I have noted for the past couple weeks that are cold starts, it now takes two turns of the key to get the car started. On the first turn, it starts but then dies, but are always starts and keeps running on second turn. Can has no driving issues when finally running. Could this be a sign of the primary or secondary fuel pump started to fail. I check the vacuum seal on the FPR to make sure if was not leaking on loosing pressure when car off. I get the feeling that when the car is off for a while the fuel pressure does not build up enough to turn car over on cold start with first turn.
