Results 1 to 7 of 7
    Mar 07 2023
    massachusetts
    Question 2017 A6 3.0T - OEM Water Pump Brand
    Hi all,
    My waterpump is due on my A6 and I was wondering what’s the oem manufacturer of this pump:
    Is it HEPU? It's cheaper than OEM.
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by Touareggg View Post
    I was wondering what’s the oem manufacturer of this pump.
    I'm not sure, but I believe others on AZ have written that Pierburg is the OE supplier to Audi. Check out the long water pump thread by qcrazy.
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Mar 07 2023
    massachusetts
    That's the auxiliary pump you're talking about and yes, it is Pierburg. What I'm talking about is the waterpump right next to thermostat and below coolant crossover pipe.
    Junior Member One Ring
    Oct 26 2008
    TX
    When the water pump failed in my A7, after 35k miles, I replaced it with this one ... https://www.fcpeuro.com/products/aud...raf-06e121018k
    I wanted to give a chance something other then OEM since I've seen many premature fails with the OEM pump. Also, FCP Euro lifetime warranty.
    Junior Member Two Rings
    Apr 20 2024
    2018 RS7-P, 2019 Volvo XC90 T-8R
    Vancouver, WA
    HEPU is a German manufacturer, I would run it.
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Gotcha. Only help I can give is to note that ECS Tuning now also offers "lifetime" warranty, I suppose to compete with FCP Euro. Looks like their option is the OEM pump from unknown supplier.
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    i put a cheap Amazon one 3 years ago when my engine failed and swapped it over to my used engine and is been 1 year so 4 years total and still hasnt leaked. i bought it for 30 bucks.
    Ivan
