The donor vehicle is a 2000's A6 C5 1.8t, with code AWT (block 06B, vvt + wideband). I have the complete engine, complete harness and control unit. I have already adapted all the physical differences between a 058 and 06B block (coolant pipes, etc) and I have cancelled the immobilizer of the engine control unit (ECU).
Both engines are with electronic throttle, my question is the following:
Is Plug & Play the connection between the colored connectors of the harness to the colored connectors of the car? and... Do you know where I can find a pinout or something similar for the colored connectors? I have only found for a4 b6 from 2003 onwards (which are not the same).
APU colored connectors of the harness:
AWT colored connectors of the harness:
Colored connectors of the car:
And the car with both engines
Some wires that are in the APU harness are not in the AWT and vice versa, only the black connector is exactly the same in both harnesses. I understand that the differences between one and the other are the management of the 2 lamps and the ignition without ICM isn't it?
If you want, when I finish the SWAP I make a post of the project. My idea is to end up with a A4 STW look.
Best regards and thanks!
