I just dropped it off at our local Audi dealership for a TSB that surfaced literally hours after taking it off the lot
1. Besides the point, they recommended the following maintenance as part of the 30k mi. service and wanted to know whether it's necessary at these intervals based on platform experience.
- 30k mi. or 3-years: Transfer Case Fluid Change
- 30k mi. or 3-years: Brake Fluid Change
- 30k mi. or 3-years: Rear Differential Fluid Change
Aside from the above, I've ran into a few other weird issues...
2. Audi Pre-Sense and other safety sensors are very sensitive. For example, the distance sensors for the car in front of me is giving me a warning rather often when the car is well over 50-100 ft. away. Is this normal? Audi says that it might need a calibration/alignment for $900.
3. Wired and Wireless Carplay both connect intermittently. Sometimes it won't connect but MMI will still recognize the phone and play music. I was advised by Audi to try an original Apple cable. Does this sound right? Anything else I should be checking?
4. I used to use OBDEleven for my B8 S4. Is this still the go-to mobile OBD Diagnostic device? I know VCDS is best but we're keeping the car stock so don't need anything advanced for now.
5. Any need-to-know maintenance/part replacements that I can expect with the B9? PCV? Thermostats? Air Ride? etc.
That's all I have for now and looking forward to your responses. Thanks!
