Results 1 to 17 of 17
    Junior Member One Ring
    Oct 26 2008
    TX
    Alignment service
    After replacing all 4 tires I needed 4-wheel alignment. I called the Audi dealer for a quote. I was told it’ll cost $544 since they will check for the camera/sensor alignment too since I have driver assistance on it. And they go” if the alignment is in spec, I will be charged $60 only”
    What am I missing here? Is this something the Audi service usually does when you need the wheels alignment only?
    Or stay away from this place.
    Junior Member Two Rings
    Jan 28 2024
    Maine
    Quote Originally Posted by jale View Post
    I’ve never heard of needing an alignment after replacing tires, but maybe. Although, I did ask this question sort of last time I was at the dealership for my RS7. Basically what I asked what, if everytime I need an alignment is it going to cost me $699?!? (I have driver assistance package as well, so sensors etc). They told me depending on how bad the alignment is off, I may need a recalibration. But it’s not always a definite recalibration with each alignment. There is a certain threshold and if it’s within that threshold then you should NOT need to recalibrate.
    Junior Member Two Rings JB40NOW's Avatar
    Aug 14 2023
    Indiana
    No need to pay the money at the dealer. Call around. The independent shops are starting to carry the equipment for "Dynamic" alignments. Locally, I went to a Best One and paid $120 for a dynamic. Glad I did it. My alignment was way out, even though the vehicle tracked straight.
    Oct 26 2008
    TX
    Quote Originally Posted by JB40NOW View Post
    Already called an independent placed, specialized in euro cars, $150.
    Veteran Member Four Rings MyDimeIsUp's Avatar
    Dec 04 2019
    West Chester, PA
    Quote Originally Posted by BigStu123 View Post
    We always perform an alignment after putting new tires on. Adds insurance for the warranty from certain tire manufacturers. Technically from most tire manufacturers, alignments should done every 12 - 20k miles. If you submit a claim they may ask for proof of alignment history. Even then, it doesn't hurt to check the alignment to ensure your brand-new tires will wear evenly.
    $699 is ridiculous though. We charge $179 (yes, we're a dealer with a Hunter alignment machine) though that doesn't include calibrating the sensors (separate opcode for alignment w/ sensors which has higher pricing), though I nor anyone else have done that. Again, technically as per your car manufacturer you should, but literally no one does it.
    OP, I'd just have the alignment done either way. Ask the dealer if you can just get an alignment without calibrating the sensors (specifically ask if they can put a normal alignment opcode in rather than an alignment w/ calibration opcode). If they say no, take it to a shop with a Hunter alignment machine and ask for a simple alignment, no sensor calibration.
    2020 BMW M340i xDrive - Mineral Grey
    2012 Audi A6 3.0T Prestige - 034 Stage 1 ECU and TCU | CTS Turbo Intake | 034 Street Density Motor Mounts w/ JHM Trans Insert | ECS X-Pipe
    2013 Audi allroad - RIP
    2007 Toyota corolla
    Oct 26 2008
    TX
    Thanks for the input. I asked the other Audi dealer service (farther from my location), they said $244 without mentioning calibration part.
    Senior Member Three Rings Jimingle10's Avatar
    May 08 2013
    2014 RS7 Dynamic
    Concord, NH
    Depending on your situation, consider Firestone or Goodyear shops lifetime alignment. It used to be $180 when I got it for my A6 and I've used it dozens of times (logged over 200k miles)
    That being said, I won't let them touch my RS7. That car is special and let my indie shop dial it in when needed.
    Depends what you drive. The A6 was a work horse and because it's free alignments, if they got it wrong I'd just bring it back lol
    Sent from my SM-S908U using Audizine Forum mobile app
    2014 RS7 Prestige - Suzuka Gray
    - OEM Options: Exclusive Pkg, B&O, Dynamic Pkg, Innovation Pkg, Driver Assistance, Soft Close
    - DS1 Stage 2 w/ Custom (KYLETUNEDIT), TCU Tune, Meth, E85, TGK Intake
    2012 A6 3.0T Prestige - Black
    - Jackal Stage2+ E40, 196.5mm/60mm, Merc HX
    - JHM Baffled Test Pipes w/ X pipe and HFC.
    - Westfalia Tow Hitch
    *SOLD*2012 A6 3.0T 270k mi & 2017 Q7 Prestige & 2005 A6 4.2L
    2011 Suzuki Hayabusa
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by MyDimeIsUp View Post
    Other AZ threads have recommended alignment after new tire purchase even if tire wear on the old tires seems even, for the reason you mention. Alignment every 12-20k miles is a new one; rotation yes, but also alignment? The Michelin warranty only says the warranty is voided if tire wear is very uneven but does not suggest routine alignment. Interesting, Michelin includes three years of road-side assistance, including free tow up to 150 miles under certain circumstances. I haven't seen that mentioned in the threads discussing replacement tire recommendations.
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Veteran Member Four Rings esemes's Avatar
    Jul 02 2019
    whirlpool cabrio washer and dryer
    clearwater florida
    I had an alignment done last week at an indy speed shop (4 wheels w/hunter alignment machine) and it was 179.21
    2016 S6 - sport - optx- atlas - AE nardo
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    Indy did mine four days ago. $150 CAD. My car has never had an alignment since I owned it. New springs and suspension components.
    Veteran Member Four Rings white fish's Avatar
    Feb 21 2004
    05 allroad(old) 10 Q5 10 S4 13 S6
    T.O.
    Can I ask where?
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    Quote Originally Posted by Jimingle10 View Post
    A wheelworks (firestone) plugged in some coupon codes and gave me a lifetime alignment on my SQ5 for $120 a couple years ago. I’ve since gotten like 4 alignments. Really can’t beat that. Driver assistance cameras don’t ever need to be touched. Literally ever. Unless you’re swapping in a new one or just got in a wreck, or got a new windshield.
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Dec 04 2019
    West Chester, PA
    Just remember that an alignment is never perfect. To get a 100% perfect alignment, the car needs to be perfectly straight on the rack, the sensor caps that go on each wheel need to be 100% aligned with the axle, and the machine must be 100% calibrated. Obviously with all of that, it is going to be slightly off. Thats why the manufacturer gives tolerances. If the alignment printout doesn't show everything is right in the middle, don't sweat it too much; its only an approximation and as long as they are in the specified tolerances, you're good. I remember hearing about someone who freaked out about paying for an alignment and not everything was straight (even though it was all in the green).
    2007 Toyota corolla
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Fair enough. Good reason to always visually inspect tires for even tire wear.
    Oct 26 2008
    TX
    The alignment done. I'm glad I did it.
    Mar 19 2019
    Toronto/Ontario
    Quote Originally Posted by STXA7 View Post
    happy for you bro , got my entire front control arms and 4 corner shocks/mounts redone. alignment was mandatory after hadn't felt the ride this good not even when i bought it used haha
    Same. I am so happy I had the alignment done. It is so much better to drive. There was a slight toe in problem, no extra wear visisble on the tires. The car is on new springs with a swaybar upgrade though. So easy to drive and so precise I look forward to driving it for no reason at all, just to drive.
    Veteran Member Three Rings A665's Avatar
    Oct 26 2019
    Mid-Atlantic
    ...got my entire front control arms and 4 corner shocks/mounts redone. alignment was mandatory after hadn't felt the ride this good not even when i bought it used haha
    I replaced lower control arms, engine mounts and all four tires some weeks back. She rides like a dream, or better.
    2013 Audi A6 3.0T Prestige | S-Line / Sport | Full LED | 034 Stage 1 ECU+TCU | ECS Trans Mount Insert | JHM Driveshaft Carrier Bushing | FormulaOne Pinnacle Tint
