Results 1 to 3 of 3
    Junior Member Two Rings sergcool's Avatar
    Dec 25 2019
    California
    Exclamation 2016 Audi S4 Weird Loud Engine or Supercharger Noise with RPM/Revs
    Hello everyone.
    A couple of days ago my engine started making weird noise which gets louder and quieter with RPM/Revs.
    I also noticed from the location of the supercharger, it started being way louder almost knocking/tapping.
    I think I remember having before, similar tapping noise when I just start the car, but then it would go a way once the car warms up. I might be mistaken though.
    What might this possibly be?
    Some videos of the issue below:
    Starting up the car:
    Noise in the area of supercharger:
    Weird noise with RPM/Revs:
    Weird noise with RPM/Revs (2nd vid, bad quality sound at first):
    Dec 25 2019
    California
    Update: Scanned for codes and I got P052E00, PCV issue? Researched a bit online and people say that Audi Crankcase Breather Hose - VNE 06E103207AP might be bad.
    Could this be the cause of the noise which happens with the revs? This is my daily driver and I want to make sure with my constant driving, I don't make things worse.
    Senior Member Three Rings LowKeyLoki's Avatar
    Aug 28 2021
    Atlanta/GA
    Yea you need to replace the PCV hose running to the PCV/intake hose. I’d check first make sure the hose didn’t get knocked off or something, it sits on the intake hose right before the throttle. Most likely gonna have to replace the hose and PCV breather, parts are a couple hundred and requires taking the supercharger off. Plenty of info on Audizine about PCV replacement.
    2014 S4 - DSG - Prestige - Volcano Red - Sport Diff. - ADS (deleted) - Bilstein B12 Kit- Stock
    2011 S4 - DSG - Prestige - Ibis White - sport diff. - IE Stage 1 ECU/TCU - DESTROYED
