Originally Posted by
SanClementeMike
@smac770 Thank you for this detail. Is there any truth to what I'm hearing that there are two types of pans and filters for these ZF's? If so, do you know if there is anyway to tell without having to remove the cover and look under the car?
ZF has always had both plastic pans with integrated filters and metal pans with separate filters for the 6HP and 8HP transmissions. But you don't care about the dozens of different transmission configurations ZF has made of the 8HP. You own a B8 A4 8-speed Tiptronic (vs the "8-speed multitronic" which is FWD using a CVT), so the only transmission of concern is the ZF 8HP55A, what Audi calls the type 0BK. Anything about anything else is irrelevant. The 0BK has a metal pan and separate filter. Audi already states the proper Audi p/n for the service: 0BK398009A (gasket, filter, bolts).
https://www.ecstuning.com/b-genuine-...it/0bk398009a/ But it's usually better to look around for OEM (ZF) parts instead of the extra cost of Audi's approval:
https://www.fcpeuro.com/products/aud...-zf-0bk398009a It appears to include new drain and fill plugs too, which is bonus.
And the 0B6 that came first in MLB (Audi AL651-6Q aka ZF 6HP28AF) is the same as the 0BK: metal pan, separate filter. Audi switched their ZFs to the plastic pan with integrated filter for MLB evo. The Audi DCT is a completely unrelated transmission design.
