Thread: Carbon Cleaning
    Dec 10 2011
    Carbon Cleaning
    Can anyone confirm that engine need to be dropped to perform carbon cleaning on B9 RS5? At 64K and starting to have rough start sometimes when cold or already warmed up. No misfires or codes. Happens on E85 and 93.
    TIA
    Veteran Member Three Rings Dan99's Avatar
    Feb 09 2019
    Chicago Area
    Quote Originally Posted by knee_dragger View Post
    TIA
    Have you done the 60K service, which includes air filter and spark plugs? My B9 RS5 ran better after that service, including the idle.
    Dec 10 2011
    Quote Originally Posted by Dan99 View Post
    Yes, all service has been completed.
    Mar 26 2010
    US
    Most likely one would need to pull EA839 engine to clean the intake ports mechanically, unlike the EA837.
    The newer engines might have less carbon cleaning need, but apparently Audi thinks it is still an issue, if one checks the latest TSB, link below.
    I saw this updated TSB for Carbon clean today; Engine does not run smoothly at idling speed - all TFSI engines, 2075530/1 October 8, 2024.
    All Audi Vehicles 2005 – 2024
    >>>> https://static.nhtsa.gov/odi/tsbs/20...09928-0001.pdf
    "Customer states:
    • Engine does not run smoothly at idling speed after cold start.
    Workshop findings:
    • Sporadic misfiring logged in event memory of engine control unit.
    • The above complaints occur more frequently on vehicles that are primarily used for short drives.
    Technical Background 1
    Deposits in inlet ports and inlet valves.
    Service
    Clean the inlet valves/ ports by walnut blasting.
    The cylinder head does not have to be removed. Remove only the intake manifold/ compressor and clean according to the repair instructions.
    Granulate blasting unit VAS 294 011
    Granulate VAS 294 011/8"
    The combustion chambers & injector location are different on the B8 vs B9 V6. See combustion chambers below, older B8 design on top, newer B9 on the bottom. Also valve timing is different.
    BMW M3 Competition X-drive
    Mar 26 2010
    US
    It looks like Audi has issues with gasoline additives for carbon cleaning;
    TSB Service Info: Use of fuel additives not permitted - EA839 V6 TFSI, 2075515/1 October 8, 2024.
    https://static.nhtsa.gov/odi/tsbs/20...09920-0001.pdf
    "S4, and SQ5 2018 – 2025
    S5, S5 Cabriolet, and S5 Sportback, 2018 - 2024
    RS 5 2018 – 2019, 2021 – 2025
    Customer states:
    Various customer statements can be mentioned, such as:
    • Increased oil consumption.
    • Engine not running smoothly.
    • Engine maintenance requested.
    Workshop findings:
    Various workshop findings may be confirmed, such as:
    • Carbon deposits in combustion chamber or on injector nozzles, visible using a borescope.
    • Misfiring.
    • No complaint can be determined (“engine maintenance”).
    Fuel additives can help remove carbon deposits in the combustion chamber, in the area of the piston rings, or in the area of the injection nozzle, for example. However, a negative impact on the engine life cannot be ruled out.
    Service
    The use of fuel additives in vehicles equipped with the EA839 V6 TFSI engine is not approved and therefore also not permitted."
    ...................I see another interesting TSB.... it appears to be generic, since discusses the older engines.
    MIL on (gasoline quality), DTCs for misfire, air/fuel ratio imbalance, or lean fuel system stored in the ECM P300000
    2014753, rev 12, February 6, 2023.
    All Audi Vehicles 2000 – 2019
    https://static.nhtsa.gov/odi/tsbs/20...31590-0001.pdf
    "The use of contaminated gasoline or gasoline with a low content of deposit control additives may result in one or more of the following conditions:
    • Excessive accumulation of deposits on intake valves, intake manifold, fuel injectors, and combustion chambers.
    • Engine running rough after cold start.
    • Excessive engine cranking time.
    • Hesitations while driving.
    • Rough engine idle.
    • Reduced engine performance.
    • Poor fuel economy."
