Results 1 to 12 of 12
    Dec 10 2011
    P24D6 Error. Where is the G950 EVAP system pressure sensor located
    Hello,
    Just like the title states I asking if anyone knows where the G950 EVAP system pressure sensor switch B is located on 19 RS5 SB? I been getting the P24D6 34275 Evap system presssure sensor "B" circuit range/preformance error the last few days.
    TD1 and out of warranty....
    TIA
    Junior Member Two Rings
    May 06 2021
    I had this same exact code pop up a couple of times last year. It would self clear after a few days/start stop cycles.
    I was starting to research a potential faulty pcv hose/valve, but I asked my local euro shop guy and he advised me to never add any more gas after pump clicks off initially (just habitually, id squeeze a bit more in or get the total to a round number, very silly i know).
    Either this fixed the issue or it was a placebo and the real issue self corrected, as i haven seen the code sense.
    Jul 16 2018
    Atlanta
    G950 should be tank ventilation pressure sensor 1. It's on the engine, right bank cylinder head, just in front of the N80 EVAP canister purge regulator valve, right under the line coming forward from the N80.
    https://www.ebay.com/itm/375178102289
    If you go to pic 5 and look below the gray/silver heat wrap on bank 1, to the right of the HPFP, you'll see yellow and gray wires. Just below that is a gray locking tab for a connector. Might be that. The G950 wires on the DECA are yellow/blue on 1, brown/white on 2, brown/green on 3.
    But range/perf, could be any number of things. How nice of Audi to forget to document that P code in the EA839 generic scan tool workshop manual. So we don't know the specific metrics that trip that code.
    Dec 10 2011
    Quote Originally Posted by Smac770 View Post
    Thank you for the info and pics!
    Mar 21 2005
    2019 RS5 SB / 2025 SQ7
    RI
    I had this code as well. I replaced the solenoid valve and the MAP sensor connected to it. I guess if one or the other fails, it'll throw the same code. So I just replaced both rather than playing "guess the broken part." It was a super easy install.
    Here's a different thread on the issue.
    Part #'s are 06M133240CJ (solenoid) and 06H906052A (MAP).
    2019 RS5 Sportback - Nardo, Black Optic Carbon Package, 034 Stage 3, TTE720s, AWE downpipes, APR intake, Wagner IC/HX, 034 HPFP, ABT H.A.S., BBS CI-R, E-Codes, Bull-X res delete, 034 rear sway, 034 trans/subframe mounts
    2025 Audi SQ7 - Wife's daily
    2015 Audi S3 - Unitronic Stage 2
    2002 Porsche 911 Turbo - AMS billet K16's / EPL tuned
    2006 Trailblazer SS - bolt-ons
    2001 Audi S4 - EPL stage 3+
    Dec 10 2011
    Quote Originally Posted by Dr. Jekyll View Post
    Thanks. I had replaced 06M133240CJ about 6 months ago, but didn’t replace the MAP. I’ll give that a try.
    Sep 18 2019
    Vienna/VA
    Quote Originally Posted by knee_dragger View Post
    Did you ever resolve this? Dealing with the exact same issue and my local shop hasn’t been now to figure it out.
    Dec 10 2011
    Quote Originally Posted by Jonny1161 View Post
    Yes, replaced the hose and sensor. No more problems.
    Feb 25 2018
    Vancouver
    I am also having the same issue. Only comes up when I shift hard between gears.
    Anyone know if this causes power loss?
    Oct 22 2013
    Bicycles
    United States
    Where is the sensor? On the intake manifold? Are there two of them?
    Audi parts say the part 06H906052A does not fit the B9 RS5
    Jul 16 2018
    Atlanta
    It's not a MAP; it's not on the intake manifold air path. In the EA839 V6 intake air path, there is the G31 charge air pressure/temp sensor between the intercooler and the throttle valve, and then the G71 manifold pressure/temp sensor "MAP" between the throttle valve and intake manifolds. These are both 06E... parts.
    For the context of this thread, the pressure sensor involved is the G950 pressure sensor on the vent line from the N80 EVAP purge valve. This line feeds the intake path after the throttle valve under idle and feeds the turbo inlets under boost. Same concept as the EA888 4-cyl. But California wanted a check system to validate the EVAP purge path was operating correctly, so we get the G950 pressure sensor in NAR.
    The G950 on a US B9 RS5 (emissions PR code 7CE) is 06H906052A through MY22, then 06H906052B starting MY23.
    The N80 purge valve with line set attached is now 06M133240CJ for through MY23. It's 06M133240EP for MY25. MY24 seems to be a mix of EP and CJ. The catalog does not list CJ as being replaced by EP.
    "Audi parts say", you mean parts.audiusa.com? Yeah, Audi USA's parts site gets stuff wrong all the time. Audi AG's parts catalog says the above. Simple enough to look at the sensor on your engine (well, maybe) and see which p/n it is. Google search Audi SSP 655 and look at page 23. The G950 is right after the N80 valve.
    Veteran Member Four Rings Jroyalty7's Avatar
    Jan 10 2016
    Porsche Macan Turbo
    FL
    Great answer!! 🫡
    Sent from my iPhone using Tapatalk Pro
    Current: ‘21 RS5 Sportback B9.5 Nardo Grey
    Retired: ‘13 S4 B8.5 Phantom Black Pearl
    EPL Stage II DP Tune | EPL 57.60mm SC Pulley | 183mm Fluidampr Crank Pulley | S4Matty Ported SC and TB| Aquamist WMI 375cc Jet @ TB| AMS Alpha Heat Exchanger | Milltek Sport Non-Resonated CBE | ECS Kohlefaser Luft-Teknik Intake | Alu Kreuz | CR-15 | 034 Drive Train & Trans Inserts | Bilstein PSS10 | SPC Upper Control Arms | TSW Bathurst 20x10 | Pulley Ratio=3.177
