Results 1 to 2 of 2
    Mar 25 2019
    C5 S6 Avant 6-spd, Q7 3.0T
    Venice, CA
    2017 Q7 3.0T 50,000 mile service - What do I need to know?
    Clock just ticked 50,000 miles, and I'm gearing up for service, so I'm looking for guidance on maintenance outside of the recommended service intervals from Audi.
    I've had the car for 3 years, and have added 20,000 miles (I bought it with 30,000 miles)
    Until now, I've followed the Audi service intervals with an oil change at 40,000 miles. Also at 40,000 miles I replaced the water pump (due to failure) and front brake pads and rotors which were completely worn down.
    Now at 50,000 miles, I will perform the recommended oil change, but what else is recommended here in the community that has been learned at potential weak points?
    Also, should I start changing oil every 5,000 miles?
    Thanks for your help
    Veteran Member Four Rings littlewhite's Avatar
    PNW Rainy States
    I believe odd intervals are minor service so just oil and filter change and inspection. I just hit 60k and did oil/filter change, air filter, spark plugs, cabin filter. Brake fluid looks fine and havent had time to do the belt yet
    Littlewhite
