Results 1 to 31 of 31
    Aug 15 2024
    Fort Lauderdale
    New 2024 RS6 has 3 defective tires.
    Hello, I just picked up my RS6. Has about 150 miles on it. Took it on the highway for the first time. Noticed a nasty shaking at 70-80mph. Took it to the dealer and told them to check the balance on wheels. They called me today said that 3 of 4 tires have "excessive road force" and need to be replaced under warranty. Has anyone ever heard of this happening from the factory. Owned many new cars and never had this issue.
    Sep 11 2011
    2022 RS7 & 2201 TTRS
    DFW
    It happens.
    Had an 2019 RS5 that had one tire with over 40 lbs of road force new, which is insane.
    Had an 2021 TTRS that came from the factory with Pirellis that would not balance and had a constant vibration around 75, they balanced several times and could not get it to fully go away.
    These low profile tires and tight suspensions are extremely sensitive to road force. Ideally you are looking for single digit road force, but in reality under 12/15 lbs is good for all but the very sensitive drivers.
    It's a pain in the ass but it happens. The car didn't sit long did it? Long term non use can cause flatspotting, but I'm willing to bet a new RS6 never sat in one place too long.
    Insist that they road force the replacements and ask to see the road force values. Like I said you are looking for below 10 lbs, but if you end up with some slightly above have them put those on the rear. There are a lot of places that say they road force, but often do a quick job and don't do it fully right. Best way to tell it was actually done is to see some form of colored marks on the tire and rim matched up. that means the tech actually rotated the tire on the wheel to match the high point of the tire with the low point of the wheel.
    2022 RS7 & 2021 TTRS
    Retired: Macan S, 2019 RS5, 2020 TTS, 2019 S4, 2017 TT, 2014 A6 TDI, 2014 S4, 2011 A4 Avant, 2011 Audi TT Roadster
    Oct 08 2012
    Bloomfield Hills
    IT has happened to two of my BMWS but not Audis. It can happen with new tires if they were not inflated properly before transport and sitting too long. At least Audi dealer found the excessive road force and will replacement. TBH Pirellis are trash tires. I prefer Michelin Pilot Sport 4S. Way more smoother and rounder with better handling ride feel etc. I always make sure all my tire/wheels are below 10lbs for cars and suvs for glass smooth ride.
    Aug 27 2007
    RS6, A7, CTS-V Wagon 6 speed
    Jacksonville, Florida
    10PSI for tire pressure?!!! Huh???
    Junior Member Two Rings
    Mar 14 2021
    10lbs, not PSI… they are talking about road force balancing, not tire pressure.
    Oct 08 2012
    Bloomfield Hills
    Quote Originally Posted by tinmanwpk View Post
    10 lbs of road force equivalent to .010 inch of run out of the tire and wheel assembly.
    Aug 27 2007
    Lol, thanks. I knew one of us was nuts. I resemble that remark!
    Oct 08 2012
    Bloomfield Hills
    All good! This is why we have these forums to help each other out etc.
    Aug 15 2024
    Fort Lauderdale
    So they replaced 3 tires and the car still vibrates. I'm getting very frustrated with it. The vibration is noticeable enough that it shakes the passenger head rest at 70-80mph
    Jan 14 2024
    Las Vegas NV
    Quote Originally Posted by TonyFLL View Post
    What manufacture tire? Continental, Michelin?
    Aug 15 2024
    Fort Lauderdale
    Quote Originally Posted by spyderbret1 View Post
    Continental
    Jan 14 2024
    Las Vegas NV
    Continental
    Wish I could help. I had a similar issue with the Michelin's on 2 other cars and didn't like them for a while but I had to put them on my car and they have been fine. Noisy but fine. I was planning on switching back to Conti's after they become more available and when my PSS4's get worn. If you had Michelin's then I wouldn't have been surprised.
    Oct 08 2012
    Bloomfield Hills
    Did they give the road force print outs? Make sure they are no higher than 10lbs run out. Some techs are lazy and accept the normal 26 lbs max but still anything in the 15-20s will vibrate these cars. I am sensitive and I can detect the minor vibration in my seats, steering wheel or even the passenger headrest. My RS7 is glass smooth up to 100.
    Senior Member Two Rings jmswashere's Avatar
    Jun 27 2013
    St. Augustine, FL
    There may be wheel bearing/other part damage from the prior vibration(s) apart from the tires. I would have them check everything.
    Current: 2023 Audi RS6 Avant - Daytona Grey; CCBs; Carbon Optics; AWE Exhaust; OEM RS6-P Bronze Wheels; APR Intake
    RIP: 2020 Ford Mustang Shelby GT350; 2017 SRT Jeep Grand Cherokee; 2014 Audi S4; 2015 Dodge Charger SRT 392; 2008 Audi S6; 2006 Nissan 350Z
    Oct 08 2012
    Bloomfield Hills
    Any updates on this?
    Aug 15 2024
    Fort Lauderdale
    Quote Originally Posted by rexus300 View Post
    It's back at a diffrent dealer. Audi of Ft Lauderdale is the worst dealer I've ever dealt with so I took it somewhere else. The foreman went on a ride with me and they called me the next day. The car needs 2 new tires again. This time both rears. One which already replaced and the other that wasn't replaced the first time around. Crossing my fingers this is the problem. If not idk what's next.
    Aug 27 2007
    Lemon Law.
    Aug 15 2024
    Fort Lauderdale
    Lemon Law.
    Believe by my state law it requires 3 visits for the same issue. So one more visit
    Feb 02 2013
    Does anyone have like a really loud and annoying popping/clunking sound coming from their front tires when steering on dry pavement? I can hear it the most when dry steering while parked. When it rains noise disappears.
    Had a similar noise from another car years ago and I was conceived that it was the suspension but it ended up being tires again.
    Sep 29 2008
    Quote Originally Posted by georgy View Post
    Do you mean when stopped or going very slowly, especially on cold tires? My 911s all do that.
    2024 AE RS6
    2023 M3 Competition
    2019 Porsche Speedster
    2019 MB C300 Wagon
    2010 911 GTS
    Feb 02 2013
    Quote Originally Posted by STALKER View Post
    Yea exactly, what the hell is that?
    Sep 29 2008
    Combination of suspension geometry at full lock and cold tires.
    Should only happen with cold tires, they are kinda skipping across the pavement.
    2024 AE RS6
    2023 M3 Competition
    2019 MB C300 Wagon
    2010 911 GTS
    Aug 27 2007
    It's a crabwalk.
    Feb 02 2013
    No, mine does it cold or hot tires and the steering doesn't need to be at full lock either.
    Sep 29 2008
    lol, you on your own then.
    What model year is your car, tire/wheel combo?
    2024 AE RS6
    2023 M3 Competition
    2019 MB C300 Wagon
    2010 911 GTS
    Sep 11 2011
    DFW
    Google Ackerman effect/principle. Really noticeable for me when your wheel travels over the painted parking lines since those have less grip than the surrounding pavement.
    Porsche 911 folks are very familiar with it!
    Completely normal!
    Feb 02 2013
    2023 I have the P zeros on 22s
    Nov 01 2011
    yyc
    if you replace all the tires and it's shaking it's not the tires, but wheel
    brakes if it shakes under braking, axles if it shakes under acceleration
    even having center bore off by 0.5mm inside the wheel will cause a shake because the rim doesn't sit perfectly center on the hub, so tire balancer will see balance but when u put it on car it shakes
    you can try finding someone who does dynamic balancing aka on the car, but for a brand new car that's crazy, older cars fine
    i had vibration nobody could fix on older vw, went to this magician he balances the wheels on the car speeds them up to 80mph and hooks up oscilloscope to car frame to pickup any vibrations
    car is smoother than a maybach now LOL
    Oct 08 2012
    Bloomfield Hills
    Quote Originally Posted by suffeks View Post
    We just discussed road force balancing not dynamic balancing. The tires are defective and 2 of them are out of tolerance. I never do dynamic balancing always road force balancing for low profile tires and rims. However the old school high speed balancing does not work anymore with these kind of cars. Its very rare for hub to be off on new cars and brakes or axle problems are less than 1% of the issues.
    Nov 01 2011
    yyc
    Hunter road force couldn't help me, this is what I had to do https://youtu.be/7UP97bO-MpU
    Oct 08 2012
    Bloomfield Hills
    Hunter road force balance is the best out of everything and the machine can only be as good as the tech using them. I have had great success with them for the past 15 years on all of my cars and the right tech.
