Howdy, any wisdom about root cause of my mystery problem that is growing in # of error codes?
My 2017 Audi SQ5 (B8) has just over 63k miles on the clock.
Accelerating with more than 10% throttle caused immediate CEL -> To begin with I only received PCV valve error, then random misfire came shortly after.
At that point I pulled compressor to inspect, noticed intercooler leak with coolant residue in the intake -> did a major service to replace:
PCV assembly + the TSB about the little boot on the vacuum line next to it.
Also replaced both intercoolers, cleaned intake from coolant residue buildup, 6 new spark plugs, new water pump, new belt and new pulley/tensioner.
No more misfires after that, but the PCV error keeps coming back under acceleration more than 10% throttle, then it started adding intermittent knock sensor errors, and yesterday I now also got Secondary Air Injection System error codes as well.
Carefully inspected the plastic pipes under the compressor, they looked good, but those pipes are known to fail, so certainly keeping them in mind.
*** Found out today that the PCV error comes in separate from the other errors and doesn't trigger CEL light on dash ***
Exec summary:
PCV error + Knock sensor 2 + Secondary Air Injection System: Bank 1 & 2:
Error Code Summary
20136 - PCV Valve Malfunction - P052E 00 [01101101] - Confirmed - Tested Since Memory Clear
9542 - Knock Sensor 2 (G66) - P0332 00 [11101100] - Signal too Low
9544 - Knock Sensor 2 (G66) - P0331 00 [01100000] - Implausible Signal
17619 - Secondary Air Injection System: Bank 1 - P0491 00 [01100000] - Insufficient Flow
17620 - Secondary Air Injection System: Bank 2 - P0492 00 [01100000] - Insufficient Flow
Full VAG-COM details:
5 Faults Found:
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 102214 km
Date: 2024.10.12
Time: 12:25:11
Engine RPM: 1866.00 /min
Normed load value: 14.1 %
Vehicle speed: 16 km/h
Coolant temperature: 19 °C
Intake air temperature: 23 °C
Ambient air pressure: 830 mbar
Voltage terminal 30: 12.593 V
Unlearning counter according OBD: 37
Engine speed: actual: 1856 /min
MAF_ENVD: 217.88235 mg/stroke
Coolant temperature (unfiltered): 19.50 °C
Engine: operating status: PL
Battery voltage: 12.593750 V
STATE_LS_ENVD[1]: 2
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 102214 km
Date: 2024.10.12
Time: 12:25:11
STATE_LS_ENVD[1]: 2
P052E 00 [01101101] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 101988 km
Date: 2024.10.07
Time: 09:20:08
Engine RPM: 705.00 /min
Normed load value: 12.2 %
Vehicle speed: 0 km/h
Coolant temperature: 94 °C
Intake air temperature: 35 °C
Voltage terminal 30: 14.319 V
Unlearning counter according OBD: 40
Engine speed: actual: 704 /min
MAF_ENVD: 163.41176 mg/stroke
Coolant temperature (unfiltered): 94.50 °C
Engine: operating status: IS
Engine load: 13.281250 %
Vehicle speed: actual: 0 km/h
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 102083 km
Date: 2024.10.09
Time: 09:24:44
Engine RPM: 2879.00 /min
Normed load value: 73.3 %
Vehicle speed: 39 km/h
Intake air temperature: 36 °C
Ambient air pressure: 840 mbar
Voltage terminal 30: 12.695 V
Engine speed: actual: 2880 /min
MAF_ENVD: 234.22352 mg/stroke
Coolant temperature (unfiltered): 95.25 °C
Engine load: 15.625000 %
Vehicle speed: actual: 57 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Mileage: 102066 km
Date: 2024.10.09
Time: 09:01:20
Engine RPM: 2419.00 /min
Normed load value: 58.8 %
Vehicle speed: 61 km/h
Intake air temperature: 39 °C
Voltage terminal 30: 14.015 V
MAF_ENVD: 512.02352 mg/stroke
Coolant temperature (unfiltered): 96.75 °C
Engine load: 35.156250 %
Vehicle speed: actual: 73 km/h
Readiness: 0000 0100
