I'm in the middle of a timing chain replacement and was getting ready to put the covers on when I noticed the crank pulley bolt was suddenly not as easy to remove by hand. I had been using the nylon washer and had switched to the pulley to verify timing marks. I'm worried that when I released the pin on the tensioner, the crank bolt may not have been on tight enough as it took maybe half a turn with socket before the sprocket would move (when I went to rotate the engine over a few times and check timing).
The symptom - crank bolt is too tight to remove by hand, need to use a socket until it is about halfway out, then can use hand. The bolt goes from being loose/easy feeling for about half a turn to being harder to turn. This makes me think that the sprocket hub may not be totally flat. Previously when taking the bolt out I could thread it all the way by hand and tension was uniform.
Should I pull everything back off and reseat the sprocket or will torquing down the pulley be sufficient? I can't tell if I'm being paranoid / overly cautious or overreacting.
