So the story begins with i got this 2007 a4 quattro 2.0t that the previous owner just replaced the timing belt. Come to find out the timing belt tensioner was loose and you guessed it....belt came off and bent all the valves. Being that the engine had 200k i just set out to find a used engine. I found a good deal on a engine with 120k and swapped out engines. The issue i am having is the code p0022. I have checked and replaced the vvt actuator at the back of the engine, replaced the camshaft position at the front of the engine and have done two oil changes. The code will come back within about 4 mins of the car running. At idle it is a little rough with cylinder 2 showing occasional misfires. The leakdown test came back good as well. I verfied the actuator works with my scan tool and also verified 12volts. There is no chain noise as well even on a cold start. Could someone point me in some directions?
