Long time lurker, first time poster. Sharing in the spirit of goodwill to fellow enthusiasts. I have a 2013 B8.5 A4 with ~140k miles with an APR stage 1 tune for the last ~100k. In a minimum effort attempt to resolve a P0299 underboost and P0499 catalytic efficiency code (and also to get rid of the factory cat) I purchased a CTS HFC. During this installation I discovered the real reason for the P0299 code was a loose wastegate (the ineptitude of the OE design baffles me), as well as a crack in the turbo housing and excessive side play in the turbine. As such, after not a whole lot of research due to a compressed schedule, I purchased a CTS K04 (CTS-TR-1070) from ECS for $1500 because a) it was cheaper than an OE turbo and b) ‘mo power baby! And thus our story begins. I couldn't get the forum image attachment tool working so here is an imgur link to an album of relevant photos.
Now, as I’m sure many of you are aware a turbo job on these cars can be a long and tedious process that will test your patience and mechanical skills, so I was happy to have my father to help. We are both engineers and not lacking in mechanical ability, but neither turn wrenches for a living (anymore). Evidently, Audi did not design this car to be serviced with the engine in the car. Half a dozen bolts are so difficult to get to they require contorting your hands and an assortment of low profile bits, ratcheting wrenches, universal joints, etc. For example, we had triple squares that had bits fitted to sockets. These were found to be too long. Hence we used the bit alone with a 10 mm ratcheting box end fit over the bit to be able to work in tight spaces. Stubby type triple square bits may have made life a lot easier.
As my mother always says, best to start off with something positive. This turbo still spools quickly, has plenty of power, and is great value for money in terms of performance. This car should come with a K04 from factory. Obviously I can’t speak to the longevity of the CTS turbo but I have had no performance or reliability issues in the short time it’s been installed.
With that said, first impressions were not good. Upon opening the box, (packaged well, good job ECS) I discovered a badly kinked hose from N75 valve to the wastegate actuator. This carelessness in assembly could’ve been prevented by using a longer and/or stiffer hose. The hoses do not seem to be of poor quality, but are significantly softer than the factory hoses which lends itself to kinking. After emailing ECS support and receiving no reply (still no reply 4 days later, bad job ECS), we went and got some fuel line hose to substitute, replacing the PITA ear clamps with hose clamps. Unsure the unbranded N75 valve was good to go, we considered swapping with the original, but decided against it considering the original had 140k miles on it.
After the disappointment with the hoses, the instructions we found just about useless, lacking detail and what steps are included don’t seem to follow reality. No torque specifications are provided. I found an FCPEuro video of replacing a turbo which was much more thorough. The instructions did include a rather humorous final step of essentially “put everything back”. There is also no mention of using a turbo oil additive in the instructions which is prudent.
It was at this point we discovered the CTS kit did not include the requisite number of gaskets, washers, or o-rings to reinstall the lines to the engine block. Lesson learned; inventory all parts of a “kit” when purchasing.
The design of the CTS turbo also requires modification of factory components. The oil inlet on the turbo casting lacks the raised boss present on the OE turbo, causing the line to be out of place. This necessitates a modification of the bracket holding the oil line to the coolant line to avoid straining the lines. Additionally, the CTS turbo lacks a mounting hole for the bracket securing the coolant line by the timing chain cover. This later caused a problem as the line was slightly out of position necessitating a perilous repositioning of the line and retightening of the banjo bolt facing the block with the turbo installed.
Speaking of installing the turbo, replacement lower manifold nuts were not supplied. The top manifold nuts were not flanged like the OE. The middle forward lower manifold nut was very difficult to tighten as the CTS casting is different than original and the waste gate actuator rod location makes it difficult to get a wrench or socket on the nut.
We used the evac tool to fill the cooling system. Could only pull 12 inHg, hence a leak somewhere. Sure enough the outboard coolant connection on turbo, the one with the copper "spacer washer", was leaking despite being properly cleaned and torqued. Fortunately, it’s relatively easy to get to this banjo bolt. After removing the banjo bolt washers, annealing them, and reinstalling this time with a very thin coat of gasket sealant, we had no more leaks. At some point we had tried to call CTS customer service for advice, only to discover (despite multiple attempts) their phone will ring for a few minutes after selecting option 1 before playing a busy signal. Helpful. I believe this is still the case as of today so by all means someone let me know if you’ve been able to get ahold of them by phone.
All in all, while the installation and my first impressions of the turbo and CTS itself were poor, it appears to be holding up so far and a K04 with APR stage 3 is certainly a great improvement to the B8.5 platform. Thank you for coming to my ted talk. If you’ve made it this far, congratulations, and I would love to know if the CTS N75 valve is any good, or how the Rev9 ICK-085 FMIC compares to the ECS Luft-Technik FMIC.
TLDR: The CTS K04 itself appears to be good value for money but despite the way it is advertised is in no way a drop in ‘kit’ solution and requires modification and additional parts and hardware to complete the job; a problem worsened by lackluster instructions and support. Questionable quality control and design choices leave doubt for the longevity of the product.
If you order this "kit" you will ADDITIONALLY need:
-Coolant line washers for banjo bolt (N0138149)
-Oil line gasket (058145757C)
-Oil line o-ring (N90067202)
-Manifold Nuts with flange (N91130801)
-Manifold studs (depending how busted your old ones are) (N0145555)
