    Aug 08 2019
    boston
    2019 USA Q5 FULL LED to UK MATRIX LED replacement possibility
    Hi everyone.
    I'm driving a US-market 2019 Q5 that has had FULL LED headlights from factory.
    I've had an accident and those headlights are gone now.
    Now I'm thinking of buying a pair of UK-market MATRIX LED headlights to install on my car.
    I know there's slight wiring pin difference between US and UK cars but i think I can fix that.
    Also I am aware that the matrix function won't work without extra stuff like a special camera. I don't need that function.
    My question is - will they work on my car just to replace the functions of stock FULL LED headlights without the extra functions?
    Established Member Two Rings Reihenmotor5's Avatar
    Oct 25 2020
    2019 Audi Q5 Premier Plus (wife’s)
    Western PA
    201 USA Q5 FULL LED to UK MATRIX LED replacement possibility
    Not sure if you’re aware, but I looked into swapping my wife’s same MY QFive Premier Plus with the Matrix headlights and they cost around nine thousand and five hundred dollars. If you’re not planning to make the appropriate coding and flashing of controller modules, not worth the cost in my opinion.
    Sorry for spelling out but recent Tapatalk doesn’t like numbers and throws a ton of emoji references.
    VW/Audi family. I mod & drive the VW & she drives the Audi. My VW mod doc https://tinyurl.com/TigRLineMods
    Aug 08 2019
    boston
    I've found some ok offers for used pairs of UK matrix headlights. I'm fine with codings as well as long as they are theoretically possible. I'm just waiting for an answer from someone who can say whether it's possible or not. Thanks.
    Oct 25 2020
    Western PA
    You’ll need to flash the controller for the camera in the windshield in addition to coding.
    Not sure if them being UK versions having an impact due to them being RHD. I’m sure someone else might have insight.
    May 20 2010
    I understand what the matrix LEDs do, but just like older cars, I'd be concerned about the lenses being different to account for RHD in UK vs LHD here in USA. Even if the LEDs turn off, you may still inadvertently dazzle oncoming drivers.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
