, as well as a new key. The car was listed on Facebook marketplace, with a single grainy picture, fake RS6 badging, by a company who had no idea what it was or if it even ran. I called them up, not knowing if this was even a real car, and we struck a deal, sight unseen, from 9 hours away. I showed up with trailer in tow and found myself equally surprised that it was, indeed, a real RS6, and, despite being told it would not run, it fired right up with a jump pack and drove itself onto the trailer! What follows is the tale and details of the build that this fortuitous sequence enabled.
    Let me start out by saying I am not the first to do this swap, nor is this a definitive guide. There are many possible ways you might accomplish a similar outcome, but I'd like to share my process, in the hopes that it may help inspire future builds The biggest issue that I've found is that RS6 owners, historically, have been a lot more willing to shell out cash that I am. This means parts are expensive, and a lot of people had their car serviced by a garage, so DIY information is a little spotty - BIG shoutout to the players who did post up what they knew. I'd like to use this thread to fill in the gaps and pay it forward.
    Foreword
    This swap is not for the faint of heart. The individual steps are not terribly difficult, but there are a lot of them. You will need a pretty thorough mechanical understanding, as well as basic to medium fabrication capabilities. Rather than documenting every single nut and bolt, I will be outlining the major steps as they relate to the changepoints only, with the assumption that you can fill in the gaps. I will, of course, answer any questions I can, but please do not expect a step-by-step instruction.
    That said, yes, you could perform this as a capable backyard mechanic on jack stands alone, but a lift will make your life much easier. I built one of the cars on a lift and the other on the ground, so I got a taste of both.
    You will need (at a minimum), the following:
    • Jack/stands
    • Engine hoist/stand
    • Angle grinder
    • Die grinder
    • Welder
    • Basic metric tool set, including wrenches, sockets, triple squares, etc
    • Torque wrench(es)
    • Wire strippers/crimpers
    • Multimeter
    • A/C manifold gauge / vacuum pump
    • Paint gun and a GOOD respiration system
    • 40v timing belt tools
    • Cam tensioner tool
    The Patients
    I'm typically an opportunistic car buyer. A good deal and mechanical worthiness are far more important to me than paint and cosmetics, so my cars have always ended up being silver - not because I have any affinity for the color, but I guess no else does either. However, for this build, I decided I wanted something special and worthy of the swap. I really wanted an Amulet Red or Nemo Blue S6, and I held out for awhile just looking for the right candidate. After a few false starts, I finally came across the perfect spec: Amulet Red over black alcantara interior, solar sunroof, and it even had a third row! Body was straight and rust-free and the clear on the roof was starting to go, so I could actually afford it. I flew out to Colorado and drove it back to Ohio for its new life!
    Donor #1: 200X Audi A6 sedan, seized 2.7T engine, 6-speed manual
    (Knoxville, TN)
    Donor #2: 2003 Audi RS6 sedan, Avus Silver over Black interior, 116k miles, Felonious History
    (Kansas City, MO)
    Recipient: Project Sauron: 2002 Audi S6 Avant, Amulet Red with Black alcantara interior, 204k miles
    (Boulder, CO)
    Donor RS6 Parts
    You might be thinking "I'll just buy an engine and swap it," but I highly recommend you have access to a whole donor car. If you want a comprehensive RS6 conversion, the following parts are unique to the RS6 and must be swapped:
    Powertrain:
    • BCY engine and all accessories, including intercoolers, turbos, harness, exhaust, ECU etc
    • Motor mount brackets bolted to engine
    • Frame rail snub mount bracket (cut and re-welded)
    • Rear differential
    Battery
    • The battery needs relocated to the rear
    • Main fuse blocks
    • Starter wire harness
    Coolant System:
    • Entire coolant system (except heater core), including pipes mounted to 2nd firewall and reservoir
    • Core support and radiator, incl electric fans
    • Radiator fan control unit
    • Radiator fan control harness, unbroken from driver's frame rail, along the fender, terminating in driver's footwell
    Brakes:
    • All calipers/rotors (just leave these assembled with the whole suspension/subframe if you can)
    • Rear spindles
    • Brake booster + master cylinder combo
    • Brake booster vacuum pump
    • Brake booster pump relay and harness under the cluster
    • Parking brake cables
    Steering:
    • Steering rack (shorter ratio)
    • Lines to/from rack
    • Heat shields over the steering rack
    Air Conditioning
    • Entire line set from the firewall to the compressor
    • Drier and mounting bracket
    Fueling
    • Fuel injectors
    • Entire fuel lines from engine bay to tank (RS6 is bigger diameter and routed a little differently in the engine bay)
    • Fuel pump
    • Auxiliary fuel pump and entire harness
    • Auxiliary fuel pump controller
    • Fuel tank (tanks are technically the same, but it was easier for me to swap the lines and pumps as one assembly with the tank when the subframes were off)
    Suspension
    • DRC control valves on the wheel well
    • DRC lines under body to each knuckle
    • Struts and springs
    • Rear subframe (may be the same, depending on your S6)
    • Front subframe (the same, but its just easier to swap the suspension, subframe and brakes all as one assembly)
    Electronics:
    • ABS controller (can be upbolted separately from pump)
    • Cluster
    • Engine control unit
    • Immobilizer "pill" in the key (paired to the cluster)
    • Horns
    Exterior:
    • Front (vented) fender liners for intercooler airflow
    • Front bumper and crash shocks
    • Grill
    • Badges (if you're a poser like me)
    • Front lock carrier
    • Door blades
    • Side skirts
    • Side view mirrors
    (RS6-Avant specific parts must be imported, including rear bumper, spoiler, and polished trim surrounding the windows)
    Interior
    • Seats front/rear - only the outer pieces of the seat backs are Avant/sedan specific, but fortunately, both my cars matched interior color
    • Door cards (I did not swap these, as I liked the S6 Alcantara)
    • Interior door handles, if whole door card is not swapped
    • Steering wheel
    • Door sills
    • Carbon fiber interior trim
    The following thread will cover the details of swapping all these parts over. Comments, feedback and corrections are most welcome!
    - - - Updated - - -
    Stage 0: General Maintenance
    This is a personal preference, but I'd recommend getting the engine(s) well-sorted if you have the engines out and it's all accessible. Both my cars had a relatively unknown history. If you can do this ahead of the swap, even better. The idea here is to minimize the amount you need to focus on when it comes to the big swap, or for that matter, removing variables if you need to troubleshoot. My recommendations for the 4.2 and 4.2T:
    • Timing belt, water pump, idlers, seals, etc
    • Cam tensioner pad replacement + oil pickup screen removal if timing is serviced (The tensioners themselves don't typically fail in isolation, but the plastic pads get brittle and can fall apart. That or, the oil screen gets dislodged and sucked in, leading to failure)
    • Front and rear main seals
    • Accessory belt
    • New spark plugs; check condition of coil packs and replace if necessary
    • Oil change, filter, air filters
    • Oil cooler coolant pipe, aka Bufkin pipe
    • Knock sensors, injector O-rings, and intake manifold gaskets + (RS6) Suction jet pump and afterrun pump under the intake manifold. Save yourself the headache of these breaking when they are impossible to get at.
    • (Optional) Secondary air injection delete - if you won't get dinged for emissions compliance, this will free up some room in the engine bay and greatly simplify layout. The monitor can be disabled via the ECU.
    • (RS6) Turbo rebuild
    • (RS6) Replace/repair leaking intercoolers - I re-cored my intercoolers with Bell Intercooler cores A300090100 (3"x 9"x10")
    • (RS6 Optional) Auxiliary radiators delete
    - - - Updated - - -
    Stage 1: Manual Swap
    Since I was planning to swap both drivetrains, I actually manual-swapped both cars prior to the engine swap. It allowed me to spread the scope of the project out over time without an extended period of downtime. Each car was individually swapped while the other could still serve as a useable car. It should be noted, you don't *need* to remove the engine for this on the S6, but you will for the RS6.
    Disclaimer: The RS6 engine does not directly mate to an 01E. The RS6 gearbox has a wider bellhousing pattern, as found on the later D3/C6 engines with the 6HP gearbox. This means several bolts don't line up, and crucially, the starter sits further out. There are a few excellent kits out there to get around this issue. I have no issue with them, but personally, I felt I could accomplish a similar result for a smaller cost. Some folks do not agree with this methodology, as it involves irreversible modification the engine block, and there are fewer bellhousing bolts securing engine to gearbox. I'll share the details below, but please understand this disclaimer.
    There are a few manual swap guides out there, so I'll keep this short. This is another case where a donor car would be handy. The following parts were used, mostly from a 6MT 2.7T A6 sedan. And of course, if you're swapping both cars... you'll need double these parts.
    • C5 A6 01E shift linkage from cabin to gearbox
    • C5 A6 01E transmission mount brackets
    • C5 S6/RS6 auto transmission mounts
    • 2.7T 01E spacer for dual-mass flywheel (11mm)
    • C5 A6 01E driveshaft OR Non-4.2 driveshaft + JHM driveshaft spacer (despite the info on their site, the 4.2 driveshaft is too short)
    • B5/C5 manual pedal assembly
    • B5/C5 01E clutch slave cylinder
    • C5 01E clutch master cylinder
    • B5/C5 clutch switch
    • B5/C5 transmission alignment dowels for use with 01E spacer
    S6 parts used:
    • 2.7T flywheel (I used a Fidanza LWFW)
    • B5 S4 clutch
    • 01E throwout bearing
    RS6 parts used
    • TTV Racing 10-bolt flywheel for RS6
    • Ringer Racing Stage 5 clutch + extended throwout bearing
    Oil cooler
    In the likely event that your RS6 oil cooler stripped the threads undoing them, there is a repair solution out there on the forums. However, I took the opportunity to increase the oil cooling capacity. I cut off the end tanks with the stripped threads and welded on a plate with -10AN male fittings on either end. In effect, I had combined the ATF and oil coolers into one, larger unified oil cooler. At the block, you can use an M22-> -10AN adapter fitting to then make AN lines to the cooler.
    ...and now I realize I don't have any pictures of this setup
    Gearbox refresh
    This would be an excellent opportunity to give the gearbox a little love. I rebuilt my 6-speed 01E with the JHM syncros and the updated 1-2 shift collar. There's a great video by JHM on Youtube guiding this process.
    Block modifications
    Your options when manual-swapping an RS6 are essentially one of three:
    1. Use an adapter kit (for example, SteveKen or Apikol)
    2. Swap internals (rods/pistons/crank) from RS6 engine block to N/A block. This would also allow you to use a much more common 8-bolt flywheel if you retained the N/A crank
    3. DIY adapt the engine block to mate to the 01E
    For all of the above options, you will be throwing out your RS6 starter.
    For option #3, you will need a D2/C5 4.2 starter. The first step is to adapt it to the block. The good news is that the holes for the alignment dowels on the engine are common between RS6 and S6 engines. This means you can comfortably bolt up the gearbox without worrying about misalignment. After fitting the dowels, you can throw on an 01E or just the spacer to serve as a template for drilling the holes for the new starter position, as well as a hole through the upper oil pan that gets tapped.
    Once that's done, it's time to clear away all that extra material for the starter. I had previously modelled the starter for another project, so I 3D-printed out a cross-section of the starter to use as a template and went to town with a die grinder. The goal, ultimately, is to remove material until it matches your N/A block.
    Finally, we need a starter spacer. If you look at the mounting boss for the BCY starter versus the N/A motor, you'll see that the RS6 is a bit thinner. This is purely from memory 4 years ago, but I believe it's around 9mm different. I approximated this by using a plate of 5/16" 6061 aluminum cut to fit the starter profile. You can just take a hole saw (3 inch?) to the plate, then easily drop the starter on to trace the rest of the profile. At this point, you can technically be finished, by just sandwiching the spacer when the starter gets bolted. However, since the starter position is located precisely by the 3" hole in the spacer, and the spacer is free to move around a little, I wasn't happy with the potential variance you could have on install. As such, I carefully aligned it on the bench and welded the spacer to the block. Then I cut a small relief in the outer side of the spacer to allow the starter to be installed/uninstalled. Finally, I made a steel bracket to fix the back end of the starter to the block, like you see on the N/A application. *Slaps starter* "That ain't going nowhere"
    Now we could actually be done. Many folks (including myself) have run this type of setup for many miles without issue at elevated power levels. You will have 7-8 bolts between the gearbox and engine, but there will be about 3 missing on the oil pan. These were obviously included by the engineers for a reason, but some might call it "good enough." However, if you simply cannot sleep at night with this omission, I believe there is a solution that hasn't been explored yet! Next time my engine comes out, I will be swapping the RS6 oil pan with an N/A oil pan that has been tapped to include turbo oil returns. They appear to be interchangeable and will complete the mating to the 01E.
    And that's it! Bolt it all together like any clutch job at this point.
    Manual Swap Wiring
    Couldn't be easier!
    Clutch switch
    You'll need to wire a clutch switch that is opened when you depress the pedal. This is used by the ECU both for cruise control interrupt, and to adjust ignition timing for driveability. Without this switch, the engine will rev-hang between shifts. Wire one side of the switch to ECU pin #39. There's no wire there, but it is populated by an empty pin that you can pull out and crimp to using a barrel crimper. The other wire of the switch needs to go to switched 12V power, which is available if you splice into the equivalent line on the brake switch.
    Starter interlock
    Did you turn the key and nothing happened? It's time to bypass the function of the Park-Neutral safety switch from the automatic. There are three options here, actually
    1. (OEM) Install a clutch switch that closes at the bottom of the pedal stroke (from B5/C5). Wire it with one pin to ground, and the other to the ground control side of the starter interlock relay
    2. Permanently trigger the starter interlock relay by grounding the control line - there's no clutch safety in this configuration
    3. Remove the starter interlock relay entirely and jump from the power supply to the load (30 to 87) - also no clutch safety in this configuration
    Reverse Switch
    This will depend on whether you removed the automatic transmission harness or not. I simply left the harness in place and spliced into the reverse wiring on the 10-pin F125 connector. Extend these 2 wires and attach them to a 2-pin Bosch connector to plug into the 01E reverse switch. That's it! The reverse lights will work, and the backup sensors/camera tilt will automatically engage when you hit reverse.
    Manual Swap Coding
    (Note: I need to double check these steps are accurate; they are based on my notes from two years ago)
    You can now simply remove the TCU. I left the harness in place for convenience. Three units will need to be updated to play nice and not report faults for the missing TCU
    ECU Coding:
    The ECU will need to be remapped to utilize the clutch switch you've added. Your tuner should be able to add this function, as well as any monitors you want to disabled (SAI, rear O2, etc).
    Once this is done, the soft coding needs to be set with VCDS. There is no login for this setting.
    Set coding to 10712
    ABS Coding
    Auto S6 Coding: 06397 (06 = Audi A6, 3 = HP2 brakes (1LX), 9 = 6/8cyl, 7 = automatic)
    Auto S6 Login: 07497 (07 = Audi A6, 4 = HP2 brakes (1LX), 9 = 6/8cyl, 7 = automatic)
    Manual S6 Coding: 06395
    Manual S6 Login: 07495
    Auto RS6 Coding: 06697 (06 = Audi A6, 6 = 2FNR brakes (1LJ/1LP), 9 = 6/8cyl, 7 = automatic)
    Auto RS6 Login: 07197 (07 = Audi A6, 1 = 2FNR brakes (1LJ/1LP), 9 = 6/8cyl, 7 = automatic)
    Manual RS6 Coding: 06695
    Manual RS6 Login: 07195
    This one's easy to get wrong, and it won't take if you do. Use VCDS and follow these steps to get it to work:
    Note: If your steering calibration has been lost, the ABS will forget its soft coding (00000). You will need to follow these steps to set the stock coding again.
    1. IG-on, establish connection with VAGCOM
    2. Select ABS-Brakes module
    3. Login (11)
    4. Type generated login code for the current state of the controller (stock)
    5. Coding (07)
    6. Type generated target code; if workshop code is 00000, you must change it! (e.g. 12345)
    7. Login (11)
    8. Type 40168 (enable basic settings) -> Do it!
    9. Don't start engine; turn steering 90deg left, back straight (you can read out group 005; must be +/-5 deg of 0
    10. Click Basic Settings (04)
    11. Group 001 -> Go! This performs the calibration. Should say OK under "Alignment status"
    12. Done, Go back
    13. Check for faults; they should now be cleared.
    Cluster
    1. Using VCDS, go to Instruments
    2. Adaptation
    3. Channel 60
    4. Set to 1025
    5. Done
    - - - Updated - - -
    Stage 2: Cosmetics and Body Work
    Following the manual conversion, I decided to pull off the body parts that would need paintwork. This way, I could prep and paint the parts without disabling the cars.
    DANGER Automotive paint is no joke. You can develop lifelong lung issues from improper ventilation or respiration, even from a single session from some clear coats. Most home respirators are not up to the task. I invested in a supplied air respirator that could port fresh air from elsewhere and provide positive pressure of fresh breathable air to my mask, no matter how hazy the air I was in got.
    Disclaimer: I don't really know what I'm doing with paint, but it's quite expensive to outsource, so I decided I'd try anyways.
    Painted parts include:
    • Front bumper cover
    • Side skirts
    • Lower door blades
    • Rear spoiler (RS6 Avant specific - it'll have to come from a real one in Europe, but I just bought a stick-on approximation on eBay that I'm happy enough with)
    • Rear bumper (RS6 Avant specific - this part has a real RS tax, and I frankly don't care enough to pay it purely for cosmetics. It is omitted from my build unless I come across a cheap one)
    At this point, you can also install the bodyparts you've painted, as well as the non-painted bits like the grill and side-view mirrors.
    The interior is also primed for swapping!
    • Front seats (direct interchange)
    • Rear seats (direct interchange, except the outer bolster that is Avant/sedan specific. If you're lucky like me, the two cars have matching interior colors, so they could be left)
    • Carbon trim, if you have it
    • Black RS6 interior door handles (you could swap the whole door card, but I wanted to keep the S6 alcantara cards). Good to do this step with the side-view mirrors
    • Door sills - Have fun with these! They are very difficult to pull up without damaging them, but meticulous prying, gentle heat, and solvents like goo-gone can get you there eventually. I cleared off the old adhesive from the sills and applied new strips of 3M trim adhesive strips
    • Steering wheel
    Cluster is omitted for now due to immobilizer function. This will be swapped with the engine.
    - - - Updated - - -
    Stage 3: Battery Relocation
    WORK IN PROGRESS. Need to gather pictures and more details. Will edit and update when available
    Due to the tight layout of the RS6 engine bay, the cooling system occupies the space where the C5 battery conventionally lies. As a result, you'll have to move the battery elsewhere.
    In the RS6 sedan (USA), the battery has a "bread box" that occupies a large portion of the trunk area. This was absolutely unacceptable to me to swap over, as it defeats practical space of an Avant. In the rest of the world, both the RS6 sedan and the Avant got their battery located in the spare wheel well. This is better, but I like to carry a spare, and I consider it a practical essential of using the car as a daily. Therefore, the only real solution left, in my eyes, is to put the battery in one of the two side storage areas in the hatch area. Based on the space available, I elected to use the driver's side pocket.
    I ordered 20 feet of 1/0 welding wire and went to town tucking it away in a way that was hidden, yet minimally invasive. From the new battery compartment (behind the interior panels), it went up and over the rear drivers wheel wheel and down behind the fixed piece of the rear seatback. It then travels under the rear seat over towards the passenger side, where you can tuck into the carpet. There is a corner where it can tuck in without getting pinched or kinked. Some trim needs to be removed to lift the carpet sufficiently, but you can run it all the way forward along the side of the floor to the box where the TCU is kept, just in front of the passenger seat. Here you can center the wire a little more and run it the rest of the way up the passenger footwell to the end of the carpet.
    Look at the sedan donor car and note where the battery cable passes through. You can drill a hole in the Avant in the exact same spot. You'll want to include a good grommet to keep the battery from shorting to the body here. Pass the battery cable through the hole and fit the grommet, then cut the cable to length to mate with the RS6 fuse block that is now mounted to the area. I crimped a ring terminal at both ends of the cable to finish it out.
    Sep 26 2014
    Knoxville, TN
    Stage 4: The Rest of the Owl
    At this point, it stops making sense to break up the build into steps that can be done in advance of the actual conversion. Hunker down and get ready to disable two cars. I know I write a lot, so I'll let the pictures do most of the talking.
    Air Conditioning
    As soon as the front ends came off, I set about swapping the A/C lines, because I was 100% sure I'd forget the routing. The S6 and RS6 have different layout due to the intercooler/airbox. I hope these pictures will help give a general overview, but you'll figure it out. The lines are pretty rigid and will only fall one way, so long as you get it started right. The Avant will need some rivnuts added to mount the drier bracket (x3 M6 or M8 I think).
    Before:
    After:
    Engines Pulled
    Day 2 of the swap. Get 'em out of here!
    Engine Bay Differences
    With clear engine bays, now is a good time to note the physical differences between the RS6 and the S6 engine bays. You’ll need to transfer these features in the conversion:
    Steering rack and heat shields
    With all the heat from the turbos, you'll need to keep from cooking the steering rack. The RS6 is clad in extra shielding, and these heat shields can be interchanged directly, though some of studs don't match one-to-one. There are enough provisions for it to be a bolt-in affair though.
    While you have these heat shields off, it would be a good time to swap the steering racks. The RS6 rack has a shorter ratio, which gives a sportier feel. Go ahead and bring the the lines with the racks, since they are also slightly different. The S6 rack used servotronic and therefore had a harness connection. Though I brought the wiring over, I decided to eliminate this function during the swap.
    Firewall Provisions
    The RS6 has a coolant manifold bolted to the second firewall. You’ll need to drill through to provide the same holes on the S6 that don’t exist there originally. I just took a piece of paper to the sedan's firewall and transferred the profile to a template by rubbing the side of a pencil against it.
    On the Avant, you will also remove the coolant reservoir mounting tabs from the firewall, and then cut a hole for the brake booster vacuum line. I drilled out the spot welds so that I could transfer the brackets to the sedan, then cut the same-ish shape in the firewall to be able to use the RS6 grommet.
    Frame rail modifications
    1. The most notable change between the two bays is that the snub mount bracket welded to the passenger frame rail is different. Even if you don’t run a snub mount, the S6 bracket needs to be removed, because it will interfere with the charge bipipe going to the intake manifold.
    There is a little bit of positional tolerance built into the mount design, so you don’t have to be *perfect,* but I measured against the common points of the frame rail and got it as close as possible. If you’re swapping both cars, you’ll want to transfer both snub mounts between cars.
    2. Additionally, both frame rails on the Avant need to be cleared for the intercooler pipes. I haven’t seen this mentioned elsewhere, but the pinch weld on the top of the frame rail is folded over on the RS6. This does not need undone for the S6 sedan, but you will want to fold over on the Avant so you don’t risk them digging into your boost hoses.
    3. Finally, you'll need to transfer the channel for the battery cable from the sedan to the Avant. The sedan will, in turn, receive the standoffs for the S6 airbox in this spot.
    Engine bay paint
    Since we’re welding and wacking and drilling, I would highly advise covering up the bare metal with paint. Given the location, you could probably just use rattle cans, but since I had paint mixed for the body panels, I gave the engine bay some nice spots of color-matched paint. Ironically, these are now the nicest paint on the cars
    Rivnuts everywhere
    You need to bolt more stuff down with the RS6 gear in the engine bay, so you’ll need some more bolting provisions. On the Avant engine bay, these are just blank sheet metal. I found the best way to provide these was to drill through the sheet metal, referencing the location on the RS6, and applying these threads with M6x1.0 or M8x1.25 rivnuts as necessary. These include (but not limited to, cause I probably forgot since I did this):
    • Mounting the main fuse block to the firewall
    • Providing a mount for the external coolant pump on the driver's frame rail
    • Mounting the A/C drier bracket on the passenger side
    • EGT sensor mounts to the 2nd firewall
    • Providing a ground point for the battery relocation in the back
    Intercooling
    You can jump the gun a little and fit the intercoolers in place, along with swapping the fender lines that provide them airflow. This stage had me sitting and staring at my work for a minute
    Suspension and Brakes
    This is easiest done as one whole assembly. Disconnect the links to the body (ABS sensors, brake hoses, DRC, headlight adjust sensor, axles, etc), and drop the entire subframe with control arms, spindles, calipers, and all.
    For the rear, this will include the rear differential and parking brake cables, which are also RS6-specific.
    I did take the opportunity to replace all the control arms and brakes pads/rotors. This is an EXPENSIVE endeavor for an RS6, but made much more affordable using R8 rotors in the front, and W12 Phaeton rotors in the rear (the rear calipers need 2mm spacer due to rotor offset)
    If you're crazy enough to keep the DRC, you'll need to add some rivnuts to the spare wheel well. Plus you will need a way to charge the system; I don't think it can be removed without breaking open the lines.
    I went ahead and lifted all the lines and mounted the valves to the wheel well, but left it all disconnected and switched to conventional struts. The hardware is there if I get any ideas, though.
    Finally, the brake booster, master cylinder and the brake booster vacuum pump are all RS6-specific, so you'll want to swap these over too. These are pretty straightforward bolt-on's, so I don't have any pictures.
    Fueling
    Honestly, I think I lost these pictures, but it's straightforward enough. However you slice it, the Avant will need a bigger fuel pump. How you go about that is up to you, but I decided to simply transfer the entire fuel systems (some people just replace the S6 pump with a more capable unit)
    The stock RS6 has TWO fuel pumps. There's one in the tank, and one external near the rear passenger wheel. This external pump also has its own little controller that's really fun to get out of the sedan, and it will need wired into the Avant for power and communication with the ECU. Though the fuel tanks are identical, the fuel lines are not. The RS6 has a larger fuel feed line, and the routing for the external pump and in the engine bay is slightly different.
    With the rear subframe off both cars, I figured it was honestly just easier to drop the tanks and lines in their entirety and bolt them up to the other car. No real surprises, except that the studs in the engine bay won't match 100% due to the layout differences.
    Wiring
    This information was really sparse when I did my swap. However, it’s really not too terrible, other than access for some spaces. Some of this is optional, and some of it can be done other ways. This was the closest approximation to OEM I could accomplish.
    Disclaimer: The best way to go about this would be to get new pins for the connectors, but I failed to find these. If someone knows a source or part number, please let me know and I’ll include that info! Otherwise you’ll need to repin and splice (my route) or add a new connector in parallel.
    The RS6 is very similar to the S6 in terms of its wiring, except that it just has a little more running gear. We'll need to wire in the following:
    • Electric fan controller
    • Horns - really, you just need to rearrange/extend the harness due to different layout
    Here's what I what put together, but I've since put it in a spreadsheet so you don't have to!
    Electric Fan Control Harness
    For the electric fan(s), you can simply swap the entire fan control harness. It runs from the front of the driver's frame rail, along the fender, and into the driver's footwell. Undo the power and ground, unclip the fuse holders, and get the brown connector out of the connector block. You should not have to cut or splice anything for this section. You will, however, need to repin/splice the receiving brown connector that's part of the body harness to close the connection between the ECU and the fan controller. See below for those details
    Body Harness
    There is no practical way to swap the entire body harness between the two cars, so this part is going to involve a little splicing. If you could find a source for new pins, there would be no need to remove these wiring sections from the sedan - in fact, the S6 sedan wiring is already done! However, without the new pins, I de-populated the pins I'd need from the sedan body and brought them over to the Avant, grabbing as much wire as I could to use for splicing (I don't think it's possible to divorce from the body harness uninterrupted)
    Sep 26 2014
    Knoxville, TN
    Reassembly
    Honestly, you get the gist, but I hope you enjoy some pictures of it all coming together, cause I know I did
    Bonus shots of the "leftover" build, dubbed the Un-RS6
    Big thanks to everyone who helped make this project a reality! I'm really fortunate to have such generous friends. The swaps were completed in Ohio after I'd moved to Colorado, and the support of these wonderful people is what made every trip out to Ohio most effective, as well as enjoyable. The final stage of the swap spanned from Sept-Dec 2022, completed in about three weeks of working time, thanks to the efforts of the following:
    • Josh G.
    • Sara S.
    • Carlos J.
    • Eli B.
    • Jefferson B.
    • Nick C.
    • Mark D.
    • Eli A.
    • Jevon H.
    • Dylan K.
    • Michael L.
    • Austin T.
    • Konrad C.
    • Rachel M.
    • Ross E.
    • Eli L.
    • Evelin G.
    • Sonia C.
    • Thomas C.
    • Blair S.
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Alpaca Beige 2002 Audi Allroad 2.7T Auto with 3rd Row Seat, Avus Silver Oxblood 2003 Audi S8, Silver
    Portland, OR
    Quote Originally Posted by Aktapod View Post
    Reassembly
    Josh G.
    Sara S.
    Carlos J.
    Eli B.
    Jefferson B.
    Nick C.
    Eli A.
    Jevon H.
    Dylan K.
    Michael L.
    Austin T.
    Konrad C.
    Rachel M.
    Ross E.
    Eli L.
    Evelin G.
    Sonia C.
    Thomas C.
    Blair S.
    Just wow. Thank you for sharing that with us. Incredible! If I somehow pick up this 89 200 10V I’ve been eyeing, I’m hitting you up!
    Jun 23 2015
    Michigan
    This is incredible.
    Veteran Member Three Rings SoundEfx's Avatar
    Aug 29 2017
    2000 S4 - 2001 S4 - 2003 RS6
    PNW
    This is sick.
    Veteran Member Four Rings cu52's Avatar
    Dec 11 2008
    Denver Metro
    Amazing write up, Might have to use this one day!! Thank you for taking at the time to put that together.
    13 Tundra SUPERCHARGED
    01 B5 S4 Avant, C5 RS6, 18 SQ5
    Gone:
    03 RS6, 01 605 Tial Avant, 00 S4, 01 S4 Avant, 01 Imola, 00 Hibiscus, 04 4.2L Allroad 6 speed swap, 03 allroad, 04 Audi Allroad 6MT 2.7T ST3!, 04 Allroad TIP, 02 Allroad MT6 2.7, 08 Toyota Sequoia, 04 Audi S4 MT6, 01 S4 Casablanca White 6MT , 04 VW GTI 5MT, 03 A4 Avant 3.0 6MT, 09 Tundra CM, 11 Tacoma DC, 02 A4 Avant 3.0 Tip, 01.5 S4 Avant tip GIAC stage 3-, 00 S4 6mt
    Jun 19 2011
    Wow. WOW!!
    I love the red topped Thule box to go with. Is that the Thule 1600 or an 1800 model?
    Thanks,
    -Jeff
    current: '02 S6 Avant, light silver metallic/ebony, 6-speed w/JHM solid short throw shifter, B7 RS4 clutch & lightweight flywheel, ST coilovers
    previous: '99 A4 1.8Tqms, aluminum silver metallic/onyx
    Veteran Member Three Rings IbisB7stage2's Avatar
    Mar 20 2013
    Bay Area
    the stuff of legends. bravo and congrats! the peelers are a sweet choice too.
    ~John
    B7 A4 quattro 6spd, k04 w/ meth, PSS9 coils, S4 recaros, basically everything else
    C5 S6 Avant 6spd
    Sep 26 2014
    Knoxville, TN
    Thanks for the love! I've been meaning to put this up for two years, and I finally found the motivation to do so. Since they traded powertrains, the Avant has now covered 16k miles and the sedan 11k. They're actually both more enjoyable than before the swaps. The sedan was so well-composed, I used it to loan to family/friends when they come to visit. I really liked it, but the sedan is now sold to make room for new projects
    Now we'll see if I can get motivated to put something together with all the footage I've been sitting on.
    Quote Originally Posted by JTF View Post
    Wow. WOW!!
    Thanks,
    Good eye! I wanna say it's an 1800. It's actually not just for looks; I usually keep a canopy and camping chairs up there during the summer, and snow-shoes and skis for winter activities. Gotta keep the cabin clear for day-to-day!
    Veteran Member Four Rings SteveKen's Avatar
    Jan 11 2005
    Pittsburgh, PA
    Nice Job. This brings back memories when I did mine a long time ago.
    Steve
    2013 S6 • 2012 Q7 TDI S-line • 2010 GTI • 2001 Honda S2000 • 1977 Honda CB750 F2 • 1965 GMC 1500 WideSide
    Sep 26 2014
    Knoxville, TN
    ^One of the pioneers of both the Avant and manual swap! Glad to have ya drop in
    Sep 26 2014
    Knoxville, TN
    I was able to confirm this last weekend a little milestone in the "budget" manual RS6 process.
    The upper oil pan from a D2 or C5 belt 40V motor directly interchanges with the RS6 upper pan without any modification to the sump baffling or oil pickup. In fact, it even accepts the same lower oil pan. You would simply need to tap oil returns for the turbos, but it will line up the remainder of the missing bellhousing bolts.
    As an aside, this is not the same case for the later 40V belted motors found in the D3 (for example, BGK). For use with an 01E, these motors require the same starter modifications as the RS6, but the BGK oil baffling and pickup interfere with the C5 oil pan if you try a straight swap. It can be done, but requires swapping the C5 N/A baffling, oil pickup, and oil pump, as well as both the upper and lower oil pans from the C5/D2. This was the setup that was used on the sedan during the swap, because the S6 BBD motor had lost compression in #3 due to a broken valve spring, and I came across a very low mileage BGK that I converted to S6-spec.
    Senior Member Three Rings danspach's Avatar
    May 03 2011
    2001 911 turbo, 2007 VW Touareg, 2003 S6
    Hartsdale, NY
    There's entirely too much to address in this series of posts but ....well....DAMN.
    The density of info. Insane. I'll be reading this for weeks.
    I have to ask, though...is that a Quantum on the trailer?!
    - Dave
    ____________
    ‘86 BMW 535i
    '88 944 turbo
    '01 911 turbo
    '03 S6
    '07 Touareg (at least it's the V8!)
    Sep 26 2014
    Knoxville, TN
    Quote Originally Posted by danspach View Post
    Sorry, missed this reply! I appreciate everything you said!
    It is in fact a Quantum Syncro! You may notice a 5-cylinder engine in the background of a couple of the pics in this thread. As I ramped down the C5 project, I started up on a 3B swap on the QSW for a friend :) It's pretty neat - still a work in progress, but it's running around and it's a rocket! 2900lbs, AWD and a 400hp 5-cylinder.
