Unfortunately the gasket on the new oil separator seems to be leaking. Cleaned the mounting surface before installing and bolts are tight. Any thoughts?
As I did a piston soak and replaced plugs in an attempt to reduce oil consumption, I decided to replace the oil separator at the same time.
