Results 1 to 9 of 9
    Junior Member Two Rings
    Dec 30 2021
    Edinburgh
    Audi A6 C7 MMI Upgrade
    I have a 2014 A6 Allroad and I would like to upgrade the MMI to the facelift version to enable carplay, I don’t like aftermarket kit so would rather avoid the rsnav style versions and go for the full OE setup if reasonably possible!
    Has anyone done this?
    Feb 08 2023
    Ohio
    The C7.5 facelift MMI is incompatible with the pre-facelift C7 MMI so upgrading is not a possibility. Your best bet to get carplay and be “as OE as possible” is to get an aftermarket wireless carplay/android auto box that daisy chains off the center MMI unit and can be stowed behind the glovebox. Once installed, switching to carplay with one of these is a simple as holding down the NAV button.
    https://www.ebay.com/itm/38531597283...mis&media=COPY
    2014 A6 Prestige
    Dec 30 2021
    Edinburgh
    Thanks bud but thast what i'm keen to avoid as I don't like aftermarket kit, i'll research whats different about the facelift MMI vs the pre facelift and transplant the necessary parts into mine and update the thread
    Veteran Member Four Rings MyDimeIsUp's Avatar
    Dec 04 2019
    West Chester, PA
    When there's a will, there's a way. However I agree that the aftermarket CarPlay box would be the best option. I used one on my previous B8 allroad and currently use one for my C7 A6. Takes about an hour to install, and all you have to do is hold the "menu" button and it'll switch to CarPlay. Never had any problems with either of them and they cost about $190 from AliExpress.
    2020 BMW M340i xDrive - Mineral Grey
    2012 Audi A6 3.0T Prestige - 034 Stage 1 ECU and TCU | CTS Turbo Intake | 034 Street Density Motor Mounts w/ JHM Trans Insert | ECS X-Pipe
    2013 Audi allroad - RIP
    2007 Toyota corolla
    Feb 08 2023
    Ohio
    Have fun throwing money away! There’s a reason these aftermarket mods exist - because it is not cost effective or practical/possible to upgrade the entire MMI system.
    2014 A6 Prestige
    Dec 30 2021
    Edinburgh
    What is required to make this swap that makes it so expensive?
    Dec 30 2021
    Edinburgh
    Someone has to be the first!
    Feb 08 2023
    Ohio
    If you’ve got the time and resources to do it. Go for it! I’ll happily eat my words if you get it to work.
    2014 A6 Prestige
