Results 1 to 7 of 7
    Veteran Member Four Rings 01northernS4's Avatar
    Oct 18 2006
    Audiville
    must you flash back to stock first before switching between different tuners?
    for example from unitronic tune directly to jackal and vice versa?
    been getting different answers and wanted to know what you fine folks do... flashing is a pain but even more so if you have to go to stock every time...
    not getting the same answer from both tuners (one says it doesn't matter the other says go to stock first)...
    thanks!
    2015 Audi S5 Technik
    Mythos Black Optics | DSG | Sport Diff | H&R OE Springs & 10F/15R Spacers | CR-15 | 20"x9" Black Matte Rotors | Akebono Brake Pads
    Unitronic DP 3.2 Ratio | Merc Racing Hx | Milltek Resonated Cat Back Exhaust W/Black Cerakote GT100's | Modded Airbox w\AWE Intake Tube & AFE Dry Cone Filter
    Veteran Member Four Rings f1torrents's Avatar
    Apr 27 2012
    B8.5 6MT S5 Coupe / B9.5 S5 Coupe
    Guelph
    Flashing back to stock is best practice, but in reality the "map area" is erased before a flash anyway. So stock or tuned, it's getting erased before the new file is written.
    It's just to eliminate possible issues.
    If you have a voltage or communication issue, it will show up while flashing to stock, which eliminates troubleshooting for them if it would have instead caused an issue with the tuned file.
    Oct 18 2006
    Audiville
    So flashing direct can be done but not best practice, check ... Thanks for the response
    Have you or any others done so on a regular without issue?
    Trying to test the tubes back to back and the extra steps are a pain in the ass.
    Thanks again!
    Jul 10 2013
    Central WI
    In most cases it's okay to flash from one vendor to another without flashing to stock first. There are some circumstances where you'd end up half of one tune and half of another, and others where the unlock process could be affected by something odd done by the previous tuner, but 99% of the time it will be okay to flash between without going stock first.
    Senior Member Four Rings
    Jun 08 2021
    PA
    I was thinking this as some tuners edit areas that other do not.
    Oct 18 2006
    Audiville
    Quote Originally Posted by sb_gli View Post
    Thank you!
    went to stock to be extra safe... appreciate the helpful response.
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    I did not have to flash back to stock file to go from dual pulley Stage 2 EPL to 034 Stage 2+. My original stock tune was lost when EPL shuttered its server. Didn't matter.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
