Hi all,
I'm dealing with a no-crank, no-start situation on my Audi. Unfortunately, I don't have VAGCOM but am using OBD 11, which isn't ideal, but it's what I have for now.
The situation:
I made a mistake by leaving my windows down during a severe rainstorm. To make matters worse, I also left my keys in the ignition (accessory mode, engine off). By the time I realized this, the battery was completely drained. It took multiple attempts and three different vehicles to jump-start the car.
On the third attempt, when I tried starting the car, the dash went haywire with flashing error messages and lights, and the electronic parking brake (EPB) cycled on and off several times. On the fourth attempt, the car finally started, and I drove it home. However, I noticed significant power loss, especially under load, and the RPMs were limited, which I assume was "limp mode."
The next day:
The car wouldn’t start again, though everything else (lights, dash, MMI, etc.) seemed to be working. When I try to start the engine, there's just clicking under the steering column.
What I've done so far:
Checked fuse boxes (driver's side, passenger side, under the wiper plenum, and trunk) – everything looks good.
The alternator tested as weak but still functional.
Installed a new Bosch starter.
Replaced the battery with a new H8 AGM battery, which shows 13.9V on the multimeter.
Checked all grounds; they look good. However, the ground near the wiper fluid cap (under the plenum) is sitting in a small puddle of water and some gunk, though it appears intact.
I realize I could take the car to a shop, but I have other means of transportation and don’t currently have the budget for that. Since I’m mechanically inclined and have completed all the work mentioned above without issues, I'm prepared to keep working on this for as long as it takes.
I'm getting frustrated but I know from past Audi ownership experiences that sometimes it’s just a silly module triggering the other codes. It is a beautiful example of an A6 with a lot of preventative service done, dealership maintained from new to 102K, that's when I received the car from my father and continued with extensive preventative services the car now sits at 175K. I understand that I will have to call it quits at some point.
When this first started, I scanned the car and got 50+ codes. After installing the new battery (which I coded correctly) and clearing the codes, I rescanned and now only have 4 codes left. As shown above.
Any advice or suggestions would be greatly appreciated.
Thanks in advance for your help!
