Results 1 to 23 of 23
    Jun 19 2011
    C5 S6 windshield no longer available per AAA insurance, Safelite and Glass America
    Tried getting mine replaced, but settled for just a repair. Have others been able to replace their C5 S6 windshields? Is it different than other C5 models?
    Thanks,
    -Jeff
    current: '02 S6 Avant, light silver metallic/ebony, 6-speed w/JHM solid short throw shifter, B7 RS4 clutch & lightweight flywheel, ST coilovers
    previous: '99 A4 1.8Tqms, aluminum silver metallic/onyx
    Jul 14 2021
    Fort Collins, CO
    Quote Originally Posted by JTF View Post
    Thanks,
    I'm in the same boat. There are so many stories of high dollar replacements that aren't correct fitment and are causing water leaks. I caught a rock chip right by the right A pillar that turned into a Crack. Shame is, I've got my A pillars wrapped in PPF
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Alpaca Beige 2002 Audi Allroad 2.7T Auto with 3rd Row Seat, Avus Silver Oxblood 2003 Audi S8, Silver
    Portland, OR
    Yes, it’s different. I believe it’s longer and goes down into the cowl area further, or something along those lines. The S and RS are a little longer than an A6 or Allroad in the nose.
    I’ve heard it called the most difficult to source windshield in the US and I bet they’re few and far between anymore. There were what, 1400 S6’s brought over or something like that.
    I’d honestly be a little weary of anything advertised as new, too. Unfortunately I am no help and know of no solutions.
    Veteran Member Four Rings R490's Avatar
    Mar 04 2014
    Northern Virginia
    Well that's fantastic.
    2003 Audi S6 Avant
    2005 Audi S4 6MT SOLD, 2001.5 S4 6MT SOLD, 2001.5 S4 Tip SOLD, '00 A6 2.7t Quattro 6mt SOLD, '97 A4 2.8 Quattro 5mt SOLD
    Jul 15 2021
    15 A3 2.0T, 00 A6 2.7T, 13 Tahoe PPV, 95 Fleetwood, 94 Fleetwood, 85 Eldorado, 94 Cougar
    Northern Illinois
    Quote Originally Posted by ShelbyM3 View Post
    Source?
    I have been operating under the belief that the following is all true, regarding C5 unibody variants sold in the US:
    There are two sedan bodies, a wide body for the 4.2 V8 cars, and a narrow body for the rest of the A6 sedans.
    The Allroad and the A6 avant are both "narrow" variants that share parts (or at least interchange) with the narrow sedan, aside from the wagon-specific body parts like the hatch, obviously. The Allroad unibody is unique, having mounting tabs for the rear wheel flares and also being reinforced in a few different places. Out of all C5s, the Allroad was the only narrow body that came with a V8.
    The A6 4.2 sedan, I think, is dimensionally the same as the S6 and RS6 sedans.
    In summary, I would be surprised to learn that the A6 4.2 windshield doesn't fit the S6 or RS6. The A6 4.2 cars do show up at LKQ every so often, but nobody ever needs any parts from them when I ask.
    EDIT: Of course there are also "facelift" differences. The Allroad body parts only fit the PRE-facelift A6 sedans, such as mine.
    2000 A6 2.7T 01E Build in progress
    20 psi on fresh Melett K03 cartridges, Allroad widebody conversion
    Feb 05 2007
    Portland, OR
    Shelby, and Russia, and fellow enthusiasts. Caddylack, I don’t believe you’re wrong in any of your statements, but some things still aren’t transferable, in my understanding.
    Here are some part numbers, although there are multiple different windscreen options as far as tint and UV protection goes, but I believe the ending letters determine that much like interior color schemes.
    02 A6 Saloon V8 - 4B4845099AE
    02 S6 Avant - 4B6845099AE
    03 RS6 Saloon - 4B4845099AE
    03 RS6 Avant - 4B6845099AE
    You can see that the Saloon versions are interchangeable, and the Avants are interchangeable, but the Avant versions and Saloons are not. So, we can source an RS6 windscreen from a wide body V8 A6, but the Avant has a different part number specific to the Avants. We obviously didn’t get the RS6 Avant in the C5 models. I was planning on listing more variants to really see what they all had, but the website will only let me look at two different models a day now. Womp.
    03 Allroad - 4Z7845099AA
    03 A6 Saloon - 4B5845099BH
    03 A6 Avant - 4Z7845099AA
    Jul 15 2021
    Northern Illinois
    Good post.
    I think it might be worth comparing side by side. There is a clearly some difference between the avant and sedan windshields, but I’m putting Allroad fenders on my A6. You catch my drift.
    Jul 15 2021
    Northern Illinois
    Speaking of 4.2 V8 cars, you can buy an entire car for $550:
    https://www.copart.com/lot/74852903/...sonville-north
    It even has sport seats.
    Jun 19 2011
    That confirms it. Thanks all!
    -Jeff
    Jul 15 2021
    Northern Illinois
    You might consider one of the companies that makes custom auto glass to order. Just google it and maybe you can find somebody near you.
    Feb 05 2007
    Portland, OR
    Edited and added Allroad and A6 Avants.
    Caddylack, I do pickup what you’re putting down, but with the windscreen and potential water damage that will potentially total a rare C5 I just wouldn’t chance it. Unless I had more proof it was successful.
    Veteran Member Three Rings IbisB7stage2's Avatar
    Mar 20 2013
    Bay Area
    dang, what a bummer. my windshield is pitted in such a bad way that I can barely see out when driving into the sun in mornings and evenings. Not sure if any repair method can handle several hundred tiny pits over the entire windshield.
    ~John
    B7 A4 quattro 6spd, k04 w/ meth, PSS9 coils, S4 recaros, basically everything else
    C5 S6 Avant 6spd
    Sep 16 2010
    Central Wash
    FWIW- you absolutely CAN swap the V8 sedan and S6 windshields. They are exactly the same size, it's the same car from the B-pillar forward, but the S6 version is maybe a tiny fraction of a mm thicker- or as Audi called it 'insulated' . That's why the different part #.
    You can put a narrow body car (sedan OR Avant/ Allroad) windshield into a wide body car, but you need the plastic parts that cover the wipers/ wiper motor and attach the 'cowl' and rain tray cover. With that stuff it WILL FIT, you'd never know the difference. And you can just install teh glass, but you'll have a gap in the plastic stuff below the windshield- honestly you could probably fill that gap with some trim or something. ( ?? like this? https://a.co/d/9AZBCeI
    That's it all wrapped up.
    Feb 05 2007
    Portland, OR
    Quote Originally Posted by rollerton View Post
    So I’m not completely full of shit, but my reasoning missed the mark. The plastics are different, not the windscreen itself.
    So you’ve got to replace all the cowl plastics? Even the part the main cowl plastic slips into under the windscreen or just the main cowl cover piece?
    Jul 15 2021
    Northern Illinois
    Bam.
    Sep 16 2010
    Central Wash
    The plastic is different because the glass on the widebody is 3/4" longer. So, use the plastic parts that go with whatever glass you have. If you put a narrow body windshield in a widebody car, get the narrow body plastic cowl stuff.
    Feb 05 2007
    Portland, OR
    So it’s the narrow body vs wide body and the windscreen is in fact longer. Thanks Rollertron for setting me straight.
    Feb 25 2016
    FYI you want to get the windshield from trival glass company, I had the other brand listed and fortunately that one had a scratch and also the blacked out edges was not wide enough. This allowed the inside trim to be seen.
    Jun 19 2011
    Thank you, and nice seats! Just noticed you're in CT (me too, in Hartford area). Where did you source this glass and is your AR a 4.2?
    -Jeff
    Feb 25 2016
    Thanks, they’re recaro toplines. I’m down in Trumbull area and had Portland Glass install the windshield. They did a great job. It’s a free install with glass coverage. And CT is no repair state so that chip you have there should net a replacement.
    Jun 19 2011
    Thank you! Have you noticed any differences between the OEM glass and your new Trival glass?
    -Jeff
    Feb 01 2017
    NoVA
    Quote Originally Posted by Caddylack View Post
    Thoss look a lot like magnaflow downpipes in that pile of parts too.
    Nathan
    ____________________________
    '19 SQ5
    '64 356 SC 1720
    '73 914 2.8 6-cyl conversion in progress
    ‘02 S6 Avant - gone to a new owner to live up to it’s potential as a 6-speed
    RIP (tree) ‘99.5 A4 2.8 Quattro Tip - GIAC engine and tip chip, Stage 3 MAF mod, A8 front rotors
    May 09 2012
    Virginia
    Quote Originally Posted by OOOOallroad View Post
    I just replaced the glass on my C5. Ended up with the Trival as well. Seems decent so far.
