Results 1 to 3 of 3
    Junior Member Two Rings
    Jan 15 2017
    Marion, Iowa
    Valve cover gasket replacement
    Have a 2011 Q5 with the 2.0. Was misfiring so I went to change the coil pack and there is oil in the tube surrounding the spark plug. From what I read it needs the valve cover gasket replaced. Called one shop and they said $300. Called another that works on German cars and they said it could have the cover that also holds the cam cover in place and could be up to $1k. Anyone have any experience replacing this? TIA
    Jul 16 2018
    Atlanta
    If you mean the 2.0T CAEB engine, there is no preformed gasket there; it's an anaerobic RTV sealant. And it's not a simple valve cover; the cylinder head cover is also the upper bearings for the cams. There's threads about the task in the B8 A4 forum. The CAEB 2.0T engine is the same be it B8 A4, B8 A5, or B8 A5.
    Jan 15 2017
    Marion, Iowa
    It’s the 2.0 TFSI engine.
