Hey gurus,
Quick run down of my last 6 months.
2013 S6 with 109,xxx miles on it. (SRM RS7 CHRAs, installed in 2017 when removing the screen wasn't suggested yet)
Jan 10th, Driving aggressively in Northern Virginia traffic one turbo/both turbos go boom, YES I still had my oil screen in. I was 5 minutes from my destination, and though I could coast all the way there.....2 miles later, engine quazi-seizes (Hydrolocked from massive oil intake from both turbos snapping both hot sides off and oil flooding my intake manifolds) I'm an idiot PART 1
I got a new engine from Lifetime Audi Parts in NC, They said it was good to go, but it looks like the donor car had impact from the driver's front.
There were some connectors to the components on the front drivers side that were damaged, so I spliced in the CWA-50 connector and one other one at the end of that run form my old harness. (YES I KNOW I SHOULD HAVE USED MY KNOWN WORKING OLD HARNESS) I'm an idiot part 2. There are a lot of things I wish I had done. like swapped over all the vacuum lines and components from my old engine. I'm an idiot Part 3
Engine is in, but I have 3 or 4 codes that I am battling. One is brand new as of yesterday (that is the Cam adjuster).
1. I tested continuity between pins 1 and 2 of the thermostat, and got nothing. I have a new thermostat sitting next to me ready to go in.
2. Intake manifold flap (Eff me, this looks like an engine out again replacement possibly) Bank 2 is the Driver's side correct? I know the pneumatic valve is located under the intake manifold by the fuel rail, and the position sensor sending unit is up front behind the Main intake manifold. Tucked in behind the fuel supply line to the fuel rail.
3. New code as of yesterday. I'm first going to unplug and reconnect both intake and exhaust actuators, since I don't know which one is A or B. if that doesn't work, I'm going to take the ones off my old engine and see if this clears up.
4. *This is from OBDeleven not Vagcom* - P2279 00 - Intake Air System Leak - static I have an boost leak that is not constant. I have used a smoke tester and it looks like it is coming from the front driver's side behind where the intake manifold front seal is, around the same location as the N75 valve.
My car is in my garage on quick jacks, and I'm going to be pulling out to service mode after I smoke the intake again to try to pin point the leak.
Here are my codes from Vagcom.
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 22 28 34 36 3B 3C 42 44
46 47 52 53 55 5F 62 6C 72 88 89 8F 90 A9 BA
VIN: WAUF2AFC7DN128074 Mileage: 175939km-109323miles
Address 01: Engine (------CEUC) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 906 014 B HW: 4H0 906 014
Component: 4.0l V8TFSI / X62 0009
Revision: NCX62--- CVN: D0AAE84F
Coding: 0A2500326526000E1000
Shop #: WSC 00477 128 28888
ASAM Dataset: EV_ECM40TFS0114G0906014B 001009
ROD: EV_ECM40TFS0114G0906014B.rod
VCID: 21426448301C809E6C-8074
VINID: 9D19560915931D478108800710E58881DB
3 Faults Found:
7036 - Thermostat for Mapped Engine Cooling (F265)
P0597 00 [00101000] - Open Circuit
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 12
Mileage: 175931 km
Date: 2024.06.24
Time: 10:11:13
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 84 °C
Intake air temperature: 63 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 11.638 V
Unlearning counter according OBD: 40
Engine status: COENG_READY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 1
8994 - Intake Manifold Flap; Bank 2
P2005 00 [11101101] - Stuck Open
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 175931 km
Date: 2024.06.24
Time: 10:12:00
Engine RPM: 1200.00 /min
Normed load value: 7.1 %
Intake air temperature: 69 °C
Voltage terminal 30: 13.570 V
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
14294 - Cam Adjustment Actuator A; Cylinder 8
P11D1 00 [11101101] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Mileage: 175931 km
Date: 2024.06.24
Time: 10:12:00
Engine RPM: 844.50 /min
Normed load value: 12.5 %
Intake air temperature: 68 °C
Voltage terminal 30: 13.546 V
