As to APR stage 3 spool, here's my experience.
I tested from ~1,500 rpm till ~6,000 rpm at WOT except for "standstill" (= red line of 7,200 RPM). I charted RPM, specified pressure and actual pressure. When the latter two are equal, I presume the turbo has spooled and noted the RPM. Here were my results:
Standstill: never (actual pressure only reaches ~70% specified pressure )
1st gear: 6,000 RPM
2nd gear: 4,600 RPM
3rd gear: 3,400 RPM
4th gear: 3,000 RPM
Not sure how tuners are testing for it.
As to the original (original) question, a larger turbo will take longer to spool, push the powerband up the RPM range and in this case, have a higher red line. Without lower/different gear ratios, the vehicle will be less responsive and spend more time in each gear. It's still completely daily drivable for sure but feels like a different vehicle when it comes time to hit the go pedal - much longer 'legged" if you will. When fully on the go pedal for an extended period (such as a 1/4 mile or 60-130 mph run, there is no discernable decrease in responsiveness - she goes like hell!).
