Results 1 to 9 of 9
    May 25 2020
    Ottawa, ON, Canada
    Brakes feel... different after Macan Caliper upgrade...
    Just replaced OEM calipers with new Macan Callipers from ECS. Redstuff pads and ECS SS lines. Upgraded the front rotors as well, same size as OEM, just better. I used a Schwaben pressure bleeder to bleed the system afterwards.
    Initially I just bled the front callipers (and only the inside of each as I forgot that Macan callipers have bleeders on the inside AND out!). Bled them until no more air came out... which took maybe 500ml of fluid between the two.. maybe a bit more.
    Took it for a test drive and as you can imagine, the pedal was soft to the floor almost. The second time I bled in sequence: Rear Pass., Rear Drvr., Front Pass, Front Drvr. (indie and outer) Only the slightest bit of air on a one calliper. Ran another 500-750ml of fluid through between all four callipers.
    Took it for test number two... much better..buuuuut, something feels off to me. Pedal is soft-ish at first, but you can feel that there is brake pressure being applied, just not a ton. A bit more and it starts to grab proper... push a little harder and bam! She bites! Also, If I pump the pedal at all it get stiff right away.... Like I was expecting it to feel from the get go.
    All of that to ask: Does this upgrade affect the feel at all or is it simply that there is still some air trapped in there somewhere. If air, whats next? I've read on other threads that the ABS module might need to be bled as well, but dosen't seem to be universal across the board. That job sounds like a VCDS is required, which I do not have.
    At any rate, any insights would be helpfull.
    Cheers
    May 20 2010
    While not the same calipers, when I swapped 18Zs on my B7, I was experiencing some of the same feeling you are. It wasn't until I did a 2-person bleed that I got them to firm up nicely and apply a very linear brake feel. I recommend doing this. Also remember you need to bleed outer bleed screw first and then the inner.
    If you did not have the system open for long when swapping the lines and then bleeding, I wouldn't worry about the ABS. But if you want to do it, you can cycle it through VCDS (or similar) or I think it cracks at ~30 psi on a pressure bleeder.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Jan 04 2021
    BMW x3 28i/ CBR F4i/ YZ125
    CALI
    Bleed the abs module through VCDS is the common denom
    Stage 2 Banner Advertiser Four Rings Sean@TAG's Avatar
    Jun 27 2014
    Seafox Boat, Jetta, F150, Travel trailer
    San Diego
    Definitely worth a shot with the ABS bleed.
    TAG MOTORSPORTS
    (866) 748-4388
    SITE: www.TAGMotorsports.com
    EMAIL: [email protected]
    Senior Member Three Rings Maimonea77's Avatar
    Aug 09 2018
    b8.5 s4, b7 A4
    California, SoCal
    I have the same exact issue, I will give it a shot with someone manually pumping the brakes as I bleed them but I did use a power bleeder to avoid needing 2 people to do it.
    Veteran Member Four Rings eurojunkjon's Avatar
    Mar 12 2017
    2013 S4
    Burlington, wi
    As others have mentioned, need to run the abs through a cycle. My past 3 brake upgrades I’ve had to run several bleed sessions and abs cycles
    2013 S4 Imola Yellow / IE Stage 2 / ECS Supercharger Pulley / IE Intake / ECS HX / AWE Non Resonated Downpipes / AWE Touring Exhaust / Vogtland Coilovers / Rs4 Grill / Eurocode SS / Black Forest Shift Knob / BBS LM-R / Alcon BBK / S6 Rear Brakes
    1996 Golf Harlequin #10
    Aug 09 2018
    b8.5 s4, b7 A4
    California, SoCal
    Quote Originally Posted by eurojunkjon View Post
    What do you mean By running the abs cycle? Don’t you use the abs cycle to bleed the brakes? Or do you run the abs cycle through vids and then have someone pump the brakes with the bleeders cracked?
    Mar 12 2017
    2013 S4
    Burlington, wi
    Quote Originally Posted by Maimonea77 View Post
    Cycle the abs with vcds or obd11 if it lets you, I use vcds, follow the prompts, it tells you to pump the brakes 10 times and then bleed. I also do this with a power bleeder.
    Established Member Two Rings iCrap's Avatar
    Nov 29 2017
    2016 S5, 2023 Q5E, 2001 Honda S2000
    MD
    I had the same impression as OP after doing my Macan brake swap as well. It took several rounds of bleeding as well as the VCDS ABS module bleed for it to finally feel corret.
    2016 S5 Daytona Grey - RS Grille | RSNAV | H&R | CTS Turbo Intake | 034 Stage 2 | Deval
    2023 Q5E - District Green
