Results 1 to 3 of 3
    Established Member Two Rings Vera_S3's Avatar
    Nov 27 2015
    2018 Q5 Brake Pad Replacement
    Hi all!
    Dad has a 2018 Q5 Progressiv and has the replace brake pad warning on.
    I’m looking to get him a set of front and rears from Rock Auto but they show two kinds:
    1. Brembo
    2. Continental Teaves
    Is there a way to know which one without physically looking at the car?
    I live across the city for him and would rather save the trip if possible.
    Here’s a screenshot showing the two variants:
    Junior Member One Ring
    Feb 26 2023
    Fowlerville/Michigan/USA
    I bought the EBC pads for my Audi Q5 S Line , I had powerstop (complete kit) on my 2012 Ford Escape it has rear drums so for the rear semi mettalic and the front aramid carbon , not semi mettalic a complete mismatch on Power Stop . I swapped the fronts out for Bendix severe duty metallic and now it is good . I've had EBC on about 4 different vehicles and they work good also they answer there support phone ! EBC Brakes USA 702-826-2400 may help you with which brakes you have . My S Line has the Brembos and I think the rotors are bigger in the front . You might need a tape measure .
    Senior Member Three Rings J-Dog's Avatar
    Aug 10 2018
    Doylestown, PA
    I’ve a got a full set of new OEM pads I never used available. Just a heads up.
