first, the main question: should i hone the cylinders and replace the rings? a couple cylinders are lightly scored in a way that no honing could help, but the others...? this is a big added cost - $500-550 just in seals and bolts, plus the rings, honing kit, and maybe new bearings.
this is a BHF around 145,000mi. i haven't run a compression test in a long time, but it was decent in the past.
cylinder 1 has these two short scrapes; the deeper-looking upper one just catches a fingernail.
cylinder 3 has a long scrape that doesn't catch a fingernail, but can definitely be felt with one. these seem like some grain of sand made it into the cylinder and was pushed against the wall.
honing probably wouldn't do much for that damage. i'm not really worried about them, though; the long one is shallow, while the deeper one is just at the top of the cylinder.
4 is where honing might actually do something. these dark marks can't really be felt, other than maybe a very, very slight difference in surface smoothness.
it's a bit hard to tell what's going on with 5, but the areas with dark speckles are the normal surface with silicon nodules poking out of aluminum. there are splotches of smooth grey, however, that might be where silicon was worn down...? or not properly honed in the first place?
would honing do anything here? there's a limit to what you can do to Alusil at home, so i'm not sure if it's worth the significant added cost. new rings might be a good idea for this aging engine, but is that more of a nice-to-have than critical preventative maintenance?
