Hi All,
For those of you who are planning to keep their car for long term. Are you concerned that Audi manufacture recommended 0w-20 motor oil will reduce the longevity of your SQ5?
My apologies for bringing up this topic which have been discussed in the past. I have read the threads and watched videos online. The video posted by VAG Technic (below) concerns me the most as well as videos regarding metal shavings in the oil filter for B9 SQ5. People said it is normal to find metal sparks in the oil filter. But it doesn't make sense to me to see that happening in our car. I wanted to keep my B9.5 SQ5 for a long time and concerned about this. I feel the only way to minimize the engine wear is to switch the motor oil to a thicker one (i.e., 5w-30) in the summer. The B9.5 SQ5 tend to run a little hot and my car's temp was at 225F when the outside temp registered at 100F. The car was not even stuck in the traffic. So I feel it was pretty hot for the car. I've looked online there is no 5w30 oil spec at 508 but 507 or 505. I'm not sure the spec 505, 507 or 508 makes any significant difference in terms compatibility. The link below is to the VAG Technic video. One of the B9 RS4s has engine fail at 26900 miles. It's scary to see a such high end car fails at such early age. I'm interested to know who on here been using 5w-30 oil for their B9 or B9.5 SQ5 and any feedback on the result is appreciated.
https://youtu.be/sd0dIE7VCKk?si=M1F2d2AKOZWSs823
