Results 1 to 10 of 10
    Aug 15 2024
    Mineola, NY
    Question 0n 08 S5 4.2 & Timing Chain Issues
    New here and I read somewhere that apparently there were 2 different 4.2 motors in the 2008 and one has the dreaded timing chain guide issue and one does not......ANYONE know how I can tell the difference in which motor might be in the vehicle I am about to purchase?....Any help in being able to see if this is true and if so, how to identify this would be appreciated. Maintained buy Audi dealers til around 85k and the car currently has 95k on it. She's real pretty and 6 speed manual gear box.
    Veteran Member Four Rings hahnmgh63's Avatar
    Jan 10 2008
    Roy, WA
    I think the CAUA was the only 4.2 available in the S5 in 2008, first year of it in N. America. Being that you're talking about a first year model year there may have been improvements/revisions to some of the parts up through the 2012 model year. The B8 4.2's are known to have less issues than the B7 4.2's but being that 2008 was 16yrs ago, more like 17yrs from production there is bound to be degredation to the plastic guides due to age and heat cycles.
    2003 RS6 (6Spd)
    2013 RS5 (Headers, Aluminum DSG Flywheel,JHM Stg2, etc...)
    2013 S5 (034 Stg2 & TCU)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Jul 16 2018
    Atlanta
    B7 S4 4.2L - BHF
    B7 RS4 4.2L - BNS
    B8 S5 4.2L - CAUA
    B8 RS5 4.2L - CFSA
    So maybe you're thinking the BHF or the BNS in the MY08 B7 vehicles? The B8.0 S5 4.2L was only the CAUA engine.
    https://www.ilcats.ru/audi/?function...65&language=en
    Aug 15 2024
    Mineola, NY
    Thank you very much for the intel , I am now reading that they also had a 40 valve 4.2 and apparently that is way more problematic than the 32 valve, which happens to be the one I am looking at and it looks like about 85,000 of this car's life was striclty serviced by Audi dealerships and oil changed on a regular basis. That is making feel a drop more confident in pulling the trigger on this weekend warrior.
    Jan 10 2008
    Roy, WA
    The 40 valve motors were before 2008, they did have the advantage/disadvantage depending on how you look at it of a front mounted timing belt instead of a rear mounted timing change. I've got the BCY version in my '03 RS6, a great motor and a very reliable 500bhp output. There's been a lot of engineering talk about what Audi did with their V8 motors with the timing chains. They have improved the system somewhat since 2008 but it is still a very complicated arrangement with lots of guides, rollers, and 4 chains. On the other hand the Porsche Cayenne 4.5 or 4.8 V8 motors with the same 'V' layout and double overhead cams per bank have just one timing chain and the guides tend to last longer. And if you do need to change it the parts are half the price of Audi's and much easier to work on. I hope i never have to do the timing chain on my RS5, they due tend to last longer than the older S5's setup though.
    2003 RS6 (6Spd)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Jul 16 2018
    Atlanta
    The 5-valve engines were the old turn of the century MPI (multi-port injection) designs. All the FSI (direct injection) engines are 4-valve engines. In MY08, the B7 S4 BHF and C6 A6 and D3 A8 BVJ were the old MPI 5V V8s. These are the notorious ones, in regards to that chain stuff, apparently. The BNS, CAUA, and CFSA are all FSI engines.
    Aug 15 2024
    Mineola, NY
    Quote Originally Posted by hahnmgh63 View Post
    Thank you for the education, as I have had a ton of cars and this would be my first Audi.....Just didnt wanna drop 14k and then another 10k for a timing chain job. I have heard with proper maintenance , they can last quite a while.
    - - - Updated - - -
    Quote Originally Posted by Smac770 View Post
    I am a novice to Audis, so I appreciated the education and response.
    Jan 10 2008
    Roy, WA
    As an example since yours is a 2008, the main crankshaft guide (aluminum with a Phenolic plastic guide plate) is now part # 079-109-507-AF, there were two previous revisions dating back to 2008, 079109507Q & 079109507R. With many manufacturers, unless there is a tech service bulleting requiring or recommending a change to a new part you really don't know what the new part revisions are for. Is the part improved or possibly a new supplier so they gave it a new part suffix? But being a 2008 the guides are old, the Phenolic plastic does get brittle with age & heat cycles. It isn't a fun job to do as the engine has to come out and there are a couple of special cam holding tools that need to be used to hold the cams in place while you get everything tightened down properly at TDC. The chain/guide setup is an engineering marvel to look at but as I mentioned, Porsche went a more conventional/practical route of simplicity compared to Audi.
    2003 RS6 (6Spd)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Aug 15 2024
    Mineola, NY
    Thanks for that info....From what I can see, if these 4.2 32 valve engines are properly maintained, they are far less problematic. The Carbon build up is what it is.....I was just worried about a 10k chain replacement and it seems like I might not have to worry so much, based on the previous owners and records of maintenance .
    Aug 15 2024
    Mineola, NY
    Thanks again for the education, great motors apparently but like most things German engineered, they tend over engineer them!
