Results 1 to 7 of 7
    Senior Member Three Rings Blockis's Avatar
    Jul 25 2012
    2007 A4, 2011 Q5
    Boston, MA
    Only P0506 and Cylinder Misfires (Rough Idle + Stalls)
    Hey there Q5ers! I'm usually over in the B7 A4 group, but my parents have a 2011 Q5 (2.0T, Auto) with 230k miles and I'm stumped on some recent codes.
    Initially, the car had a P008700 (fuel rail / system pressure - too low) and it would intermittently stall or not start. We didn't see any obvious signs of leaking or anything, but we replaced the HPFP and checked the cam follower (looked great, no scoring or anything, it looked pristine).
    Now the P008700 code is gone (woohoo!) but I see new codes:
    • P0300 - Random/Multiple Cylinder Misfire
    • P030X - All Cylinders misfiring
    • P0506 - Idle Control System RPM - lower than expected
    It would appear that the cause of the P0506 is why the cylinders are misfiring. I have no other codes. What should we be checking next? Fuel injectors? Vacuum leak - how would we test when the car can't idle for more than 10 seconds before it stalls and dies? Throttle body cleaning? What can we do to try to narrow down what it might be?
    I saw a video of a Tiguan with a similar issue (only misfires + P0506) and the guy suggested disconnecting the PCV from the intake manifold and just covering/blocking the hose port on the intake manifold -- if the car starts to idle normally, then that would be indicative of the PCV valve being bad. Thought that was interesting, as we did replace the diaphragm in the PCV valve about a year ago, but not the whole unit. We did the test, and it still died even covering/blocking the port.
    Thanks y'all!
    Paul
    2002 A4 1.8T Quattro | 197k ☠️
    2007 A4 2.0T Quattro | 168k
    2011 Q5 2.0T Quattro | 240k 🔧
    Mar 05 2013
    CA
    check LPFP
    Jul 25 2012
    2007 A4, 2011 Q5
    Boston, MA
    Quote Originally Posted by Spike00513 View Post
    check LPFP
    Is there a measuring block to observe before ripping into it?
    Paul
    Jul 25 2012
    2007 A4, 2011 Q5
    Boston, MA
    Took to a shop, they did a compression test, and found that cylinder 2 had no compression. Their recommendation is a valve job for $3,500 — is this something I can do as a project (no timeline) or is this better left to the pros?
    Senior Member Three Rings QwertyD's Avatar
    Oct 04 2017
    United States
    You check your injectors yet?
    Sent from my SM-N986U using Audizine Forum mobile app
    AKA: Dhoang57
    Jul 25 2012
    2007 A4, 2011 Q5
    Boston, MA
    Quote Originally Posted by QwertyD View Post
    I have not, currently not with the vehicle. I'll have the folks try to start it up with a screwdriver on each injector and listen for inconsistent or lack of ticks.
    Or is it possible the o-ring for one of the fuel injectors went bad? Probably too hard to tell without ripping her open lol.
    If a valve job is needed, feels like it would be timely to replace injectors and o-rings while you have so much off.
    Paul
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    A leaking injector seal, injector body, or leaking valve seal can cause zero compression.
    I'd also want to scope tge cylinders, especially tge one with zero compression to see what they look like.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
