I have read A LOT of forum posts regarding issues with MMI and the joys of troubleshooting precisely what the problem might be.
After checking connections, wiring w/ fiber loops, etc. I decided, based on everything I was reading, to purchase a used MMI head unit that matched the model, etc., and replace it.
After the replacement, I saw the following along with the CP, which I know I must have cleared. Still, before I go and do that, I wanted to know if the other items listed in the VCDS scan below are indicative of the CP or held over from my issue with MMI that will likely not be resolved once I get the CP cleared. Thank you in advance for any input.
Scan from original MMI:
Code:
4 Faults Found: 00658 - Control Head 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 220 Mileage: 116920 km Time Indication: 0 Date: 2024.08.28 Time: 16:50:05 Freeze Frame: Voltage: 14.30 V 02071 - Local Databus 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 220 Mileage: 116920 km Time Indication: 0 Date: 2024.08.28 Time: 16:50:02 Freeze Frame: Voltage: 14.20 V VCDS Diagnostic Trouble Code Report Control Module Part Number: 8R1 035 746 K Page 2 02259 - Information Display and Control Head (Front) (J685) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 220 Mileage: 116920 km Time Indication: 0 Date: 2024.08.28 Time: 16:50:04 Freeze Frame: Voltage: 14.20 V 02259 - Information Display and Control Head (Front) (J685) 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 220 Mileage: 116920 km Time Indication: 0 Date: 2024.08.28 Time: 16:50:04 Freeze Frame: Voltage: 14.20 V
Scan from replacement MMI:
Code:
5 Faults Found: 00658 - Control Head 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 220 Mileage: 116920 km Time Indication: 0 Date: 2024.08.28 Time: 15:36:49 Freeze Frame: Voltage: 13.90 V 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 4 Fault Frequency: 1 Reset counter: 220 Mileage: 116920 km Time Indication: 0 Date: 2024.08.28 Time: 15:36:47 VCDS Diagnostic Trouble Code Report Control Module Part Number: 8R1 035 746 K Page 2 02071 - Local Databus 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 220 Mileage: 116920 km Time Indication: 0 Date: 2024.08.28 Time: 15:36:47 Freeze Frame: Voltage: 14.00 V 02259 - Information Display and Control Head (Front) (J685) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 220 Mileage: 116920 km Time Indication: 0 Date: 2024.08.28 Time: 15:36:50 Freeze Frame: Voltage: 14.00 V 02259 - Information Display and Control Head (Front) (J685) 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 220 Mileage: 116920 km Time Indication: 0 Date: 2024.08.28 Time: 15:36:50 Freeze Frame: Voltage: 14.00 V
