Results 1 to 2 of 2
    Feb 12 2021
    Sweden
    Problem with fault codes on power steering A7
    Hello
    I have some problems with my 2016 A7. The car has for some weeks throw random fault codes on several systems and often the code has been :U111300, U111100 and with message in dislpay like "ACC and braking guard not available" "Start stopp not available"
    The codes has always cleared and the car has function normal, when google the symptoms many things pointed to bad battery, the car had its original battery och with battery tester showed 40% healht with message "change battery"
    I ordered a new battery but before i had change the battery when i started the car the display showed like error on everything (obdeleven got 209 errors in 40 system). This time when i cleared the codes not all was cleared and i still got yellow lights on power steering, airbag,ACS,adaptive lights,air suspention and got no front or reverse camera,no ACC,no park assist, no start stop function, no steering column lock when ignition off and i leave the car. The car is still drivable and steering feels like in dynamic mode always. It feels like it has something to do with the electrical power steering.
    I have done G85 basic settings and i get ok and live data shows 0 when steering wheel is straight and 460 full left and 453 full right, it is not possible to relearn the endstops, get no beeping in end positions, and fault code b1168F1 and C10ACF0 in module 44. fuses to steering are ok. Car has new battery.
    Complete scan of the car in post below.
    Any ideas what to do/check?
    Best regards/ Emil
    Feb 12 2021
    Sweden
    Code:
    OBDeleven data log
    Date: 2024-06-24 21:54
        VIN: WAUZZZ4G5GN053523
        Car: Audi A7
        Year: 2016
        Body type: Sportback
        Engine: CVUA
        Mileage: 149530 KM
    01 Engine
        System description: 3.0BTD EDC17
        Software number: 4G0907589F
        Software version: 0008
        Hardware number: 4G0907589B
        Hardware version: H23
        ODX name: EV_ECM30BTD0114G0907589F
        ODX version: 001008
        Long coding: 1A2A403A257603030000
        Trouble codes:
            No trouble codes found
    02 Transmission
        System description: 0BK 30RTDIRDW
        Software number: 4G0927158AK
        Software version: 1015
        Hardware number: 0BK927156AM
        Hardware version: H19
        ODX name: EV_TCMAL551211
        ODX version: 002022
        Long coding: 000001
        Trouble codes:
    03 Brakes
        System description: ESP9 Premium
        Software number: 4G0907379S
        Software version: 0530
        Hardware number: 4G0907379S
        Hardware version: H01
        Serial number: --------------
        ODX name: EV_ESP9BOSCHAU57X
        ODX version: 004018
        Long coding: 49AFDD4B92F5BBD2BB00
        Trouble codes:
            U111300 - Function limitation due to received malfunction value
                static
                    Date: 2024-06-24 13:21:34
                    Mileage: 149476 km
                    Priority: 6
                    Malfunction frequency counter: 1
                    Unlearning counter: 255
                    VzRef: 0
                    Bit Info 1: 0
                    Bit Info 2: 2
                    Bit Info 3: 2
                    Bit Info 4: 1f
                    Uz: 9d
                    Unlearning counter according OBD: 40
    04 Steering Angle Sensor
        Trouble codes:
    05 Keyless System
        System description: BCM2 2.0
        Software number: 4H0907064GP
        Software version: 0572
        Hardware number: 4H0907064GP
        Hardware version: H37
        Long coding: 05AA6F0E000000000000
        Trouble codes:
            00955 - Key 1 Lower limit not reached
                static
                    Priority:  3
                    Frequency counter:  1
                    Driving cycle: 124
                    Mileage: 149474 km
                    Date: 2024-06-24 06:15:30
    06 Passenger Seat
        System description: MEM-BFS
        Software number: 4G8959760C
        Software version: 0157
        Hardware number: 4G8959760C
        Hardware version: H04
        Serial number: 00000155196116
        Long coding: C018320085006201010001010101112030303333283333
        Trouble codes:
    08 Air Conditioning
        System description: KLIMA 4 ZONEN
        Software number: 4G0820043CE
        Software version: 0112
        Hardware number: 4G0820043CE
        Hardware version: H14
        Serial number: 08071500040120
        ODX name: EV_AirCondiComfoUDS
        ODX version: 003008
        Long coding: 369311BE3D0000
        Trouble codes:
    09 Central Electrics
        System description: BCM1 2.0
        Software number: 4H0907063DG
        Software version: 0311
        Hardware number: 4H0907063AG
        Hardware version: H20
        Serial number: 00001111565202
        Long coding: 0105C01440349FF2D90140C4A0001800CF9CE308AE080221800008946101170200400009090000
        Subsystems:
            System description: WWS57X 150623
            Software number: 4G1955119
            Software version: 0080
            Serial number:         150706235650
            Long coding: 0045F7
            System description: G397_RLFS
            Software number: 8U0955559B
            Software version: 0002
            Hardware version: H06
            Serial number: 24068638
            Long coding: 02006E
            System description: E1 - LDS
            Software number: 4G0941531BH
            Software version: 0044
            Hardware version: H07
            Serial number: 26 06 2015  00000111
            System description: EHL2 V07.03
            Software number: 4G0907410
            Software version: 0030
            Hardware version: H30
            Serial number: 0000000094CE01FA62EC
            System description: EVLS-SG
            Software number: 4H0907705K
            Software version: 0300
            Hardware version: H08
            Serial number: WA121037000013742323
            Long coding: 020300
            System description: AQ_Hum_Sensor
            Software number: 4H0907658
            Software version: 0003
            Hardware version: H03
            Serial number: D3190AB7000000000001
        Trouble codes:
            01309 - Power steering control module Please read DTC
                static
                    Priority:  3
                    Frequency counter:  2
                    Driving cycle: 124
                    Mileage: 149474 km
                    Date: 2024-06-23 19:03:02
    0E Media Player
        System description: DVD Changer
        Software number: 4M0035108A
        Software version: 0072
        Hardware number: 4M0035108
        Hardware version: H40
        ODX name: EV_DVDCALPI
        ODX version: 001010
        Trouble codes:
    10 Parking Assistance
        System description: PARKHILFE PLA
        Software number: 4G0919475G
        Software version: 0070
        Hardware number: 4H0919475E
        Serial number: 56231518501641
        ODX name: EV_EPHVA2CAU64X0000
        ODX version: 001011
        Long coding: B92B0F
        Trouble codes:
            U112300 - Databus error value received
                static
                    Date: 2024-06-23 18:50:05
                    Mileage: 149474 km
                    Priority: 6
                    Unlearning counter: 124
                static
                    Date: 2024-06-23 19:03:00
                    Mileage: 149474 km
                    Priority: 6
                    Malfunction frequency counter: 4
    13 Adaptive Cruise Control
        System description: ACC3
        Software number: 4G0907561B
        Software version: 0053
        Hardware number: 4G0907561
        Hardware version: H21
        Serial number: 00000000000000
        ODX name: EV_AdaptCruisContrAU57X
        ODX version: 002014
        Long coding: 7F04010201
        Trouble codes:
                static
                    Date: 2024-06-23 18:47:36
                    Mileage: 149474 km
                    Priority: 6
                    Dynamic environmental data: 028D002202853050100EFFFE100F0000
            U111200 - Function limitation due to implausible message
                static
                    Date: 2024-06-23 18:47:37
                    Mileage: 149474 km
                    Priority: 6
                    Dynamic environmental data: 028D00220285304B100EFFFE100F0000
    15 Airbag
        System description: Airbag10.43
        Software number: 4H0959655H
        Software version: 0086
        Hardware number: 4H0959655H
        Hardware version: H82
        Serial number: 003P1005LKXM
        ODX name: EV_AirbaAU10BPAAU64X
        ODX version: 001014
        Long coding: 30333046313130313132554A304C34473853
        Trouble codes:
            B13BCF2 - Multiple collision brake No function
                static
                    Date: 2024-06-23 18:47:57
                    Mileage: 149474 km
                    Priority: 2
    16 Steering Column
        System description: Lenks.Modul
        Software number: 4H0953568H
        Software version: 0005
        Hardware number: 4H0953568H
        Serial number: 90372OG7000B6
        Long coding: 0004FC
        Subsystems:
            System description: E221 - MFL
            Software number: 4H0951528E
            Software version: 0010
            Serial number: 27 05 2015  G0067087
        Trouble codes:
    17 Dashboard
        System description: TDieRdwAccNv
        Software number: 4G8920934J
        Software version: 0104
        Hardware number: 4G8920934J
        Hardware version: H10
        Serial number: 6581007155960004
        ODX name: EV_RBD4K
        ODX version: 004055
        Long coding: 138F02023F5700080B0100
        Trouble codes:
    18 Parking Heater
        System description: Standheizung
        Software number: 4H0265105J
        Software version: 0260
        Hardware number: 4H0265105J
        Hardware version: H26
        Serial number: 20150630214706
        Long coding: 5D3F01
        Trouble codes:
    19 Gateway
        System description: J533--Gateway
        Software number: 4G8907468F
        Software version: 0083
        Hardware number: 4G8907468
        Serial number: 00000001918771
        ODX name: EV_GatewPkoUDS
        ODX version: 001028
        Long coding: C0CD078118
        Subsystems:
            System description: J367-BDMHella
            Software number: 8T0915181
            Software version: 8041
            Serial number: 5016837103
        Trouble codes:
    1B Active Steering
        System description: DYNAMIKLENK.
        Software number: 8K0907144M
        Software version: 0730
        Hardware number: 8K0907144M
        Long coding: 0E0100
        Trouble codes:
            01087 - Basic settings not carried out
                static
                    Priority:  2
                    Driving cycle: 255
    28 Rear Climate Control
        System description: KLIMA FOND
        Software number: 4G0919158R
        Hardware number: 4G0919158R
        Serial number: 06071500041735
        ODX name: EV_ClimaContrUnitRearUDS
        ODX version: 003004
        Long coding: 21
        Trouble codes:
    34 Chassis Control
        System description: LUFE-DAEMPFER
        Software number: 4G0907553G
        Software version: 0783
        Hardware number: 4G0907553F
        Serial number: ‰€%$
        ODX name: EV_AirSuspe
        ODX version: 003025
        Long coding: 008007
        Trouble codes:
                Intermittent
                    Date: 2024-06-24 13:35:13
                    Mileage: 149476 km
                    Priority: 6
                    Unlearning counter: 164
                static
                    Mileage: 149476 km
                    Priority: 6
                static
                    Date: 2024-06-24 13:35:12
                    Mileage: 149476 km
                    Priority: 6
    36 Driver Seat
        System description: MEM-FS
        Serial number: 00000155192835
        Long coding: C0183B0085016201010001010101112030303333203333
        Trouble codes:
    3B Sensor Electronics
        System description: SARA 6D red
        Software number: 4G0907637L
        Software version: 0056
        Hardware number: 4G0907637G
        Serial number: EJ1BPA7E01MP7R
        ODX name: EV_SARA2
        ODX version: 005012
        Trouble codes:
    3C Lane Change Assistant Right
        System description: SWA Master
        Software number: 4G0907566M
        Software version: 0060
        Hardware number: 4H0907566F
        Serial number: 0372075392
        ODX name: EV_LaneChangAssis
        ODX version: 001028
        Long coding: 040321
        Trouble codes:
    42 Driver Door
        System description: TSG FA
        Software number: 4G8959793H
        Software version: 0507
        Hardware number: 4G8959793F
        Long coding: 011F5F035E00628202080413
        Trouble codes:
    44 Steering Assistance
        System description: RCEPS
        Software number: 4G0909144S
        Software version: 0012
        Hardware number: 4G0909144G
        Hardware version: H43
        Serial number: 0028869842
        ODX name: EV_RCEPS
        ODX version: 009013
        Long coding: 011101010001
        Trouble codes:
            B1168F1 - Steering angle sensor Synchronization failed
                static
                    Date: 2024-06-23 19:07:57
                    Mileage: 149474 km
                    Priority: 2
                    Malfunction frequency counter: 11
                    Unlearning counter: 126
                    Steering wheel angle speed: 0.00 °
                    Calculated_steering_angle: 0.00 °
                    Steering angle sensor, status: System OK
                    Steering wheel angle: 2.7 °
                    System_state_current: Steering_control
                    Engine steering torque sensor, average value: -0.16 Nm
            C10ACF0 - Steering End stops not learned
                static
                    Mileage: 149474 km
                    Priority: 6
                    Malfunction frequency counter: 33
                    VIN_EEPROM: 33353233
                    VIN_bus_system: 33353233
                    BUS_SCU_Motor_Angle: 6550.6 °
                    BUS_SCU_Nominal_Angle: 6550.6 °
                    End_stops_unlearn_reason: unlearned by Diagnostic Service 31
                    End_stops_unlearn_reason_hex: 05
    46 Comfort System
        Serial number: 0373170135
        Long coding: 01000E3820B9F085C3200A8C2E030D4F0000000000000000000000000000
        Subsystems:
            System description: GTO BF
            Software number: 4G0959719
            Software version: 0081
            Serial number: 00000000000000299036
            System description: J245 PS40.402
            Software number: 4G8959591A
            Software version: 0004
            Serial number: 0000FST000E6LAF00000
            Long coding: 901F02
            System description: Dachelektroni
            Software number: 4G0947135G
            Software version: 0100
            Serial number: 0000000AP00013926834
            Long coding: 010000
            System description: HSP-SG
            Software number: 4G8959252
            Software version: 0029
            Hardware version: H11
            Serial number: WA121266000014398959
            System description: GEB.F.Heckoef
            Software number: 3AA962243D
            Software version: 0811
            Hardware version: H16
            Serial number: 93576672
        Trouble codes:
    52 Passenger Door
        System description: TSG BF
        Software number: 4G8959792H
        Hardware number: 4G8959792F
        Long coding: 011F5F035E00628202080402
        Trouble codes:
    53 Parking Brake
        System description: EPB-4
        Software number: 4H0907801H
        Software version: 0015
        Hardware number: 4H0907801A
        Serial number: 00000001534606
        ODX name: EV_ParkiBrake
        ODX version: 001028
        Trouble codes:
    55 Headlight Regulation
        System description: MxB-ECU
        Software number: 4H4907357E
        Hardware number: 7P6907357B
        Hardware version: 001
        ODX name: EV_HeadlRegulAUDIMXBAU64X
        ODX version: 005009
        Long coding: 05FA0A202A1F0200
        Subsystems:
            System description: LED LeiMo li.
            Software version: 7560
            Long coding: E02100
            System description: LED LeiMo re.
            Long coding: E02100
            System description: MxB LeiMo li.
            Software version: 0031
            Long coding: E02100
            System description: MxB LeiMo re.
            Long coding: E02100
        Trouble codes:
    56 Radio
        System description: MU-H-LND-EU
        Software number: 4G1035021T
        Software version: 0335
        Hardware number: 4G1035021
        Hardware version: 042
        Serial number: A588G0F7523409
        ODX name: EV_MUHig6C3Gen2HBAS
        ODX version: 001115
        Long coding: 017503010000000013111102000A00132F000CE5F17001009F
        Subsystems:
            System description: E380 BDT C7
            Software version: 0250
            Serial number: 90349OG70012P
            System description: DU8 C7 SV
            Software version: 0006
            Hardware version: H63
            Serial number: AUZ8Z9FY801ZLM
            System description: ECE 2018
            Software version: 0166
            Hardware version: ---
            Serial number: --------------------
            System description: Gracenote
            Software version: 1010
        Trouble codes:
    57 TV Tuner
        System description: DVB-DTV
        Software number: 8V0919191C
        Software version: 1800
        Hardware number: 8V0919191
        ODX name: EV_TVMELC
        ODX version: 001033
        Long coding: 0104010000000100000000
        Trouble codes:
    5F Multimedia
        ODX version: 001115
        Subsystems:
        Trouble codes:
    62 Rear Left Door
        System description: TSG HL
        Software number: 4G8959795H
        Hardware number: 4G8959795F
        Long coding: 010F1D024000628202080002
        Trouble codes:
    69 Trailer Control
        System description: Anhaenger
        Software number: 4G8907383B
        Software version: 0137
        Hardware number: 4G8907383B
        Serial number: 0352785006
        ODX name: EV_TrailFunctGener2Hella
        ODX version: 001005
        Long coding: 0100000202000000
        Trouble codes:
    6C Rear View Camera
        System description: TopView
        Software number: 4H0907428D
        Software version: 0330
        Hardware number: 7P6907441F
        Serial number: 82330JF0241181
        ODX name: EV_CamerSysteTopViewAUDI
        ODX version: 008027
        Long coding: 0216000101010100010102000000
        Trouble codes:
            B127CF0 - Front peripheral camera Calibration failed
                static
                    Date: 2024-06-23 18:48:26
                    Mileage: 149474 km
                    Priority: 5
            B127DF0 - Rear peripheral camera Calibration failed
                static
                    Mileage: 149474 km
                    Priority: 5
            B201000 - No basic setting
                static
                    Mileage: 149474 km
                    Priority: 2
    6D Deck Lid Control
        System description: HDSG-Modul
        Software number: 4G8959107S
        Software version: 0049
        Hardware number: 4G8959107H
        Serial number: 188500959
        ODX name: EV_HDSGAu573
        ODX version: 001022
        Long coding: 0A3305C023
        Trouble codes:
    72 Rear Right Door
        System description: TSG HR
        Trouble codes:
    82 Head Up Display
        System description: HeadUpDisplay
        Software number: 4G8919604M
        Software version: 0305
        Hardware number: 4G8919604M
        ODX name: EV_HUDContiC7
        ODX version: 001027
        Long coding: D70000
        Trouble codes:
    84 Night Vision
        System description: NV-ECU-Gen3
        Software number: 4G0907547A
        Software version: 0107
        Hardware number: 4G0907547
        Serial number: 6223524002015053045603
        ODX name: EV_NightVisioGen3AE4AU64X
        ODX version: 001001
        Long coding: 400100
        Trouble codes:
    85 On Board Camera
        System description: DPC-SG
        Software number: 4H0907217F
        Hardware number: 4H0907217A
        Hardware version: H27
        Serial number: 26213002542100000001593722
        ODX name: EV_OnBoardCamerDPC
        ODX version: 001007
        Long coding: EA160000
        Trouble codes:
    88 Driver Seat
        System description: P2G
        Software number: 4G8881073
        Software version: 0032
        Hardware number: 4G8881073
        Hardware version: H02
        Serial number: 0F6G5V0
        ODX name: EV_P2GDriveSideFrnt
        ODX version: 001006
        Long coding: 766FF0
        Trouble codes:
    89 Passenger Seat
        Serial number: 0F6H2FC
        ODX name: EV_P2GPasseSideFrnt
        ODX version: 001006
        Long coding: 366FF0
        Trouble codes:
    8B Adaptive Cruise Control
        Software number: 4G0907541B
        Hardware number: 4G0907541
        ODX name: EV_AdaptCruisContr2AU57X
        ODX version: 002012
        Trouble codes:
                static
                    Date: 2024-06-23 18:48:32
                    Mileage: 149474 km
                    Priority: 6
                    Dynamic environmental data: 028D001E0285303C100EFFFF100F0000
                static
                    Date: 2024-06-23 18:48:33
                    Mileage: 149474 km
                    Priority: 6
                    Dynamic environmental data: 028D001E02853036100EFFFF100F0000
    8E Image Processing
        System description: BV-SG
        Software number: 4H0907107H
        Software version: 0090
        Hardware number: 4H0907107
        Hardware version: H33
        Serial number: 00500062080715768601570000
        ODX name: EV_BC7
        ODX version: 001001
        Long coding: 03C0BB1D1111
        Trouble codes:
                static
                    Date: 2024-06-23 18:48:39
                    Mileage: 149474 km
                    Priority: 6
                    Voltage terminal 15: 12.3 V
                    Control module temperature: 36.0 °C
                    Outside air temperature: 25.0 °C
                static
                    Date: 2024-06-23 19:03:01
                    Mileage: 149474 km
                    Priority: 6
                    Voltage terminal 15: 11.8 V
                    Control module temperature: 39.0 °C
                    Outside air temperature: 24.5 °C
                static
                    Mileage: 149474 km
                    Priority: 6
                static
                    Mileage: 149474 km
                    Priority: 6
