Originally Posted by
Turbanator
Is the Porsche setup on any MLB vehicles? Because if not, I can imagine there are mechanical incompatibilities trying to fit MSB components in.
It's a bolt on ("hang-on") transfer case to the ZF transmission. It's made by Magna, same people that make the "quattro ultra", another "managed" transfer case solution ("Flex4"). So same concept, same manufacturer, "inverted" implementation where the rear output is forged to the input and the front output is the clutched output. Also, unlike the DL501, the DL382 has the same arrangement of front shaft inside of output shaft as the ZF transmission. The DL501 was inverted, same as the 6MTs it was based on, thus why the Torsen center diff p/ns were always different (0B2,0B4,0B5) vs the ones for the ZFs (0B6, 0BK, 0BL).
If you look at diagram of the DL382 type 0CL with Torsen center on pages 46-47 of the SSP 644, you see the clutch K2 in blue and the shaft with gearing that it drives cutaway in blue. Then the clutch K1 in orange, with the shaft through the middle of the blue input shaft, to the orange geared input shaft. These both mesh with the output shaft in dark tan (?). We see that drives the Torsen housing, with the Torsen front output coming back down the center of the output shaft to the front, where it drives the spur gear to the front drive shaft.
If you look at the diagram of the AL552 (ZF 8HP65A) type 0D5 with Torsen center on pages 34-35 of the SSP 662, we see the same general arrangement at the transmission rear end. Output on the outside, input to the front diff returning through the inside of that output.
Pages 38-39 of the SSP 657 shows the 0CJ version of the DL382, with the long inside shaft to the front axle spur gear removed and that gear driven directly by the output shaft. Then the output shaft feeds through at the rear to the "AWD clutch", where the clutch pack governs the transfer to the rear drive shaft output. The transfer case for the Porsche would be like the 0CL config, taking the output which would be hard linked with the rear drive shaft output, and the clutch pack connecting the front axle shaft returning back up the transmission to the front spur gear.
