Originally Posted by
Smac770
My complaint at the moment would be the apparent complete lack of understanding of the ENVD variables. They do not appear to be the live measured values. Are they diagnostics test result variables? Are they key on measured values recorded for comparisons? There's no ENVD in the Bosch MED variables, and almost none in the Simos 16 of the B9 CYMC. But that could be due to one complaint I have with VCDS labels, they remove the software variable name when they put in a wordy text label. Makes it hard to relate measuring values to variables in proper technical documentation. But it doesn't seem anyone has any proper technical documentation of Simos 8.4 or 8.5 for the supercharged engines.
ENG101388 Intake manifold pressure: absolute 322.05 297.18 hPa
ENG101499 map 330.84 303.31 hPa
ENG103166 MAP_ENVD 0.0000 0.0000 hPa
ENG102680 MAP_1_MES 328.85 305.97 hPa
ENG99737 MAP_1_MES_BAS 321.14 307.62 hPa
ENG102949 MAP_1_ENVD 557.19727 557.19727 hPa
ENG102281 MAP_2_MES 325.95 313.43 hPa
ENG104243 MAP_2_MES_BAS 320.31 305.39 hPa
ENG102960 MAP_2_ENVD 551.89063 551.89063 hPa
ENG99319 Ambient pressure 976.69 975.61 hPa
ENG101830 AMP_ENVD 976.4219 976.4219 hPa
ENG101106 PDT_ENVD 557.19727 557.19727 hPa
ENG99738 RFP_AV 63.96 59.14 °
ENG103313 RFP_AV_ENVD 64.4882 64.4882
ENG101571 RFP_SP 63.42 59.47 °
ENG102212 RFP_SP_ENVD 64.4882 64.4882
Above are some samples of data from maps with the engine idling, cold start vs warm start I believe (vs cold start then after warmed up). Not my data; I don't have a 3.0T to test.
So what is MES vs MES_BAS vs ENVD? SP = specified; AV = actual? PDT = ? The freeze frame data values listed are the ENVD ones, but we have no assurance they are relevant to the actual math of the P code. And the Audi documentation is, as usually the case, almost useless.
What's curious is the only values around that 55x mark in the blockmap are MAP_1_ENVD, MAP_2_ENVD, and PDT_ENVD.
And then there's a single value for what appears to be some "difference of ambient vs MAP", but why record that?
ENG125298 PRS_DIF_AMP_MAP_DIAGCPS 628.93 669.72 hPa
In your freeze frame values, your two MAP ENVDs are similar, but the PDT one is quite different. The P code is because something was "too different", but specifically what, not sure we can know with only the documentation we have.
(the forum removes all white space formatting for whatever reason, so your stuck having to read the table as the forum engine insists)
Yes I agree, the labels and variable names of the VCDS measuring blocks are very annoying, and documentation on the 8.4/8.5 Simos is limited. Perhaps the VCDS wiki has some kind of list that relates their wordy names to the variables listed in Audi's documentation. And you're correct, we have no idea what variables are actually related to the rationality check of the P012B00 code. The fact that the freeze-frame data chooses to show you the ENVD values must mean they're relevant in someway, but we do not know for sure. Maybe I'll post this in the RossTech forums and see if anyone over there as a clue as to the relevancy of the ENVD values. But thank you for the sample data.
I've been able to gather more understanding of these variables from another forum.
https://forums.audirevolution.net/t/...logging/6086/5
It appears that your suggestions were correct:
AV - Actual value
SP - Setpoint
ENVD - Environmental data (still a little unsure of what that actually means, and how is it different from AV or MES?)
RFP - Recirculation flap (reported in degrees, I think this is the boost regulating flap at the back of the supercharger, right after the throttle body)
Ones I'm unsure of:
MES = measured value?
BAS = Baseline value (what the ECU is being told to target?)
AMP = ambient pressure?
PDT = no freaking clue? Perhaps "Pressure Difference Target" Just throwing things around here.
Perhaps "MAP" and "MAP_ENVD" are for the supercharger inlet sensor, and MAP 1 & MAP 2 are the charge pressure sensors because there are two of them.
Comparing the sample data to mine, The MAP 1/2 ENVD's are very similar. The AMP_ENVD's are about 25 hPA difference, which is probably attributed to environmental differences, assuming AMP = ambient pressure. Ambient pressure at sea level is 1013 hPa (I'm at sea level), but it's roughly 970 at 1000 ft above sea level (matches sample data). My PDT_ENVD is roughly 144 hPa lower than the sample data (that's a pretty big difference), and my RFP_AV_ENVD is roughly 6 degrees greater.
So, based on my freeze-frame data , I don't see much of a difference between the sample values you provided.
Instead of relying on the freeze from data, perhaps the better approach is to try and log/live-monitor those measuring blocks during cold startup, driving, and warm startup to try and look for differences. Perhaps the signal is dropping out intermittently, but the dropout happens too quickly to be captured by the freeze frame data.
I closely inspected the connectors for all three MAP sensors, and the wires leading up to the sensors, and I didn't notice anything out of the ordinary. No frayed wires, no loose connections to the crimped contacts. However, I did notice that the white rubber seal on the connector for MAP 2 looks a little beat up & torn, and it kind of jams up when plugging the connector into the sensor. Perhaps moisture is getting in there? The humidity in NH has been very very high in the past week or two. Typically 80% or more. Replacing the connector body wouldn't be too hard, and I have the tools to remove the socket contacts from the body.
In other news, the car has been running good and the code hasn't resurfaced in the last two days of commuting. I've done a healthy mix of highway, back-road, and stop-and-go driving. I've driven it quite conservatively for the most part, but also have done some spirited pulls here and there. Both with A/C on an off, in comfort & dynamic, just trying to create different load & rpm situations resulting in large swings of boost/vacuum.
Maybe I'll post some more data later this evening to match the sample data you provided. Thanks for the help and the insight!
