Hello all
The A/C stopped working one day out of the blue, straight to ambient+ temp air. I did some diagnostics, and the high and low side pressures were just about the same, around 80 psi (in 75F ambient temp if that matters). No codes, no blown fuses anywhere in the car (even though I never found a fuse designated for A/C). Knowing more about electricity than car A/C systems, I unplugged the 2 pin connector on the condenser and measured the voltage across it. Toggling the A/C in the car shows battery voltage with the A/C on, 0V when off, telling me that the issue wasn't a sensor - the computer wanted the A/C on too. Knowing this and that there wasn't a difference in pressure, I thought it was either a bad compressor or clutch. I purchased a remanufactured compressor/clutch combo from R&Y and installed it, following the 30 mins of internet knowledge I'd obtained. The system maintained a vacuum for a couple hours, I filled the system, and voila, cold air. I filled the system to achieve the correct pressures (high and low) for the given ambient temperature, using a bit less than 2 12oz cans.
Then problems. I toggled on/off the A/C a couple times, and then it stopped being cold. No more pressure drop, no more cold air. I turned back to the connector for the clutch. Backprobing the 2 pin plug, only with it connected, showed a 7 volt drop across the compressor, not a 13V drop. I found the other 6 volts between the negative on the pin and chassis ground. Internet scouring for a few hours didn't present anything as to the terminal point of those two wires. Using an entirely seperate car battery and some leads, applying 12V across the compressor (bypass car issues and just engage the clutch) results in the sound of the clutch engaging, but the A/C still doesn't work. Doing this to engage the clutch, the low side drops about 10 psi slowly, then up 5. High side does not change, and the steady state still looks like the high/low sides 5-10 psi different.
Hoping to figure out where the 2 wires leading to the compressor clutch come from so I can either fix or replace. Also wondering what other component of the A/C system may be preventing the system from working. Wisdom regarding either would be very appreciated, as would an applicable wiring diagram.
(First post. Please take it easy on me.)
