Results 1 to 14 of 14
    Junior Member One Ring
    May 26 2024
    Steering Wheel Heater
    Hello all.
    I have a 2021 S4, trying to turn up the heat on the steering wheel.
    OBD11 wouldn't do it, it just said failed, customer support couldn't do anything.
    Carista, although it changed a lot of things, won't bring up the steering wheel section in the app.
    There customer service people wrote:
    "Unfortunately, I can tell you that your car doesn't support the coding for Use steering wheel temperature"
    I believe my software on the car is up to date, does anyone know if the dealer or a mechanic with a different machine can make the adjustment?
    Thank you.
    Veteran Member Three Rings E.Anderson's Avatar
    Jun 23 2010
    Oswego, IL
    Adjust Heated Steering Wheel Temperature
    Description: Adjusts heated steering wheel temperature (Default 34)
    16 - Steering Column Electrics
    Adaptation
    20527 - steering wheel heater
    Adjust all 3 to be the same
    If i remember correctly you don't want to go more than 36c or you can risk damage.
    2021 S4 | PREMIUM PLUS | MYTHOS BLACK | ALU OPTIC | SPORT DIFF | B&O | LEATHER
    Previous
    2018 S4 | PREMIUM PLUS | DAYTONA GREY | BLACK OPTICS | SPORT DIFF | B&O | LEATHER | JB4
    2011 S4 MT6 | PREMIUM PLUS | QUARTZ GREY | TITANIUM PACKAGE | ROC EURO | LED INTERIOR | SPORT DIFF | B&O | LEATHER
    2008 A4 SE
    May 26 2024
    Thank you.
    Are those headings found on the more expensive readers a mechanic or the dealer would have?
    I don't recognize seeing any of those descriptions on the OBD 11 or Carista readers.
    I sent the OBD 11 back, it wouldn't really do anything, the Carista at least let me turn off the Auto Stop and a couple of other things.
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    Likely only visible on scanners that understand Audi speak - RossTech VCDS or OBDeleven.
    Current:
    2017 B9 A4 Technik, 2.0T, 6 spd manual, S-Line, quattro with Ultra
    2008 B7 A4 Avant, 2.0T, 6MTQS, S-Line, Special Edition
    Past: - 2005 B6 A4 3.0 V6 6MTQS, 1998 B5 A4 2.8 V6 5MTQS
    Feb 18 2023
    Baltimore
    I used OBD11 to adjust the heat level on my 2019. Not sure if that functionality is hidden behind the subscription (I have one), but suspect it may be.
    As mentioned above, you will need a tool that can navigate and code VAG-specific functionality. VCDS and OBD11 both do.
    Aug 16 2018
    NoVA
    You have to open the hood when you do it as well or it won’t work
    Jun 23 2010
    Oswego, IL
    I used OBD11. You don't use the apps, you go into the adaptations and make the changes.
    Previous
    2008 A4 SE
    May 26 2024
    Had the OBD 11 and bought credits, I managed to get my heat for my seats increased. Ran a complete scan, saved a backup and sent it through to customer service. After that, I would click and hold the icon like they request, it would just come back failed.
    Ignition on, hood wide open, nothing I tried would work.
    On the Carista, I managed to change a bunch of things, including getting rid of the Auto Stop.
    Returned the OBD 11 back to Amazon, wasn't impressed.
    Jun 23 2010
    Oswego, IL
    Sounds like you don't understand how coding works. You never needed to buy credits.
    Previous
    2008 A4 SE
    May 26 2024
    I bought the "free" OBD version that you had to bought a credit to make a single change. According to their customer service, their product would not support changing the steering wheel temperature.
    Perhaps you could give them a call and straighten them out.
    Established Member Two Rings schubby333's Avatar
    Dec 16 2016
    2012 A4 Avant, 2000 Corvette
    Madison Heights, MI
    I bumped mine up to 36 degrees and it's still not anywhere warm as it should be. Need to try bumping it up some more to see if it actually generates any decent heat. This can be done with VCDS. Thread:
    https://www.audizine.com/forum/showt...1#post14790774
    2022 SQ5 Prestige, Sport, Black Optics - Daytona Gray
    2012 A4 Avant Prestige, S-Line, Black Optics - Glacier White, IE Stg 2
    2000 Corvette - Navy Blue
    Jan 16 2007
    Have you checked the temp of the steering wheel compared to the setting?
    May 26 2024
    Thank you for the help, I have already purchased two readers with no success, I am just going to wait until I take the car in for service and hopefully they can do it.
    May 26 2024
    Thank you for your reply, I could tell on the OBD 11 that it was set right in the middle of the available temperatures, just couldn't do anything about it.
