Hello everyone. I'm considering buying a 2019 SQ5 Prem +. Found a nice example locally with 55K on the clock, correct color and S Sport package. I've had a B8 allroad and a B8.5 A4 in the past as well as some VW products (couple of GTI's). With the SQ5 running a similar (I think) ZF 8 speed as my previous Audi's, what is the transmission service schedule in the SQ5? I know a fluid change at 35K was part of the factory service schedule on the allroad/A4. Is it similar in the SQ5? I've done a fair amount of research and understand the stock mapping of the SQ5 trans is a little sloppy. I do plan to get a stage 1 ECU flash and a TCU flash to boost the power a bit and clean up the transmission. Sway bars and motor mounts will probably be in the works too. I'd be happy at that level of improvement all around.
I maintain my vehicles myself and am religious about proper maintenance and preventative maintenance. All of my Audi/VW products have been rock-solid reliable. Can I expect the same from this newer generation SQ5? What has your experience been in terms of maintenance and reliability? Anything to pay particular attention to or common faults? The only thing that irks me a bit is the adaptive air suspension...sounds expensive... If anyone has info on the factory recommended services (35K service, 60K service etc etc.) would you mind sharing? Appreciate the help!
